    Converting a 3D surface (stl mesh) into a 3D SketchUp object
    3 Posts 3 Posters 2.7k Views 3 Watching
      mbernard
      Good morning all,
      I have an STL file that represents a 3D surface (without thickness). It is a mesh based on triangles (Over 600,000).
      This surface should have a flat base of a certain thickness with opaque faces on the sides in order to present the appearance of a solid object without hole.
      I want to be able to use this surface in SketchUp 2019 software to apply a wood texture.
      Please tell me the different operations to be performed to achieve this result.
      Regards,
      Marc
      See file in attach.
        Plugin Import Export STL by Didier Bur! πŸ˜‰
        • N
          nlipovac
          I use Ultimate Unwrap 3D to open them and export them to SU. I use it for UV unwrapping and this part is a plus for me, also you could use Blender to open ti and export it to obj.
