    Exploded View
    12 Posts 5 Posters 2.0k Views 5 Watching
      You give up your favorite render(s) ?
        Not yet.
        • G
          Glenn at home
          Very nice Dave. Are the dashed lines done in post production (photoshop)?
            Thank you sir. The dashed lines were created in SketchUp and an image export was laid over the rendered image in the image editor.
            • G
              Glenn at home
              Ah, clever solution sir πŸ˜‰
                Thank you. It's actually quite simple and quick to do. In this case, because I wanted the dashed lines to be white due to the dark background, I inverted the colors in the image (only black and white for this) and then set the layer blend mode to Additive. Most often when I want to use linework from SU with a render the line work image has a white background and I use Multiply for the blend mode.
                • Bryan KB
                  Very nice!
                  • ntxdaveN
                    ntxdave
                    DaveR, Could you also use the dashed line tool in TIG's 2D Tools and set the color to white which would save some steps (maybe). Just a thought.......
                    Press F1...thank me later
                      I suppose you could do that however I don't know that the rendered 2D faces would look that good. It's really such a simple thing to combine images that it is easy enough to do what I do. And if I don't want to show certain lines, I can deal with them more easily that trying to paint something out in a rendered image.
                      • ntxdaveN
                        ntxdave
                        Understand, as I aid, just a thought. I have used it in images that I rendered and it worked well even though other edges did not show,
                        BTW; your render looks great to me.
                          Thank you.
