    Asset editor opening off screen - reset position on launch
    renderpluginsextensions
    3 Posts 1 Posters 5.7k Views 1 Watching
      monkers
      Hi Guys, I recently updated my vray to 42002 for sketchup. I am having a strange issue where I can't find the asset editor. All the other vray settings seem to be working fine as I can render etc. I have uninstalled both SU 18/19 and vray then done a clean install of SU18/19 and vray.
      Is there a way to reset window position on load to 0,0 or something? I remember there was a config file to do so in 3DS but I can't find the same in SU.
      This is super frustrating. Id had issues with the file version on the previous versions so can't roll back.
      Is there a way to make the asset editor "windowed" rather than floating so I can use the "win+arrow" in the future.
        monkers
        Also Just as a side note, Going to preferences > workspace > reset workspace doesn't work, which makes me question is the asset editor even opening up?
          monkers
          After a day of messing about I found the problem, I'll give an update just in case it helps anyone.
          My security and software I use to manage all my workplace machines has an auto container feature - so if it doesnt trust software one of my staff is running it will run it in a container to stop it infecting anything. Turns out it didn't like this version of Vray. It usually opens windows with a green boarder around them to signify its doing it. There must be some glitch with SU opening up in a floating window which means it just wont open.
