Over Engineering for My Shop
perfect work(s)
and how cool are your reports with the sailboats (which is my only term for all these types
) - for one who lives in the middle of the continent, away from any coasts this is so very exotic !! -
Thank you HornOxx. The baby cradle is a Pram that I designed for my son. He just turned 16 last Saturday.
Great model and pictures. I love that gaff rig.
Thank you Peter.
... wunderbar, respect !!! (and a little bit of envy when it comes to sailing
You could still build a boat and take it to some water to sail. The building process is a good learning experience.
The way having shingles is a good medical experience?
Boats have too many curves for me. -
LOL!
Boats teach you how to deal with things when you have no square corners.
as you can already guess - I am not a woodworker.
Can you buy a wood-shape-bender (a real one analog with plug) in a specialized shop?I'm just kidding here - as someone who can't even glue together any airfix model flawless I bow to this craftsmanship! - in addition a craftsmanship with which you can send your own son onto/into(?) the deep water without any stomach rumbling...
@hornoxx said:
as you can already guess - I am not a woodworker.Maybe you start a new hobby.
I expect you can buy a steam box although most people who steam bend wood would probably make their own. You can buy big clamps to use for clamping wood to forms. In the case of the two boats I show, the bending didn't really require anything special. The sailboat has a plywood hull. The bottom (12mm thick) was screwed down to the keep to create its bend. The deck is suspended at the ends with some intermediate bulkheads and then the sides were screwed to the edges of the deck and bottom creating their curves.
The small boat was built by bending the wood over a form. The planks on the small boat are only about 2.5 to 3 mm thick.
Thank you very much. I think anyone could do this stuff if they just put their mind to it. When I was building the sailboat I had a number of people ask me, "How do you know how to build a sailboat?" The answer was that I didn't know how to build a sailboat but I knew how to do the next step in the process and could follow the directions.
Dave's undoubtedly correct that (most) pros build their own steam-bending set-up, but Rockler does sell this kit (along with plans for the box itself) for hobbyists:
Rockler Steam Bending Kit w/FREE Steam Box Plan, Hinges and Latch
All the hardware and fittings you need to bend wood to your will, including a steamer and a plan for building your own box.
https://www.rockler.com/ (www.rockler.com)
