    [Plugin] FredoTools::CurviShear 1.5a - 25 Aug 11 (ramps)
    67 Posts 41 Posters 177.9k Views 41 Watching
    • U
      urjuan
      Hi Everyone,
      Could someone help me..is this plugin only works for curves? how bout straight ramps with curve edges only?
      Thanks.
      • fredo6F
        Thanks.
        Curvishear only requires that the contour is given as Sketchup 'curves' (as shown in the Entity Info panel).
        Please post a picture or the skp file for what you have in mind.
          mohsen
          How can I create this model? What is the plug?
          • jeff hammondJ
            do you have sketchUp pro? if so, looks like a job for Solid Tools
            make the full sheet using curviloft then slice it up with solid tools
            EDIT--
            mohsenwall.skp
            click pic --> larger view
              Or after the "Make Solid" use the Slicer by TIG 😉
              • E
                Elric00
                There's a SU2015 version?
                • fredo6F
                  Yes, take the latest version of FredoTools and also update LibFredo6 by precaution.
                  All my plugins work from SU6 to SU15.
                    shoaibnot
                    how download curvishear1.5a
                      AMOR1919
                      All of you creators of plugins are bunch of genius. Thank you for all
                        Archimaker
                        CurviShear indirmek istiyorum ama olmuyor. Yardımcı olabilir misiniz?
                        • 4 / 4
