    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      Tutorial 13 - Stretch Wall Tool (7:41 min.)
      The audio is a little strange in this video, not sure why, I will check the audio out in more detail for future videos.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.4.7 - 06.02.2020
        • Enabled the "Wall Join" tool within the Medeek Wall Tools toolbar.
        Note, that to join two walls they must be colinear and their START and END points must be coincidental.
        design.medeek.com
        • medeekM Offline
          medeek
          Tutorial 14 - Join Wall Tool (5:54 min.)
          design.medeek.com
          • medeekM Offline
            medeek
            Updated todo list (as of June 3, 2020):
            1.) Gable and Shed Walls
            2.) Move the Estimating module to the new Medeek Project extension, and further develop this module as it relates to the wall plugin.
            3.) Complete the Wall Join tool.
            4.) Convert the Window, Door and Garage Door Draw menus to HTML.
            5.) Move the Fixtures module to a the new Medeek Interior extension.
            6.) Compete the standalone columns/post tool.
            6b) Classical columns for the post tool.
            7.) Start work on the integrated Medeek Engineering extension, start with window and door headers for vertical loads.
            8.) A generic Blocking module.
            9.) Transom windows above doors with and without sidelites.
            10.) Shear Wall module which will ultimately integrate with the engineering plugin.
            11.) Complete the Wall Stretch tool.
            12.) Additional door and window types as requested (eg. bi-fold, sliding glass, double and triple single hung windows).
            13.) Spend some time on the new tabs in the global settings, currently showing an Under Construction sign.
            14.) Presets for Windows, Door and Garage Doors
            15.) Making the Window and Door modules work with generic walls, not just Medeek walls.
            16.) Multi-layer gypsum
            17.) Stair module permutations: U, L, T etc…
            18.) Further “idiot” proofing of the plugins: (zero value, nil values, checking for impossible geometry, etc…)
            19.) Wall Justification
            20.) Interior trim added to Medeek Interior extension.
            Highlighted items have been recently completed.
            This list does not include many other minor feature additions and bugs fixes, more details can be found here:
            Medeek Design Inc. - Medeek Wall Plugin Changelog
            (design.medeek.com)
            So far this year (2020) I’ve made 30 major revision upgrades to the plugin. Last year was only about half this amount as most of my attention was focused on upgrades to the Foundation plugin, the release of the new Electrical plugin and a concentrated effort on the complex roof module towards the end of 2019.
            Always onward and upward.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.4.8 - 06.05.2020
              • Added Quoins as an option for exterior walls.
              http://design.medeek.com/resources/wallplugin/images/wall_su360_800.jpg
              *** Warning ***
              This update is backward compatible with walls drawn in previous versions of the plugin however if you download this version you will be required to recreate any wall presets that you have previously defined.
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              design.medeek.com
              • medeekM Offline
                medeek
                Looks like the algorithm is working correctly even with non-orthogonal walls:
                https://aws1.discourse-cdn.com/sketchup/original/3X/2/8/284da57333c233d66e27740d65528649176159eb.jpeg
                View model here:
                3D Warehouse
                design.medeek.com
                • medeekM Offline
                  medeek
                  Tutorial 15 - Quoins (8:34 min.)
                  View model here:
                  3D Warehouse
                  The feature is probably not as commonly used in most residential construction however it was an easy add and it has been requested enough times to warrant its inclusion.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.4.9 - 06.11.2020
                    • Converted the "Draw Garage Door" menu to HTML.
                    http://design.medeek.com/resources/wallplugin/images/wall_su362_800.jpg
                    At first glance this may seem like a minor update, but in fact it is was quite a major undertaking. I rewrote a good portion of the Garage module so that both the Draw and Edit menus are fully HTML. I also tracked down some long standing bugs with regards to the jamb depth calculation (garage door installation).
                    This is part of the larger project to migrate all of the draw menus to HTML. I figured I would start with the garage door module since it is used less than the window and door modules and somewhat less critical. I've tested the update extensively (both metric and imperial) and it all appears to shake out. If things look good after a few more days I will proceed to update the other two modules.
                    The HTML draw menu is a significant improvement over the previous legacy menu system.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      ***** Father's Day Sale*****
                      In appreciation for all of the hard working fathers (and mothers) out there, and especially during these unprecedented times, I will be offering a renewal promotion on all of the plugins for the next three days (June 12, 13 and 14).
