    Extinction of geometry
    4 Posts 3 Posters 1.1k Views 3 Watching
    • ipsketchpiI
      ipsketchpi
      How to avoid this, when zooming in for a closer view.
      Thank you in advance.
      /IP
      • jujuJ
        juju
        This is a clipping thing with SketchUp. Has been there since forever without a fix in sight by the SketchUp devs.
        There is an extension that has a workaround (only for Windows machines, if I recall correctly), http://www.clippingplane.com - note that it is not free, but works well.
        There are a few other things you can do to minimize the chances of it occurring, it's been covered quite a bit so perhaps do a search for "clipping" or "clipping plane".
        • pbacotP
          One thing you can do is not use Parallel Projection for modeling and navigating. It helps some but you can still get clipping on close-ups or if the model is large in area.
          • ipsketchpiI
            ipsketchpi
            Clipping plane extension does not resolve the problem, (bought it) which has actually become a problem just recently with the 2020 SKP update. I mean, yes this has always been in SKP, but recently it's absolutely impossible to work, I have no idea what has happened.... 😞
            Could it be anyhow problems with personal templates or file settings...? I have noticed that some files work better when I copy and paste them into the older templates I used before.
            p.s.
            it's clear for me that itis something in the SKP templates I used. Since I have restored some older ones and use them, it's +/- "fine" again.... ❗ ❓ but still very disturbing..
            /IP
