    Library of Babel
    15 Posts 5 Posters 3.1k Views 5 Watching
      shawb
      An attempt at Jorge Luis Borges's universe metaphor 'The Library of Babel'. I did try and render this but the file becomes very large, very quickly even using Fog.
        chedda
        Wow awesome model ! This deserves a render surely ?
        Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
          Make one in the time πŸ˜„
          http://piloumaison.weebly.com/uploads/3/6/2/0/3620514/4775391_orig.jpg
            shawb
            Thank you for the comments guys. I did try some renders but it just choked my machine. The SU file size with just plain colours for textures is not huge by any means. Each gallery is a component and by itself is a relatively simple room. The slowdown comes when copying the gallery sufficiently to give the impression of infinity and then adding enough lighting. There was always some empty space in view that required another set of galleries to fill it! With realistic textures my system would not even allow shadows to be toggled on without freezing.
            Somehow I always end up with very complex models - even if I try something simple! My admiration goes to Chedda, his recent Marienplatz and Midnight Maze convey so much with none of the clutter that I seem to have.
            • HornOxxH Offline
              HornOxx
              I agree with Chedda πŸ˜„ πŸ‘
              never trust a skinny cook
                chedda
                Perhaps your limitation is sketchup itself ? You might consider using proxies for each element or even making the entire floor a component proxy. You could then achieve your infinite look. However i think fixing your camera view to be more sympathetic to your model is a much easier route. If you want the depth then put a bend or a foyer/lobby as the target instead. Or if you insist on this infinity view use a mirror or a water feature to create an illusion πŸ˜‰ I have attached a few of my staircase images i also am currently working on a new one πŸ˜‰
                  shawb
                  Thanks chedda, I think I understand what you are suggesting. The limitation is my PC in that it doesn't have the processing power needed for this type of model. To stick with Borges's description of the Library each gallery has to be exactly the same as all the others. To show this idea each view must indicate that wherever you look everything is identical. So the infinity thing is an essential component otherwise it is just a room with some bookcases! I will try and explore your idea of using proxies and see if that lightens the load. Also, using a mirror(s) might work so will give that a try as well. Thank you again for the input!
                    shawb
                    Couldn't resist posting this rough and ready render using chedda's mirror idea. Only one gallery component is used in this view along with opposing mirrors. To infinity and beyond?
                      chedda
                      Excellent so the mirror worked. Did you use 2 one in each doorway ? I think the mirror would also work vertically in the void too. The geometry of the view looks fine its just the inconsistent lighting thats a clue because of the mirrors. I wonder if your software would allow you to hide these mirror objects from shadows etc or even render the reflections to s different channel and then compose them in photoshop.
                        shawb
                        Yes, one mirror in each doorway. The scene still needs a gallery positioned above and below the one shown. The gallery component is open at the top and bottom so daylight is getting in at the moment. The lighting and textures now need a lot of work, I just had to rush out a fast render to see if it would work with the mirrors and report back! Going to try the mirrors vertically today.
                          Looking good!
                            shawb
                            Cheers Bryan, as usual things conspire to get in the way of modelling time so haven't done much more. I did, however, try the mirror effect in the vertical direction. It works the same but as the view looking up is different to that looking down, the combined mirror image shows both - so up and down appear in the same image. If that makes sense!
                              shawb
                              Going to leave this one here as I've reached a bit of a dead end with it! Time to move on to something else.
                                Dead end? If you say so, but that looks great!
                                  shawb
                                  Thank you for your kind words Bryan. I really wanted to illustrate the premise of the infinite Library. Borges's description is loose enough to allow a broad interpretation. However, the very real limitation is that I wasn't able to create a model that could do it (the Library) justice. I'm quite happy with the render that I did complete but the requirement for more and more gallery modules to be in view to give the infinity impression just slowed the model and render process exponentially. This is despite using Chedda's excellent mirror suggestion. What you see in the final render is really the limit of what can be shown in any one view. Anything more always seems to reveal a space at the end of the reflected views that needed another gallery to fill it! And so on....
                                  So, not a dead end but more of a limit reached perhaps. It was a very enjoyable learning experience and not at all wasted. Not sure what I will try next but likely there will always be the false starts and trail of unfinished models!
