    [Plugin] [$] S4u_Panel
    25 Posts 12 Posters 15.2k Views 12 Watching
    • F Offline
      feodos
      ok, thanks
        goga63
        when you download the new version error
        Error Loading File C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_code.rb
        Error; #<SyntaxError; C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_code.rb;665; syntax error, unexpected keyword_end, expecting end-of-input>
        C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;9;in `require'
        C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;9;in `<module;S4u_panel>'
        C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;5;in `<module;S4U>'
        C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel/s4u_panel_menu.rb;3;in `<top (required)>'
        C;/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb;197;in `require'
        C;/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb;197;in `load'
        C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;16;in `register_extension'
        C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;16;in `<module;S4u_panel>'
        C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;4;in `<module;S4U>'
        C;/Users/JssI/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/s4u_panel.rb;3;in `<top (required)>'
        • hdpvH Offline
          hdpv
          Run as Administrator Sketchup
          install plugin and restart.
          I don't know this error.
          Suforyou
          http://www.sketchupforyou.com
            goga63
            thanks, it works now.
            • designerbursaD Offline
              designerbursa
              s4u please part list an cutting nesting
              Than you
              • hdpvH Offline
                hdpv
                i don't understand!
                Suforyou
                  greatoe
                  the TAB key for Front-Middle-Back never work on a Mac
                  • hdpvH Offline
                    hdpv
                    Did you update the new version?
                    What is your system?
                    Suforyou
                      AISmebel
                      Hey. I want to clarify with you if the plugin is being updated if I bought it on extensions.sketchup.com? The fact is that my version is v1.3, but v1.4.8 is listed on sketchucation.com.
                      What do I need to do to upgrade to v1.4.8?
                      I have one more question for you. Is it possible to remove the sticking of the cursor to 1/3? I do not need this function and it really bothers me.
                      • hdpvH Offline
                        hdpv
                        I will update it soon.
                        Suforyou
                          AISmebel
                          Thank. I will wait.
                            AISmebel
                            Dear developers, when users can see the updated version of the plugin on extensions.sketchup.com ???
                              AISmebel
                              Hey. I recently bought the s4u-Panel plugin from you, I really like it. I use it very often. Thanks for such a wonderful plugin. I have a good suggestion for improving it: you need to enter several cells into which you can enter different thicknesses of the material, and which can be assigned to different hot keys !!! For example: To use material with a thickness of 3 mm, 10 mm, 15 mm, 16 mm, 19 mm. Each time, changing the thickness using the settings menu is very inconvenient.
                              I hope you enjoy my idea. Sorry for my English, I use a translator πŸ˜„))
                              • 2 / 2
