    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
    • fredo6F Offline
      @roxcore said:
      Hello LibFredo6!! Just installed the new versions of animator and the library plugin. I use Vray next to render and i notice that after te first image is rendered Animator doesn't start with the second image. It just keeps counting the seconds even after the render is finished. I also noticed that in the menu, the preset dimensions are gone. I only have the viewport option.
      Could you open the Ruby Console before launching the video generation and check the traces and potential errors.
      Can you also confirm the version of VRay you use. Thanks.
        roxcore
        Hello Fredo! Thank you for answering!! This is what te ruby console showed when opening Animator and starting the generation of the movie:
        RENDERING INIT
        Status natural = {}
        Status thea = :not_supported
        Status ambient_occlusion = :not_supported
        Status sketchFX = :not_supported
        Status twilight = :not_supported
        VRAY4 Init
        Status vray4 = nil
        Status vray = :not_supported
        :beg_time => 0
        :end_time => 90.5
        :frame_rate => 25
        :speed_factor => 1.0
        :reversed_play => nil
        :transparent => false
        :dimX => 1920
        :dimY => 1080
        :dim_mode => "custom"
        :filter => {
        } (:filter)
        :root_dir => "C:/Users/Gebruiker/Desktop/PROJECTEN/CARPENTIER/7. MONTAGEFILM HOUTEN WAND PERGOLA/Animator Videos"
        :movie_dir => "BASIS ANIMATOR 4 - 23-Nov-2020 15-23-52"
        :movie_name => "Film 1"
        :date_modified => 1606130042.267186
        :break_aspect_ratio => true
        :movie_formats => {
        :mp4 => true
        :mov => false
        :img_seq => true
        } (:movie_formats)
        :rendering_method => :vray4
        MOVIE PX = 1920 PY = 1080 transpa = false
        FORMATTED===========================
        VRAY Movie frame 1
        Animation time = 0.00s
        AFTER launching Rendering and Timer: status = true
        VRAY Status check - status = 6
        VRay rendering not finished yet elapsed = 1.99s
        Error: #<NoMethodError: undefined method state' for nil:NilClass> c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:445:in vray_status_check'
        c:/users/gebruiker/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/body_lib6videomanager.rbe:553:in `block in vray4_status_check'
        INTERRUPT true
        VRAY STOP timer =
        VRAY STOP timer =
        My Version of Vray is: V-Ray for SketchUp 4.20.02
        Greetings
        • fredo6F Offline
          NEW RELEASE: LibFredo6 v11.4a - 23 Nov 20
          LibFredo6 11.4a fixes a problem introduced with v11.3a in the support of VRay 4.2 for Animator
            roxcore
            Everything works fine with the update!! Thank you so much!! Greetz
              manoamo
              I'm having a " invalid byte sequence in UTF-8 error "
              I watched your installation video 4 times, Searched about this error for days.
              I found out that this might be a encoding problem, but I have no idea how to solve this problem.
              please help .. Below is error log(?) when I restart SU after Libfredo6 installation.
              Error Loading File Fredo6_!LibFredo6.rb
              Error: #<ArgumentError: invalid byte sequence in UTF-8>
              c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in gsub' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:45:in get_dir_from_ENV'
              c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:425:in su_appdata' c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:443:in dir_appdata'
              c:/users/홍우빈/appdata/roaming/sketchup/sketchup 2020/sketchup/plugins/fredo6_!libfredo6/top_libfredo6.rbe:206:in startup' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:62:in process'
              C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:69:in <module:LibFredo6_Loader>' C:/Users/홍우빈/AppData/Roaming/SketchUp/SketchUp 2020/SketchUp/Plugins/Fredo6_!LibFredo6.rb:30:in <top (required)>'
              • fredo6F Offline
                @manoamo said:
                I'm having a " invalid byte sequence in UTF-8 error " .
                It's definitely related to your Windows user name not in ascii.
                Difficult to fix as there are so many situations.
