    Medeek Wall Plugin
    1.6k Posts 29 Posters 2.0m Views 28 Watching
    • medeekM
      medeek
      Version 1.9.6 - 03.09.2021
      • Added a layer for "symbols" to the miscellaneous layer/tag options (Layer tab of the Global Settings).
      • Fixed a minor bug in the shed wall edit menu.
      This update moves the symbols for windows, doors, garage doors, shearwalls, in-wall columns and holdowns to the "wall_symbol" layer/tag.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Version 1.9.7 - 03.12.2021
        • Fixed a bug involving gable, shed and hips walls that are created adjacent to rectangular walls.
        • Fixed a minor bug involving regeneration of dissimilar wall types at the same type.
        design.medeek.com
        • medeekM
          medeek
          Version 1.9.8 - 03.13.2021
          • Added an extra (Trim Top Plate) parameter to the "Start" and "End" configurations of rectangular walls.
          http://design.medeek.com/resources/wallplugin/images/wall_su494_800.jpg
          **** CAUTION ****
          This update adds two new parameters to the rectangular walls and will require the user to delete and recreate any rectangular wall presets. This upgrade does not affect gable wall or any other presets (ie. windows, door, garage, gable wall, shed wall, hip wall).
          This parameter (for the start and end of the wall) should normally be assigned to a value of "YES", this is also its default behavior. However, in certain cases (such as a corner with a shed or gable wall) it may be useful to configure its value as "NO", as shown in the image above.
          design.medeek.com
          • medeekM
            medeek
            I’ve had some recent interest in a log siding/cladding similar to the shiplap cladding I enabled recently:
            https://aws1.discourse-cdn.com/sketchup/original/3X/8/8/8848f4df76b98d11aa7ecb6c0b5050cd0db5b92e.jpeg
            Thoughts?
            design.medeek.com
            • pbacotP
              Fond memories of my parents' little old cabin in Arizona (no picture handy-- no street view--still there and little changed). Is the tongue in the ship lap that thin? Maybe so. About half an inch?
              • medeekM
                medeek
                The example shown is not dimensional correct per se, just representative at this moment.
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.9.9 - 03.20.2021
                  • Added the ability to create custom "Log" wall cladding materials within the Material Library.
                  • Enabled "3D" Log wall cladding for all wall types: Rectangular, Gable, Shed and Hip.
                  http://design.medeek.com/resources/wallplugin/images/wall_su497_800.jpg
                  http://design.medeek.com/resources/wallplugin/images/wall_su495_800.jpg
                  http://design.medeek.com/resources/wallplugin/images/wall_su496_800.jpg
                  View model here:
                  3D Warehouse
                  (3dwarehouse.sketchup.com)
                  design.medeek.com
                  • medeekM
                    medeek
                    Here is an issue with half walls that tee into other walls. Notice how the gypsum is being cut:
                    https://aws1.discourse-cdn.com/sketchup/original/3X/2/b/2b560a8d2675e5ed5b75a9e4505e9871afb0c766.jpeg
                    Let's see if I can adjust the gypsum module to rectify this particular situation.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 2.0.0 - 03.21.2021
                      • Fixed a bug with the gypsum (cutout) where a half wall tees into another wall.
                      http://design.medeek.com/resources/wallplugin/images/wall_su499_800.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 2.0.1 - 03.27.2021
                        • Fixed a bug (introduced with Version 1.9.8 release) with wall presets for rectangular walls.
                        *** Critical Fix ***
                        I highly recommend updating to this latest release. A small typo in the 1.9.8 release essentially rendered the wall presets unusable. This fix rectifies that error and re-enables wall presets.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 2.0.2 - 03.31.2021
                          • Added a "Draw Molding" tool to the updated Blocking/Molding toolbar.
                          • Added the ability to create base board, crown molding and chair rail with the "Molding" tool.
                          • Added additional parameters into the General tab of the Global Settings as related to moldings.
                          • Added an additional layer for moldings into the Layers tab of the Global Settings.
                          http://design.medeek.com/resources/wallplugin/images/wall_su501_800.jpg
                          http://design.medeek.com/resources/images/wall_blocking_su_menu_active.jpg
                          I will probably need to make a video on this new tool to help clarify its usage.
                          The user has the ability to add their own profiles for the various molding types, so this should make this tool fairly flexible.
                          Also note that the moldings are created independently of the wall panels so the tool can be used with any wall geometry, not just Medeek walls.
                          See model here:
                          3D Warehouse
                          design.medeek.com
                          • medeekM
                            medeek
                            Tutorial 19 - Moldings (21:37 min.)
                            design.medeek.com
                            • medeekM
                              medeek
                              I've had some clients ask me about positioning the cladding material/texture on the cladding group (or face to be more precise).