                      The regular license renewal prices are given below:
                      License Renewals:
                      Medeek Truss - $60.00 USD
                      Medeek Wall - $60.00 USD
                      Medeek Foundation - $40.00 USD
                      Medeek Electrical - $25.00 USD
                      The promotional renewal prices are given below:
                      Medeek Truss - $15.00 USD
                      Medeek Wall - $15.00 USD
                      Medeek Foundation - $10.00 USD
                      Medeek Electrical - $5.00 USD
                      This is a very steep discount in hopes of getting as many users to upgrade to the latest versions of the plugins as possible. In the last year, the updates to the plugins have been quite significant. I would very much like to see everyone taking advantage of these updates and feature additions that I have worked very hard to create.
                      These promotional prices will take affect June. 12, 2020 and end June. 14, 2020. All renewals, prior and after this time frame, will be at the regular prices.
                      Please note that if you have recently purchased a plugin(s), you can still take advantage of this renewal offer. Renewing your license while it is still active adds an additional year to the license expiration date.
                      Thank-you for your continued support.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.5.0 - 06.15.2020
                        • Converted the "Draw Window" menu to HTML.
                        http://design.medeek.com/resources/wallplugin/images/wall_su363_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.5.1 - 06.18.2020
                          • Converted the "Draw Door" menu to HTML.
                          • Fixed a bug with arched door sidelites.
                          http://design.medeek.com/resources/wallplugin/images/wall_su364_800.jpg
                          Not a glamorous update, but certainly a critical one. The three most important draw menus are now switched to full HTML.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.5.2 - 06.21.2020
                            • Added the ability to create, load and delete window presets within the Edit and Draw (HTML) Menus.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.5.3 - 06.22.2020
                              • Added the ability to create, load and delete door presets within the Edit and Draw (HTML) Menus.
                              http://design.medeek.com/resources/wallplugin/images/wall_su365_800.jpg
                              design.medeek.com
                              • jujuJ Offline
                                juju
                                Any chance that updates / newer versions could be limited to once every fortnight, unless it fixes a mission critical flaw / error / issue?
                                • medeekM Offline
                                  medeek
                                  The frequency of updates will probably decrease now that the plugin is maturing. I will also be moving my attention to the new Floor plugin in a few weeks.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    When you first click the gable wall tool you will be presented with the following gable wall matrix:
                                    https://aws1.discourse-cdn.com/sketchup/original/3X/1/a/1a93e1702f0505ccea87e546778df491c75d3be9.jpeg
                                    As you can see from the shading all wall types except for the "Gable" type have been grayed out. Initially I will make only this wall type available, then the "Shed" will be the next type I proceed to develop. The rectangular, gable and shed walls constitute the vast majority of wall geometries used in most construction however you can see there are quite a few other possibilities, so many in fact, that I quickly ran out of descriptive names to assign them.
                                    Compared with a standard rectangular wall a gable wall with have the following additional parameters:
                                    • Wall Height Left
                                    • Wall Height Right
                                    • Wall Pitch Left
                                    • Wall Pitch Right
                                    These four parameters will drive the location of the wall peak. In most situations the left and right values will be the same resulting in a symmetric gable wall however any combination of dissimilar pitches and wall heights will be possible which will then yield an asymmetric gable wall.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      The wireframe preview will look like this:
                                      https://aws1.discourse-cdn.com/sketchup/original/3X/c/a/ca76d723d8aed6bf7cda5c0d0c315be9b6d31838.jpeg
                                      In this case we have a symmetric gable wall.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        An asymmetric gable wall:
                                        (click image to view animation)
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          I'm going to have to dumb down some of the more general features/parameters found with rectangular walls as they apply to gable walls. For example with rectangular walls you can have walls connected at non-orthogonal corners. For gable walls this becomes very complicated and eventually I will probably allow it however for now I think it would be best to limit gable walls to ONLY orthogonal connections at the corners. If I don't do this it will be another 6 months of programming before I ever complete the gable wall module.
                                          As I was testing asymmetric gable walls earlier today it became apparent that the intersection at the peak is a little more interesting with the asymmetric case. Also I will probably make the double studs positioned at the peak an optional setting in the global settings.
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/d/9/d9211e9a193ca8581e45bd0dae7e7e12e542622a.jpeg
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Notice how the door falls beneath the gable wall peak:
                                            https://aws1.discourse-cdn.com/sketchup/original/3X/b/f/bfc5ff718508de782d6857f05d3811b7e1ee2eea.jpeg
                                            In this situation the symbol or outline for the opening must be broken into two faces as shown.
                                            There are a lot of little details like this that further complicate things having to do with gable walls, finding them all is a slow and meticulous process.
                                            design.medeek.com
                                            • 70
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 76
                                            • 72 / 76
