β οΈ Libfredo 15.4b | Minor release with bugfixes and improvements Update
Cast Iron Crank Wheel
Very nice Dave.
Primo Dave.... and don't soft sell yourself your mechanical bits are very cool
Thank you both. I appreciate it.
Nice!
These 'mechanical bits' are very cool and very well done.
Good start for an early farm implement.
Could be Jim. At least if the wheel was smaller. The one I modeled is 32 in. in diameter and 6 in. thick. It would weight nearly 745 pounds not including the crank pin. Maybe that's more than the mower weighs.
At that size and weight I would take a guess that it is the flywheel for an oil or maybe hot air engine? Nice technical execution as always!
Probably from a steam engine.
Thank you.
