    [Plugin] Physically-Based Rendering - v1.5.9 - 19 Apr. 2020
    119 Posts 14 Posters 96.8k Views 14 Watching
    • samuel_tS Offline
      samuel_t
      What's new in the version 1.5.2 of the PBR plugin?
      • You can add artificial lights from Toolbar/Menu.
      • You can adjust sunlight intensity in Viewport.
      • Camera control in Viewport is similar to SU one.
      Download latest PBR plugin from the SketchUcation PluginStore.
      • samuel_tS Offline
        samuel_t
        What's new in the version 1.5.3 of the PBR plugin?
        • Camera position in Viewport is automatically saved/restored.
        • You can reset camera position in Viewport in one click on movie camera icon.
        • "Propagate materials to whole model." is automatically done.
          So we will win a click! ๐Ÿ˜‰
          • samuel_tS Offline
            samuel_t
            What's new in the version 1.5.4 of the PBR plugin?
            • Textures not supported by glTF are supported by PBR plugin in SketchUp v2018 or greater.
            • Fix bug: SketchUp model can't be saved (CFileException 0...) whereas PBR Viewport is open.
            • PBR plugin checks automatically if a newer version is available @ http://www.sketchucation.com.
            • samuel_tS Offline
              samuel_t
              What's new in the version 1.5.5 of the PBR plugin?
              • Ambient occlusion maps are supported. For now, they are incompatible with height maps. ๐Ÿ˜•
              • When you erase a PBR light: PBR Viewport reopens automatically. Also, PBR lights are named.
              • Minor things were changed. E.g: SketchUp status bar changes when PBR Viewport (re)opens...
              • samuel_tS Offline
                samuel_t
                What's new in the version 1.5.6 of the PBR plugin?
                There is an option in PBR Menu to track all changes done in SketchUp. When checked, PBR Viewport is automatically refreshed. Note that requires a powerful computer!
                • samuel_tS Offline
                  samuel_t
                  The version 1.5.7 of the PBR plugin:
                  • Exports sun light direction according to settings defined in Shadows panel.
                  • Fixes three little bugs about: ME tooltips, SU back faces & Viewport loader.
                  • samuel_tS Offline
                    samuel_t
                    The version 1.5.8 of the PBR plugin:
                    • Exports sun light intensity according to Light parameter defined in Shadows panel.
                    • Fixes a bug affecting some models: Viewport doesn't open and SketchUp freezes โ—
                    • samuel_tS Offline
                      samuel_t
                      The version 1.5.9 of the PBR plugin fixes URL of required plugin (glTF Exporter).
                        DH2002
                        First, Is this Plugin works for Mac OS SketchUp 2018 Pro?
                        I managed to Install it and I have SimLab USDZ exporter Installed that works fine.
                        After I install this Plugin SketchUp crashes, cant even save or load any object?
                        I can draw a new mesh and even open this plugin, Load maps etc but when the try export files Aplication Crashes?
                        My SketchUp the doesent work properly until I deinstall this Plugin.
                        / Daniel
                        • samuel_tS Offline
                          samuel_t
                          / Daniel
                          First, sorry for this late reply:
                          This plugin is compatible with SketchUp 2017-2021 for Windows and should be compatible with SketchUp 2017-2021 for macOS.
                          If this plugin crashes when you export model as glTF file, you can try to in order:
                          1. Open "Window > Ruby Console".
                          2. Copy-paste below code:
                          PBR;;GlTF.export
                          1. Press enter to execute above code.
                          2. Send me a screenshot.
                          • samuel_tS Offline
                            samuel_t
                            The PBR 2.x plugin for SketchUp will support real-time ray tracing. Work in progress:
                            • pabloariasP Offline
                              pabloarias
                              Hi. From a month, more or less, I got a popup when SU starts that said something about a newer version 4.2.6 from this plugin and opens this SketchUcation page when message accepted. But I see no news here about newer releases of this plugin. Does anybody here tell me what's wrong?
                              Pablo Arias
                              SketchUp trainer
                              V-Ray licensed trainer
                              • chonC Offline
                                chon
                                Hello,
                                I think this message is about the last version of SketchUcation ExtensionStore ๐Ÿ˜‰
                                • samuel_tS Offline
                                  samuel_t
                                  @chon said:
                                  Hello,
                                  Yes, it makes sense! ๐Ÿ˜„
                                  • samuel_tS Offline
                                    samuel_t
                                    Hi Pablo.
                                    4.2.6 ? ๐Ÿ˜• I'm working on the 2.x version of the PBR plugin but the latest public version available at SketchUcation is 1.5.9.
                                    • Didier BurD Offline
                                      Didier Bur
                                      Hi Samuel,
                                      First thanks for this great plugin (just like all of your other goodies).
                                      Some questions about the materials:
                                      -what is the difference between the heightfield map and the normal map features ?
                                      • how to get an occlusion map based on a jpg texture ?
                                      I'm starting some tests and amazed with the results ๐Ÿ˜‰
                                      Thanks for your time.
                                      DB
                                      • samuel_tS Offline
                                        samuel_t
                                        @didier bur said:
                                        Hi Samuel,
                                        Hi Didier,
                                        That's very kind! ๐Ÿ˜„
                                        The height map in the PBR 1.x plugin is a parallax occlusion map. The height map is a grayscale image which simulates a "deep relief". You can use a displacement map from Poly Haven (for example) as a height map. Whereas the normal map encodes the "bas-relief" in the RGB channels of an image...
                                        Handmade or automatic? Some softwares can autogenerate an [ambient] occlusion map from a diffuse texture...
                                        Stay tuned ๐Ÿ˜‰ The PBR 2.x plugin should reach photorealism.
                                        You're welcome!
                                          Didier Bur
                                          Hi Samuel,
                                          Thanks for your answers.
                                          I'm curious to know why each time I launch Sketchup I get the message:
                                          It loads the Web page where I can dowload version 1.5.9. ๐Ÿ˜ฎ
                                          Where can I find version 4.2.6 ?
                                          Best regards,
                                          DB
                                          • chonC Offline
                                            chon
                                            Hi Didier,
                                            I think you've got the same problem as on this post :
                                            @chon said:
                                            Hello,
                                            • 2 / 6
