    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 646.7k Views 71 Watching
    • utilerU
      utiler
      Good morning Garry, is there a way to change the door arc radius? I note that its set to 120 degrees as standard but I'd like to set it to 85-90 degrees.
      Can't seem to find it anywhere in the manual.
      Cheers,
      Just Curious...
      • G
        Garry K
        Try this
        • utilerU
          utiler
          Seriously, I need glasses... Thank you Garry. 😳
          Just Curious...
            marcinek12
            I got problem with plugin gkware cabinet maker v6
            Window come up with Registration
            User id i got it
            What password i need to tape in
            I need to registered somwhere?
            Thank you
            • G
              Garry K
              First create an account on my website
              https://cabmaker32.com/login/
              Use those credentials with any of my plugins.
              Garry
              • ajharlanA
                ajharlan
                I am scratching my head to try and figure this one out. I've tried multiple permutations of settings but cannot seem to get past this error. Any help appreciated.
                "Drawer System Error: Height < = 0"
                • G
                  Garry K
                  Contact me via Skype
                  My Skype handle is:
                  gkernan@telus.net
                    srimadiraju
                    Hello Gary,
                    Can i use cabmaker v6 & Cutmaster for modular furniture (kitchens&wardrobes) cutlist purpose to produce cut sizes, edge banding details, holes for mini fixes & groves to work on machines?
                    Iam planning to purchase if it works for me.....
                    Awaiting for your reply
                    Thaks & Regards
                    Sri
                    • G
                      Garry K
                      Yes it should - I can talk to you over Skype.
                      My Skype handle is:
                      gkernan@telus.net
                        Antonis777
                        After i click this the user id window disappears and Sketchup freezes as if it was somewhere a hidden window or task and needed to be closed first. I can't even close Sketchup I do it from task manager
                        • G
                          Garry K
                          Please email me from my website and provide me with your userid
                            shaunperkins
                            hi
                            im trying to make several cabinets that are tall open shelf cabinets (ends,tops, bottoms and backs) out of door material, so i can get it to come up as components on m export,
                            is this at all possible?
                            • G
                              Garry K
                              CabMaker allows you to add finished panels to sides and back.
                              You can configure the cabinet to have no bottom and then add another cabinet with depth of 0 so that you can have another door set up as a bottom. When you edit the main cabinet the new bottom door cabinet will NOT be edited - you will have to edit the bottom door (cabinet) indpendently.
                                mitch8628
                                Hello Garry,
                                I submitted a purchase for CabMaker Build I think 2 days ago, and emailed you my user name. Just checking to see what to expect for time frame for getting the plugin active with my user name.
                                Mitch
                                  mitch8628
                                  Thanks to Garry for getting back to me quickly through email! Looking forward to diving deeper into the plug-in for our kitchen design!
                                  • N
                                    NancyL
                                    I've really enjoyed working with cabmaker and cutmaster and I'm getting close to wanting to take my DFX files to the local CNC place.
                                    I'm hung up on the drawer and hinge systems and how to set them up in the two programs. It seems there are a few demo ones set up in the DB, but not what I want to use. further I'm not finding any useful information about adding the data for the system I DO want to use in either help file.
                                    Has anyone else sorted out how to add a new drawer slide system? I'm specifically interested in the BLUM Tandem full slides.
                                    • C
                                      cullisz
                                      I just purchased the plugin and was wondering if it's possible to make Farm Sink style sink cabinets. I searched this forum for previous posts relating to this and also checked YouTube but couldn't find anything.
                                      Thanks.
                                      • G
                                        Garry K
                                        Yes you can. You need to adjust the cabinet - set the top drawer so that it does not create a drawer and does not create the drawer front.
                                        • B
                                          blah1234567890
                                          How can I get cabmaker to user my pullout slide adjust measurements. I only need a 1/2" on each side of the pull out for the drawer slide. No mater where I change the slide adj it always defaults to 1". I am on the trial and have adjusted no settings. Its confusing because its listed in multiple areas. Which on is it.
                                          This is what's in the system and even if I make changes nothing happens).
                                          Rules 2:
                                          Pullout Slide Adj: Default - 2" (When changed nothing happens. Yet when I make it its 1" on each side, not 2".)
                                          Drawers:
                                          Pullout Options:
                                          Pullout Row: 1
                                          Slide Adj: Default 0" (When I change nothing happens.)
                                          If I change both at the same time nothing also happens. Its always 1" on both sides of the pullout.
                                          • G
                                            Garry K
                                            sounds like your tabs are locked.
                                            Go to PROJECT tab and turn off locks
                                            With your input, this post could be even better šŸ’—
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 29 / 32
