    Medeek Electrical
    206 Posts 6 Posters 278.2k Views 5 Watching
    • medeekM
      medeek
      To be perfectly honest I didn't think this plugin would be widely used or adopted, kind of niche thing for a few electrical contractors or guys like myself who like to show a lot of details in their models. I actually got the initial idea from reading through John Brock's book and I really liked how he was placing electrical components into his models. It seemed like too much work to have to place pre-made components into the model at the right depth into the walls and also the height, hence the plugin was born, which automatically sorted out these details for you.
      As with my other plugins as I have continued to develop them they have garnered more interest and I've tried to make them more flexible to accommodate more users and standards. I'm currently working to release the British Standard upgrade which will include some typical UK outlets and switches (and boxes). However, a lot more remains to be done to truly make this flexible enough for a worldwide audience.
      Keep sending in the feedback, it ultimately helps me fine tune this plugin to better meet the needs of you the user.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        Surface mounted MK Logic Plus switches:
        https://aws1.discourse-cdn.com/sketchup/original/3X/4/5/45054cec1dad75cd3cb73d048c109a8ac4d22772.jpeg
        design.medeek.com
        • medeekM
          medeek
          Version 1.1.7 - 08.13.2020
          • Created the Medeek Electrical UK (British Standard) toolbar, with two additional functions/tools: Draw Switch, Draw Outlet.
          • Enabled the Draw Switch (UK) tool with the following switch types (MK Logic Plus): single pole, dimmer, blank.
          http://design.medeek.com/resources/images/electrical_uk_su_menu_active.jpg
          design.medeek.com
          • medeekM
            medeek
            Since I am using manufacturer's part numbers to specify the switch and box with the new UK module I thought it made sense to provide a thumbnail to aid in the selection process:
            https://aws1.discourse-cdn.com/sketchup/original/3X/f/8/f85039920b69d103d0dbf6a3a5cd38dd2061fb43.gif
            design.medeek.com
            • medeekM
              medeek
              Version 1.1.7b - 08.13.2020
              • Added preview thumbnails to the draw and edit menus of the UK switch tool.
              http://design.medeek.com/resources/electricalplugin/images/elec_su203_800.jpg
              design.medeek.com
              • medeekM
                medeek
                After some further digging about on the internet I really only came upon three or four reference documents for UK outlet symbols. Based on those examples here are my proposed symbols:
                https://aws1.discourse-cdn.com/sketchup/original/3X/c/5/c559bacc35d3d4db1d66843efce6e40c258bc51f.jpeg
                Please provide feedback or suggestions.
                I planning on using the abbreviation "SW" for switched since I am trying to keep the length of the text in the legend to a manageable length, or I could spell it out in full.
                There will probably be other outlet types (ie. fused outlets or connector outlets), but this is all I have for now.
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.1.8 - 08.15.2020
                  • Enabled the Draw Outlet (UK) tool with the following outlets types (MK Logic Plus): unswitched, switched, switched w/ USB, weatherproof, blank.
                  • Added preview thumbnails to the draw and edit menus of the UK outlet tool.
                  • Added UK outlet (2D) symbols to the Legend tool.
                  http://design.medeek.com/resources/electricalplugin/images/elec_su205_800.jpg
                  http://design.medeek.com/resources/electricalplugin/images/elec_su206_800.jpg
                  http://design.medeek.com/resources/electricalplugin/images/elec_su204_800.jpg
                  design.medeek.com
                  • medeekM
                    medeek
                    Editing a UK outlet:
                    https://aws1.discourse-cdn.com/sketchup/original/3X/2/e/2e6a5760d97bcfb14c24757805e83e8f4350574a.gif
                    design.medeek.com
                    • jujuJ
                      juju
                      As opposed to choosing the outlet by a code (and having the visual reference appear then), can we do the search for the outlet module by scrolling through a visual reference as well?
                      • medeekM
                        medeek
                        Tutorial 4: UK Toolbar
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.1.9 - 09.10.2020
                          • Added optional metadata parameters for outlets: description, circuit.