                              I just noticed that there is actually an API method for this operation:
                              Class: Sketchup::Face
                              Faces in SketchUp are flat, 2-sided polygons with 3 or more sides.
                              SketchUp Ruby API Documentation (ruby.sketchup.com)
                              A vertical offset parameter for the material/texture would come in very useful when walls are stacked in a multi-story scenario and you want the siding or some other cladding to line up across multiple vertically stacked walls.
                              I learn something new everyday.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 2.0.3 - 04.03.2021
                                • Removed all limitations on wall height in the trial version of the plugin.
                                I decided that it was time for this overly draconian measure to go away. I want people to enjoy using my plugins not add to their frustration levels. There is still a 30 day time limit on the trial version, so not all limitations have been removed.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 2.0.3b - 04.03.2021
                                  • Added a vertical offset parameter for cladding materials for rectangular walls.
                                  • Added a vertical offset parameter for "Log" and "Shiplap" cladding materials for rectangular walls.
                                  This parameter will allow the custom vertical positioning of the cladding material/texture so that multi-story structures can be properly rendered.
                                  ****** CAUTION ******
                                  This update adds one new parameters to the rectangular walls and will require the user to delete and recreate any rectangular wall presets. This upgrade does not affect gable wall or any other presets (ie. windows, door, garage, gable wall, shed wall, hip wall).
                                  http://design.medeek.com/resources/wallplugin/images/wall_su503_800.jpg
                                  http://design.medeek.com/resources/wallplugin/images/wall_su502_800.jpg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    View model here for a demonstration of the cladding material (vertical) offset parameter.
                                    3D Warehouse
                                    Note that in this model I've adjusted the offset for both top and bottom walls. I first adjusted the bottom wall cladding so that the first run of siding started at the bottom of the wall as it should. I then adjusted the wall above it to match to the bottom wall. I also turned on the option in the general tab of the global settings which hides the cladding edges, so the two walls appear to blend together.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 2.0.4 - 04.16.2021
                                      • Fixed a bug involving wall presets and the vertical material offset parameter for rectangular walls.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Manual editing of an “assembly” has always been a can of worms for the plugins. The problem really is how does one actually track manual edits? I don’t think you can realistically do this.
                                        When the Wall plugin adds a door or window to a wall it must essentially redraw the entire assembly from scratch in order to recalc the studs, insulation, blocking and a few other things like cutting holes in sheathing and cladding. When you delete an opening the same process occurs.
                                        In a nutshell what I am doing is deleting all of the geometry within the assembly (Group) and then completely redrawing it all. I do have a system in place whereby certain sub-groups can be retained within the main wall group/assembly. This is done by including the keyword “CUSTOM” in the sub-group’s entity name. When you do this any group having this keyword will not be deleted (upon a regen) and will retain it’s geometry, position and any properties and entities it contains.
                                        So additive manual editing (ie. adding specific blocking, hardware etc…) can be accomplished with the plugins as they currently are. This is actually how the Electrical plugin is able to work with the wall, truss, and foundation assemblies. When you regen a wall you will notice that the electrical components/groups within that wall assembly do not disappear (the keyword for electrical components is different than CUSTOM).
                                        You will also notice that if there is any un-grouped edges or faces inserted into a wall assembly those will also be retained by default, no key words necessary. The reason for this is that everything I place into the primary assembly is a group or component, so when I regen I only need to look for those entities (sub-groups) and delete them.
                                        I will need to give manual edits some more thought. There is a possibility that I could employ some sort of comparative type of check that looks at every sub-group created and then compares it to any existing sub-group. The first problem that jumps out at me with this type of system is that it would be very computationally expensive and hence performance would take a hit (who wants a slow and sluggish plugin?).
                                        I’m sure other developers have also given this some thought, but so far I have not found a satisfactory solution that will allow subtractive or modified manual edits within the plugin geometry while maintaining the parametric ability of the plugins.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Some really nice work using the plugins by Carlos Pose (Spain):
                                          Framing ISO:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/d/b/db2211547b97148e9087378034eccd276360f803.jpeg
                                          Renderings:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/8/0/8014a5019918811902f0cc3d55c254be1a3fe520.jpeg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            There seems to be some interest in a "raised" header for windows and doors:
                                            https://aws1.discourse-cdn.com/sketchup/original/3X/4/6/4632066dcc0fad463fe532ebdeff6f8a7588f8ac.jpeg
                                            If there is enough interest it probably wouldn't be that hard to provide another option which allows these openings to be framed in this manner. My only questions are:
                                            1.) What to do with stacked windows or stacked windows and doors?
                                            2.) What if the opening is in a shed or gable wall? How should the raised header be framed, or is it even applicable?
                                            design.medeek.com
                                            • 50
                                            • 51
                                            • 52
                                            • 53
                                            • 54
                                            • 80
                                            • 81
                                            • 52 / 81