                If you agree, we could try to troubleshoot together the problem (I would send you some small lines of Ruby to test).
                In the Ruby console, can you type (just copy / paste the statement and Enter)
                ENV["LOCALAPPDATA"].encoding.inspect
                Then tell me what you see as a response
                  manoamo
                  Thank you so much for your kind help! Much appreciated!!
                  #Encoding:CP949
                  This is what I got !
                  • fredo6F Offline
                    #Encoding:CP949
                    Could you now execute the following commands in the Ruby console, one after the other
                    a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8")
                    a.encoding.inspect
                      manoamo
                      #Encoding:CP949
                      C:\Users\￈ᆱ﾿↓ᄎ￳\AppData\Local
                      a.encoding.inspect
                      #Encoding:UTF-8
                      This is what I got
                      • fredo6F Offline
                        #Encoding:CP949
                        a.encoding.inspect
                        #Encoding:UTF-8
                        This is what I got
                        Then, can you try the following commands
                        a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub(/\\/, "/")
                        a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub("\\", "/")
                        and then this command
                        LibFredo6.get_dir_from_ENV "LOCALAPPDATA"
                        • fredo6F Offline
                          NEW RELEASE: LibFredo6 v11.4d - 27 Nov 20
                          LibFredo6 11.4d fixes two issues for Animator (VRay5 rendering of apparation and rotation with variable speed)
                            manoamo
                            #Encoding:CP949
                            a.encoding.inspect
                            #Encoding:UTF-8
                            a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub(/\/, "/")
                            <main>:in gsub' <main>:in <main>'
                            SketchUp:1:in `eval'
                            a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub("\", "/")
                            C:/Users/￈ᆱ﾿↓ᄎ￳/AppData/Local
                            Error: #<NameError: uninitialized constant LibFredo6>
                            <main>:in <main>' SketchUp:1:in eval'
                            I followed every step that you told me!
                            but still same errors occur 😢
                            • fredo6F Offline
                              @manoamo
                              Thank you. Very useful.
                              I think this is a bug in the core ruby engine.
                              I'll see what I can do in order to overcome the problem.
                              • fredo6F Offline
                                @manoamo
                                Could you try
                                ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub(/\\/, "/")
                                  manoamo
                                  I tried the last typing but I failed again
                                  I typed the codes in this sequence
                                  1. ENV["LOCALAPPDATA"].encoding.inspect
                                  2. a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8")
                                  3. a.encoding.inspect
                                  1. a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub(/\/, "/")
                                  2. a = ENV["LOCALAPPDATA"].dup.force_encoding("UTF-8").gsub("\", "/")
                                  3. ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub(/\/, "/")
                                  1. LibFredo6.get_dir_from_ENV "LOCALAPPDATA"
                                  • fredo6F Offline
                                    @manoamo
                                    Could you tell me what is the erroryou get with this statement
                                      manoamo
                                      This is my ruby console
                                      #Encoding:CP949
                                      a.encoding.inspect
                                      #Encoding:UTF-8
                                      C:/Users/■ルヘ↓レᄚ→ᄍネ/AppData/Local
                                      This is what I get after restart
                                      • fredo6F Offline
                                        Ok. Thanks I think we progress.
                                        Can you try this statement (only this one)
                                        File.directory? ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub(/\\/, "/")
                                        if there is an error, can you try this one
                                        File.directory? ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub("\\", "/")
                                        Many thanks
                                          manoamo
                                          Good to hear!
                                          These are what I got back
                                          First,
                                          File.directory? ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub(/\/, "/")
                                          true
                                          Second,
                                          File.directory? ENV["LOCALAPPDATA"].dup.encode("UTF-8").gsub("\", "/")
                                          true
                                          • fredo6F Offline
                                            OK. Thanks.
                                            I will publish a fix and it should hopefully work for you.
                                            • 108
                                            • 109
                                            • 5 / 109
