    Extension to make a snail or snake for underfloor heating
    extensions
    8 Posts 5 Posters 5.6k Views 5 Watching
    • C
      cariothida
      Hi all! Maybe you know the extension that will help me make snails for underfloor heating pipes layout. JI want to just select a face and extension will draw a snail
      https://ibb.co/L5d5txs
      • T
        TBoy
        Not a magical-click plugin but take a look here:
        https://sketchucation.com/forums/viewtopic.php?f=18&t=70478&start=30#p643338
        • HornOxxH
          HornOxx
          πŸ‘ πŸ˜„ πŸ‘ Great - these Box-Things are just great πŸ‘
          never trust a skinny cook
            So πŸ˜‰ Exactly that i said! πŸ˜„
              Excellent the "double True Bend" ! β˜€
              Else i believe that you can make something with an helix then Use Fredo Tools for un smooth it...
              That was that! Here with the Thomthom edge tools πŸ˜„
              The helix is downloaded from 3Dwarehouse directly from SketchUp! πŸ€“
              Free to you to try better coefficient Cut unwanted and Flat the result if needing πŸ˜„
              • C
                cariothida
                How to use the offset tool to make several copies like here?
                https://i.imgur.com/Hieau17.gif
                • BoxB
                  Many tools in sketchup will repeat the last action by using a double click.
                  • C
                    cariothida
