    Quad Faces Does Not Appear
    7 Posts 3 Posters 5.0k Views 3 Watching
      SketchUcation Kid
      hi everybody!
      I have Quad Faces plugin already installed on my SketchUp 2015 but it does not appear on the screen. It is not available in the menu Tools, nor in any other menu, although it is activated at Windows/Preferences/Extensions.
      how can I have this tool available for use?
      thanks in advance.
        Did you open its Toolbar ?
        Its menu entry is in the Tools menu ??
          SketchUcation Kid
          before I write this post, nothing about Quad Face appeared in the Tools menu. then, I installed the TT_Lib² plugin and now there is a Quad Face option in the Tools menu with lots of options but I still can't open Quad Face toolbar. all I want is to fill a 3D face. I have only the edge lines and want to fill it with faces.
          thanks TIG.
            Most of thomthom's Extensions require you to have installed his TT_Lib²...
            As you've now found out.
            How are you trying to open its Toolbar ?
            A right-click over the top or left toolbar docking area should produce a drop-down list that includes it...
            Alternatively View > Toolbars... opens a dialog that lets you choose it...
              SketchUcation Kid
              TT_Lib² is marked on the System Preferences/Extensions settings. TT_Lib² folder exists in C:\Users\MY_USER\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins address. what's wrong so? what can I do different? would you have any suggestion?
              thanks again.
                qfaces.jpgWorking without problem (2015 make) 😄
                Maybe mine is an old version...
                Here my files who are in "C:\Users\user\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins..."
                quads face.zip
                  SketchUcation Kid
                  @pilou said:
                  [attachment=1:1xxfgg4z]<!-- ia1 -->qfaces.jpg<!-- ia1 -->[/attachment:1xxfgg4z]Working without problem (2015 make) 😄
                  hi pilou. my QuadFaces is working fine. 😄 I thank you all for the help. you helped me a lot!
