    [Plugin][$] FredoSpline - v2.6a - 01 Apr 24
    149 Posts 40 Posters 201.1k Views 40 Watching
    • fredo6F
      @johnnygitarr said:
      but i do have problems with the plugin on my mac
      macOS 10.15.4 (Catalina) and SKP 20.0.362.
      SKP crashes while i try to use the plugin.
      I could not test on Mac since I don't have one.
      Could you tell me more about the crash.
      @johnnygitarr said:
      I think i can delete Fredo's Bezierspline now, or?
      I suggest you keep it. I maintain it, although there won't be functional evolutions.
        rv1974
        Fredo,
        *) In other, de-facto standard programs like Max and Pshop, one spline can include all 4 types of points: bezier corner, bezier, corner, smooth, corner. Is this general type of spline possible?
        A singlemouse click creates corner point, continuousmouse click creates bezier point. Is it possible to implement in FredoSpline?
        *) May Undo last point be with Backspace key?
        *) Can moving handle grips aside control pitching (like in attached gif)?
        Thank you for attention
        • fredo6F
          Not clear to me what this means...and I don't have these software to compare.
          Backspace is used to remove inference visuals. Undo is more natural with Ctrl-Z or Escape
          Maybe this is because I have a small screen, but I found that grasping the tangent for rotation and having a handle on the same tangent segment was not very handy.
            johnnygitarr
            Hi Fredo6,
            I wish I could describe the crash more then the following words:
            The only thing I can say is, that when I click on a FredoSpline icon
            and then click on the drawing area to draw, then SKP crashes immediately.
            No Beachball, no other info.
            Greetings
            • fredo6F
              Do you see the button palette appearing?
              Does it happen for any icon?
              Can you start the Quick Launcher?
                johnnygitarr
                HIi Fredo,
                Palette is visible and i did my changes to show every icon,
                but i havn't tried every icon yet.
                Dunno what you mean with Quicklauncher!?
                If it is the Fredo-Menu of the plugin, then i can say no.
                Plugin crashes SKP before Quicklauncher is acitve.
                It might be useful if another Mac user would try the plugin,
                maybe it is a special thing on my machine.
                Greetings
                Toby
                • OxerO
                  Oxer
                  On macOS 10.13.6 & SU2017 the plugin doesn't work, I can init the Quick Launcher, the icons and the Contextual Menu appear but when you push some icon nothing happens, I looked into Console but it's empty. 😲
                  • pascal1964P
                    pascal1964
                    Génial que de belles courbes! 👍
                      jranly
                      @johnnygitarr said:
                      HIi Fredo,
                      Greetings
                      Toby
                      I'm having the same problem with the plugin on my Mac. Click the icon, then Sketchup disappears/crashes.
                        jranly
                        @jranly said:
                        @johnnygitarr said:
                        HIi Fredo,
                        Greetings
                        Toby
                        I'm having the same problem with the plugin on my Mac. Click the icon, then drawing area, then Sketchup disappears/crashes.
                        • fredo6F
                          I am aware of this and trying to find out the cause. I have to count of Mac users because I don't have a Mac myself.
                            • JClementsJ
                              JClements
                              @y rv1974
                              Yes, FredoSpline can produce the equivalence to your questions. It just depends upon the type of spline you are editing and how to manipulate the control points. See Pilou's video and others. If you download the PDFs you should find specific answers to your question.
                              • T
                                T_MP
                                Same problem here. The plugin appears to install ok but crashes SKP when I try to select any of the FredoSpline tools.
                                macOS 10.13.6 (High Sierra) - SKP 19.0.684
                                • fredo6F
                                  NEW RELEASE: FredoSpline v1.2a - 29 Apr 20
                                  Requirement: LibFredo6 10.2
                                  FredoSpline 1.2a is a major release that should now work on Mac platforms
                                  Home Page of FredoSpline for information and Download.
                                  Main post of this FredoSpline thread.
                                  • ArcA
                                    Arc
                                    Convert Curves Error.
                                    Error; #<TypeError; no implicit conversion of nil into Hash>
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/fredosplinetool.rbe;5847;in `update'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/fredosplinetool.rbe;5847;in `edge_picking_init'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/fredosplinetool.rbe;244;in `initialize'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;291;in `new'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;291;in `launch'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;245;in `action__mapping'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;126;in `call'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;126;in `launch_action'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;224;in `launch_action'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;118;in `launch_action'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_fredospline/bootstrap_fredospline.rbe;183;in `block in declare_command'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1321;in `command_invoke'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6plugin.rbe;1303;in `block (2 levels) in build_config_commands'
                                    c;/users/xwtao/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/fredo6_!libfredo6/lib6traductor.rbe;1372;in `block in add_command'
                                    • fredo6F
                                      @Arc
                                      Did you update to FredoSpline v1.2a?
                                      The error lines seems outdated.
                                      • ArcA
                                        Arc
                                        It is fixed, thank you.
                                          reza1813
                                          Dear Fredo,
                                          Hello, is it any possibility to add Gumball to Fredospline like the Rhino? I know that we have it now in these plugins, but regarding the graphical concern, it would be great when we select the point, then we can see a Gumball on top of the point. Thanks.
                                          • fredo6F
                                            @reza1813 said:
                                            Dear Fredo,
                                            You have the direction inferences on axes (global and local), you can also lock any direction. And once the direction is locked or inferred, you can type a distance.
                                            The interest of the gumball (as I see it in the other software) is that you can select several control points (via a selection rectangle) and move them together.
                                            • 1 / 8
