    Increase line size for extrusion
    7 Posts 3 Posters 2.0k Views 3 Watching
    • N Offline
      nikyorke
      Screenshot 2021-01-28 at 18.20.04.pngHi all,
      Does anyone know of a plug in that increase a lines thickness, enabling to extrude?
      For example - see attached
      I draw a free hand line, I would like to then select the line, and give it a required thickness, and then be able to extrude the line.
      Very similar to pipe along path, but with a flat profile.
      Hope I'm making sense.........
      • cottyC Offline
        cotty
        offset and closing the two ends with lines?
        my SketchUp gallery
        • N Offline
          nikyorke
          Thanks Cotty,
          That would work to some extreme, but only offsets one direction.
          I kind of need to offset both directions, ie, original line to remain center.
          Cheers
          • ntxdaveN Offline
            ntxdave
            Exactly what I was thinking cotty!
            Press F1...thank me later
            • cottyC Offline
              cotty
              s4u Offset [$] | SketchUcation
              (sketchucation.com)
              there may be others too...
              my SketchUp gallery
              • N Offline
                nikyorke
                Thanks Cotty,
                That plugin works great. Ive got to do it twice for both sides, but hey ho, works!
                Thank you.
                • cottyC Offline
                  cotty
                  from the description...
                  "Offset both side"
                  Have you watched the video already?
                  my SketchUp gallery
