    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 573.0k Views 71 Watching
      Garry K
      Contact me via Skype
      My Skype handle is:
      gkernan@telus.net
        srimadiraju
        Hello Gary,
        Can i use cabmaker v6 & Cutmaster for modular furniture (kitchens&wardrobes) cutlist purpose to produce cut sizes, edge banding details, holes for mini fixes & groves to work on machines?
        Iam planning to purchase if it works for me.....
        Awaiting for your reply
        Thaks & Regards
        Sri
          Garry K
          Yes it should - I can talk to you over Skype.
          My Skype handle is:
          gkernan@telus.net
            Antonis777
            After i click this the user id window disappears and Sketchup freezes as if it was somewhere a hidden window or task and needed to be closed first. I can't even close Sketchup I do it from task manager
              Garry K
              Please email me from my website and provide me with your userid
                shaunperkins
                hi
                im trying to make several cabinets that are tall open shelf cabinets (ends,tops, bottoms and backs) out of door material, so i can get it to come up as components on m export,
                is this at all possible?
                  Garry K
                  CabMaker allows you to add finished panels to sides and back.
                  You can configure the cabinet to have no bottom and then add another cabinet with depth of 0 so that you can have another door set up as a bottom. When you edit the main cabinet the new bottom door cabinet will NOT be edited - you will have to edit the bottom door (cabinet) indpendently.
                    mitch8628
                    Hello Garry,
                    I submitted a purchase for CabMaker Build I think 2 days ago, and emailed you my user name. Just checking to see what to expect for time frame for getting the plugin active with my user name.
                    Mitch
                      mitch8628
                      Thanks to Garry for getting back to me quickly through email! Looking forward to diving deeper into the plug-in for our kitchen design!
                      • N Offline
                        NancyL
                        I've really enjoyed working with cabmaker and cutmaster and I'm getting close to wanting to take my DFX files to the local CNC place.
                        I'm hung up on the drawer and hinge systems and how to set them up in the two programs. It seems there are a few demo ones set up in the DB, but not what I want to use. further I'm not finding any useful information about adding the data for the system I DO want to use in either help file.
                        Has anyone else sorted out how to add a new drawer slide system? I'm specifically interested in the BLUM Tandem full slides.
                          cullisz
                          I just purchased the plugin and was wondering if it's possible to make Farm Sink style sink cabinets. I searched this forum for previous posts relating to this and also checked YouTube but couldn't find anything.
                          Thanks.
                            Garry K
                            Yes you can. You need to adjust the cabinet - set the top drawer so that it does not create a drawer and does not create the drawer front.
                              blah1234567890
                              How can I get cabmaker to user my pullout slide adjust measurements. I only need a 1/2" on each side of the pull out for the drawer slide. No mater where I change the slide adj it always defaults to 1". I am on the trial and have adjusted no settings. Its confusing because its listed in multiple areas. Which on is it.
                              This is what's in the system and even if I make changes nothing happens).
                              Rules 2:
                              Pullout Slide Adj: Default - 2" (When changed nothing happens. Yet when I make it its 1" on each side, not 2".)
                              Drawers:
                              Pullout Options:
                              Pullout Row: 1
                              Slide Adj: Default 0" (When I change nothing happens.)
                              If I change both at the same time nothing also happens. Its always 1" on both sides of the pullout.
                                Garry K
                                sounds like your tabs are locked.
                                Go to PROJECT tab and turn off locks
                                • N Offline
                                  nakinaw
                                  Hey Gary.
                                  Curious how you animate doors in Cabmaker? I turned the animation on, but how do you toggle the doors open/closed?
                                  Steve
                                    Garry K
                                    You must have Dynamic Components loaded
                                    Then choose SU / tools / Interact
                                      MFC83
                                      Does anyone know how to edit the cabinet style to have a "Plant On" back? Meaning the cabinet back is the full width and height of the cabinet box and the sides and bottom are butt jointed to it. For example https://imgur.com/a/XnkNK39
                                        Garry K
                                        Set the dado to be >= the thickness of the sides
                                          MFC83
                                          Excellent! Thanks for the quick response and solution!
                                            Distinctive Woodwork
                                            Hi Garry,
                                            I found your plugin on sketchup, and tried to use it. I have run into error -25. I got a couple hours into using the extension and like what i have seen. I am serious about purchasing this extension, as it would be to great help in my drafting for clients! I have sent you an email with all my information. Let me know how we can proceed!
                                            With your input, this post could be even better šŸ’—
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 29 / 32
