    [Plugin] GKWare Cabinet Maker
    625 Posts 67 Posters 410.3k Views 68 Watching
      Garry K
      Now you have more control over Blind mortise and tenons.
      Here are 2 examples with and without integrated kicks.
        Garry K
        A new version of CabMaker is now available
        Version 6.0.158 – Jul 1, 2020
        1. Modified Sink cabinet. You can now have side by side drawer fronts without a stretcher.
        A new versin of CutMaster is now available.
        Version 6.0.1.101 Jun 30, 2020
        1. Fixed drawer bottoms for single line routing directionality.
        2. Added pocket screws for drawer bottoms.
        3. Added optional X / Y offsets for routed label positioning.
          LusaMx
          Just installed the latest version. But once I try to run for first time the login dialogbox appears and ask for "hardware". If i use the ID and password registered at website but "hardware" field blamk. Sketchup freezes and the only way to starover is ctl+alt+del and kill the process.
          Why?
          Regards
            Garry K
            I am currently helping him via email.
            • utilerU Offline
              utiler
              Good morning Garry, is there a way to change the door arc radius? I note that its set to 120 degrees as standard but I'd like to set it to 85-90 degrees.
              Can't seem to find it anywhere in the manual.
              Cheers,
              purpose/expression/purpose/....
                Garry K
                Try this
                • utilerU Offline
                  utiler
                  Seriously, I need glasses... Thank you Garry. 😳
                    marcinek12
                    I got problem with plugin gkware cabinet maker v6
                    Window come up with Registration
                    User id i got it
                    What password i need to tape in
                    I need to registered somwhere?
                    Thank you
                      Garry K
                      First create an account on my website
                      https://cabmaker32.com/login/
                      Use those credentials with any of my plugins.
                      Garry
                      • ajharlanA Offline
                        ajharlan
                        I am scratching my head to try and figure this one out. I've tried multiple permutations of settings but cannot seem to get past this error. Any help appreciated.
                        "Drawer System Error: Height < = 0"
                          Garry K
                          Contact me via Skype
                          My Skype handle is:
                          gkernan@telus.net
                            srimadiraju
                            Hello Gary,
                            Can i use cabmaker v6 & Cutmaster for modular furniture (kitchens&wardrobes) cutlist purpose to produce cut sizes, edge banding details, holes for mini fixes & groves to work on machines?
                            Iam planning to purchase if it works for me.....
                            Awaiting for your reply
                            Thaks & Regards
                            Sri
                              Garry K
                              Yes it should - I can talk to you over Skype.
                              My Skype handle is:
                              gkernan@telus.net
                                Antonis777
                                After i click this the user id window disappears and Sketchup freezes as if it was somewhere a hidden window or task and needed to be closed first. I can't even close Sketchup I do it from task manager
                                  Garry K
                                  Please email me from my website and provide me with your userid
                                    shaunperkins
                                    hi
                                    im trying to make several cabinets that are tall open shelf cabinets (ends,tops, bottoms and backs) out of door material, so i can get it to come up as components on m export,
                                    is this at all possible?
                                      Garry K
                                      CabMaker allows you to add finished panels to sides and back.
                                      You can configure the cabinet to have no bottom and then add another cabinet with depth of 0 so that you can have another door set up as a bottom. When you edit the main cabinet the new bottom door cabinet will NOT be edited - you will have to edit the bottom door (cabinet) indpendently.
                                        mitch8628
                                        Hello Garry,
                                        I submitted a purchase for CabMaker Build I think 2 days ago, and emailed you my user name. Just checking to see what to expect for time frame for getting the plugin active with my user name.
                                        Mitch
                                          mitch8628
                                          Thanks to Garry for getting back to me quickly through email! Looking forward to diving deeper into the plug-in for our kitchen design!
                                          • N Offline
                                            NancyL
                                            I've really enjoyed working with cabmaker and cutmaster and I'm getting close to wanting to take my DFX files to the local CNC place.
                                            I'm hung up on the drawer and hinge systems and how to set them up in the two programs. It seems there are a few demo ones set up in the DB, but not what I want to use. further I'm not finding any useful information about adding the data for the system I DO want to use in either help file.
                                            Has anyone else sorted out how to add a new drawer slide system? I'm specifically interested in the BLUM Tandem full slides.
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 30 / 32
