    Work Flow question - determining scale without dimensions
    19 Posts 4 Posters 3.1k Views 4 Watching
      jman0war
      If someone sent you plans for a house in PDF, that included Front, Left, Right, Rear Elevations and a RoofPlan.
      But there were no dimensions included at all and the only information you had to go on was a scale ruler sort of information under the elevation title that says:
      FRONT VIEW
      1/4" = 1'-0"
      (one quarter inch equals one foot).
      The other Elevations are a different scale:
      1/8" = 1'-0"
      (one eighth inch equals one foot)
      But you don't have a large format printer to print this PDF and a scale ruler to use πŸ˜•
      Photoshop somehow?
        Are you going to be using the plans in sketchup?
        Does is say 1/4" = 1'-0" at A1 or A2 ect? does it nominate page size?
          jman0war
          Yes to the first question.
          I don't see a page size, but the PDF file properties says:
          Page Size: 36 x 24 inches
          So it must be "D Sized Paper for Architectural Plans"
          https://www.engineersupply.com/Drawing-Size-Reference-Table.aspx#:~:text=D%2Dsize%20paper%20for%20architectural,course%2C%20other%20drawing%20paper%20sizes.
            Are you aware of how to scale in sketchup?
            If so you could scale the page in Sketchup to the said dimensions and then do simple maths
            1/4" = 1'-0" 1:48.........imperial......sheesh'
            Or stating the obvious by asking the supplier for one known dimension
            Beware, when you scale the 2 different scales do them in different sketchup models and bring one into the other after scaling or you will be in trouble as SU does not scale the item but the whole world scale.
              jman0war
              If so you could scale the page in Sketchup to the said dimentions and then do simple maths
              Or stating the obvious by asking the supplier for one know dimention
              Yes i know how to scale in SketchUp.
              What i don't know however, is how do I determine what 1/4" is in the PDF?
              Or even 1 foot for that matter.
                jman0war
                @l i am said:
                Like I said, scale the page in SU to 36 x 24 inches. then scale
                Ok I think I follow you.
                I can save the PDF as an image file.
                Drag that into SU, scale to 36" on the long side - but then my image looks pretty crude as it's been scaled down (is that due to my current unit settings?)
                But that's probably ok for now.
                Use Tape Measure Tool to determine how many inches wide this elevation is, then do the math and punch in the result..
                  (edited) To be clearer, scale the paper to say 36 inch. Then use the measuring tool to measure a dimention in the drawing. Then when you have measured it apply the scaling maths and scale the drawing again so it is 1:1. Not ideal but should be OK for an su model.
                    πŸ‘
                      If you do not have a high res converter try this it works online with no fees or sign up
                      PDF to JPG Converter | Convert Your PDF to Image Online
                      Turn your PDF into a JPG image with a free online tool. It's easy to convert PDF pages into high-quality images instantly with our online PDF to JPG converter.
                      PDF to JPG Converter | Convert Your PDF to Image Online (smallpdf.com)
                      And if you are using SUP it does support PDF's
                        jman0war
                        It's the scaling down within SU where the quality of the image drops.
                        Makes sense because 36" x 24" is a small area in SU for a Plan that has 4 elevations within it.
                        • BoxB Offline
                          Surely there is something in the drawings that you can use as a known dimension. The height of a door, a brick, a roof tile, a stud. a joist etc etc
                          Can you show us an image.
                          Just checking also that there isn't a physical scale depiction with the scale.
                            jman0war
                            I guess i could use a door as a known dimension.
                            https://1drv.ms/u/s!An4TIiBt2x9fnDlj8TAbtJZBkpTJ?e=Pi0f6S
                            • BoxB Offline
                              I'd be sending it back with a polite note telling them it is unusable with at least one known dimension.
                                Agreed but we are not sure of the circumstances. But I would think the source of the drawings could be got hold of, somebody paid for it. Could jman0war send a screenshot of the image in SU. I often have to deal with those images, and they are difficult to work with. However when they are blurred I draw sketchup lines in the center of the blurred line. Can we see how blurred it is with the requested screenshot?
                                • BoxB Offline
                                  He posted a link to the pdf.
                                    I missed it. But not sure I see the problem.
                                      Glenn at home
                                      FRONT VIEW
                                      1/4" = 1'-0"
                                      You could always download and use the Bluebeam Revu trial. It allows you the measure PDFs. You can even set the scale or calibrate to a known distance. Once the trial is over you can continue to use it in "Vu" mode. It's a very slick tool.
                                      https://i.ibb.co/DG2NhfN/Vu.jpg
                                        jman0war
                                        Thanks.
                                        I used to use BlueBeam Revu years ago, mostly for the one click PDF conversion and a few Markup tools.
                                        Looks like they've added functionality.
                                          Glenn at home
                                          @jman0war said:
                                          Thanks.
                                          I only have the viewer but it's great to get dims off of PDFs. It'd be nice to be able to bring vector PDFs into SU (like I can in AutoCAD) but maybe one day. πŸ˜‰
                                          Good luck
                                          Glenn