                          design.medeek.com
                          • medeekM
                            medeek
                            Custom Wiring Feature:
                            I've been getting some requests for the ability to add in wiring.
                            After giving this some additional thought I think I can add in a rudimentary wiring module that will allow the user to create their own wire types. The basic parameters would be:
                            1.) Name: NM-B_14/3, NM-B_8/3 etc...
                            2.) Shape: RND or RECT
                            3.) Dia.
                            4.) Width
                            5.) Depth
                            6.) Color
                            7.) Bend Radius
                            https://aws1.discourse-cdn.com/sketchup/original/3X/6/8/6864bd21ed4046fbf7f0e740a413640beee5b2c3.jpeg
                            design.medeek.com
                            • medeekM
                              medeek
                              The second toolbar will include a new icon for wiring:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/b/f/bfac9af4e4997565c4f2f13dd2289fdd944aca52.jpeg
                              Additionally the wiring assemblies will not be embedded into any other assemblies (ie. wall, roof, floor etc...), this way they can be edited and regenerated. I will have two context menu items for wiring assemblies: edit and regen.
                              design.medeek.com
                              • medeekM
                                medeek
                                The bend radius is the parameter that is the most unique feature of this tool. One could easily use a tool like profile builder to generate the wiring but with the bend radius the tool will introduce another level of complexity.
                                In some cases the line segment(s) will be too short to allow for the bend to occur, in these cases the radius will not be applied, the segments will simply be followed as is.
                                The wire types can be configured in the global settings of the plugin.
                                design.medeek.com
                                • medeekM
                                  medeek
                                  First look at the Custom Wire Library tab in the global settings:
                                  https://aws1.discourse-cdn.com/sketchup/original/3X/d/2/d2accdf34374e9f603f1a8387ed963c54da58bb6.jpeg
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.2.0 - 10.11.2020
                                    • Added a "Refresh Licensee Data" button within the License tab of the Global Settings.
                                    http://design.medeek.com/resources/electricalplugin/images/elec_su209_800.jpg
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Version 1.2.1 - 10.14.2020
                                      • Added a Custom Wire Library to the Global Settings which allows user defined rectangular or circular cross section wires/cables/conduit.
                                      • Enabled the Wiring Tool with three additional context menu functions: Edit Wire Assembly, Regen Wire Assembly, Edit Wire Path.
                                      • Added a 4th dimensioning layer specifically for wire callouts in the Layers tab of the Global Settings.
                                      • Added the following parameters to the General tab of the Global Settings: Wire Label Callout, Wire Label Prefix, Circle Segments.
                                      http://design.medeek.com/resources/electricalplugin/images/elec_su210_800.jpg
                                      http://design.medeek.com/resources/electricalplugin/images/elec_su211_800.jpg
                                      I think I need a few additional tools to round out this wiring module and make it more intuitive and efficient to use:
                                      • Move Segment Tool (rather than having to edit the wire path directly)
                                      • Integrate the Estimating tool with the wiring statistics
                                      design.medeek.com
                                      • pbacotP
                                        Quite impressive, though it didn't occur to me someone would model house wiring. Gotta be more fun than actually running it though.
                                        • medeekM
                                          medeek
                                          Note that the wire callout gives the name of the wire, the type and the length.
                                          I would tend to agree with Pbacot, I didn't think people would want to go to the trouble of modeling wires but I've received enough features for this request that I decided I should include it as part of the plugin.
                                          For round wires I have the "circle segment" parameter which allows ones to decrease the number of segments in order to keep the polycount down in the model.
                                          The draw tool needs a feature or switch which allows one to simply select a pre-drawn polyline (of edges) rather than picking points.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            Version 1.2.1b - 10.15.2020
                                            • Draw Wire Tool input extended to two options: Points, Edges
                                            Tutorial 5 - Wiring (11:15 min.)
                                            design.medeek.com
                                            • 11
                                            • 8 / 11
