    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • medeekM Offline
      medeek
      The corinthian capital is a little bit heavy for my liking but I guess that is the price you pay for that degree of intricacy.
      https://aws1.discourse-cdn.com/sketchup/original/3X/5/3/538c64727af33295390cb2180f86b2ef39285b2a.jpeg
      View model here:
      3D Warehouse
      (3dwarehouse.sketchup.com)
      I probably need to modify that capital component a bit further and see if I can shrink down the polygon count.
      I also need to provide two additional variants of the Tuscan and Doric capitals which include the astragal directly below the capital.
      My model for the corinthian capital is based off of the model drawn by Karlfucious (found in the 3D warehouse). However, I modified the model extensively as well as redrew the lower fillets and torus to bring it in line with the correct aspect ratio for this type of capital.
      Reference model here:
      3D Warehouse
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        I've managed to squeeze a bit more polygons out of the corinthian capital however it is still quite large. I've also generated my own ionic capital. It is fairly basic but it will do for now:
        https://aws1.discourse-cdn.com/sketchup/original/3X/f/d/fdf826d237f54c78fc860f454401355711cb3e20.jpeg
        The key elements of the ionic capital are dimensionally correct and that is what is most important to me.
        View model here:
        3D Warehouse
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.3.3b - 04.07.2020
          • Added the following classical column types: Tuscan /w Astragal, Doric /w Astragal, Ionic, Corinthian
          http://design.medeek.com/resources/trussplugin/images/truss_su669_800.jpg
          Spent only a couple days on the classical columns but it was time well spent. I now have a much better understanding of the various orders and some of the intricacies and theory on how they all go together. That is why I love this job, I learn something new everyday.
          View model here:
          3D Warehouse
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.3.3c - 04.08.2020
            • Corrected the abacus of the Tuscan and Doric capitals
            https://design.medeek.com/resources/trussplugin/images/truss_su670_800.jpg
            Updated model here:
            3D Warehouse
            Not sure how I initially got this wrong but suffice it to say it is now right.
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.3.3d - 04.09.2020
              • Added a fluting option for the following column types: Doric, Ionic, Corinthian
              http://design.medeek.com/resources/trussplugin/images/truss_su671_800.jpg
              View model here:
              3D Warehouse
              The fluting is represented using a texture/material. The effect is not 100% when viewing the columns up close but I think the effect is adequate for most situations. Note that the Doric column has 20 flutes whereas the ionic and corinthian have 24 flutes.
              design.medeek.com
              • pbacotP Offline
                They look great!
                • medeekM Offline
                  medeek
                  The new post module is really a plugin within a plugin when you think about it. The assemblies it creates (similar to the beam module and stair module) are standalone assemblies within the wall plugin.
                  One could argue that I should split all of these modules out into separate plugins (ie. windows/doors, beams, posts, stairs, trimming tools). I do think the trimming tools (currently found in the Truss plugin) should be split out into a stand alone plugin since it can find application with any SketchUp geometry and not just Medeek related groups/assemblies.
                  On the flip side one could argue that with so much functionality included within the wall plugin it is good value for the money.
                  All in all, I'm very excited to not only get the post module completed (its been on the todo list for quite some time) but also to quite unexpectedly enable a classical column feature.
                  Now that I've got the post module monkey off of my back I'm giving some more serious thought to extending the window and door modules to include non-Medeek walls or Generic Walls as I like to call them. I've already had some experience (and code) doing this sort of thing with the electrical plugin so it isn't impossible, however there may be a few hurdles or technical challenges I haven't foreseen yet.
                  I don't know, I'm still rolling it around in my head this morning. If it feels right I may take the plunge.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.3.4 - 04.14.2020
                    • Added transoms for all rectangular door types.
                    • Enabled all grille options for door transoms.
                    http://design.medeek.com/resources/trussplugin/images/truss_su675_800.jpg
                    I may need to finesse the various grilles to better suite the transom window (dependent on its aspect ratio) but for now it is generally working as it should.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Adding a transom for an arched doorway (with or without sidelites) is an interesting permutation on the problem. In that case the transom would be arched however the door (and sidelites) would be rectangular as usual:
                      https://www.picclickimg.com/d/l400/pict/254185487727_/3068-Colonial-Style-Mahogany-6-Panel-Entry-Door.jpg
                      There are some variations to this though:
                      https://i.pinimg.com/originals/99/1b/bb/991bbbf87a59f95bffd3f78c46c80515.jpg
                      https://i.pinimg.com/originals/56/21/a5/5621a5368e18fe24efd86e9aa9ba39e7.jpg
                      It gives me a headache just trying to figure out how to commit all of these possibilities into code. At some point if a door assembly becomes to "custom" I probably just need to leave it to the user to insert their own assembly/component.
                      I also need to enable arched doorways for doors with sidelites but no transom, the work never ends:
                      https://lcdn.doornmore.com/pub/media/catalog/product/cache/4c49b7d5a8bb55cec7c3e2e44ce07be3/t/r/trinity-solid-panel-e-18-irsl_4.jpg
                      Without a doubt the rectangular doors are so much more linear and boring.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Updated todo list (as of Apr. 14, 2020):
                        1.) Gable and Shed Walls
                        2.) Move the Estimating module to the new Medeek Project extension, and further develop this module as it relates to the wall plugin.
                        3.) Complete the Wall Join tool.
                        4.) Convert the Window, Door and Garage Door Draw menus to HTML.
                        5.) Move the Fixtures module to a the new Medeek Interior extension.
                        6.) Compete the standalone columns/post tool.
                        6b) Classical columns for the post tool.
                        7.) Start work on the integrated Medeek Engineering extension, start with window and door headers for vertical loads.
                        8.) A generic Blocking module is still a good idea in my opinion, I will need further feedback on this one.
                        9.) Transom windows above doors with and without sidelites.
                        10.) Shear Wall module which will ultimately integrate with the engineering plugin.
                        11.) Complete the Wall Stretch tool (75% complete as of 02/24/2020)
                        12.) Additional door and window types as requested (eg. bi-fold, sliding glass, double and triple single hung windows).
                        13.) Spend some time on the new tabs in the global settings, currently showing an Under Construction sign.
                        14.) Presets for Windows and Doors
                        15.) Making the Window and Door modules work with generic walls, not just Medeek walls.
                        16.) Multi-layer gypsum
                        17.) Stair module permutations: U, L, T etc...
                        18.) Further "idiot" proofing of the plugins: (zero value, nil values, checking for impossible geometry, etc...)
                        19.) Wall Justification
                        20.) Interior trim added to Medeek Interior extension.
                        Items in strikethrough have been recently completed.
                        A full list of what has been added or updated can be viewed here:
                        Medeek Design Inc. - Medeek Wall Plugin Changelog
                        (design.medeek.com)
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.3.4b - 04.15.2020
                          • Added transoms for arched door types.
                          http://design.medeek.com/resources/trussplugin/images/truss_su676_800.jpg
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Door with transom and sidelite and wall trim:
                            https://aws1.discourse-cdn.com/sketchup/original/3X/9/7/970edef68e51bf79900295a9dda245094bc5d212.jpeg
                            Arched door with transom and wall trim:
                            https://aws1.discourse-cdn.com/sketchup/original/3X/1/8/18cdf0c3611da81ecb5688ae44c06a267cc1d3bf.jpeg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I've added a parameter which shows the leg height of the transom or arched door way, it is currently not a user editable parameter but I will test it further and may make it user definable if that makes sense:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/0/c/0c1be7240c132e7fb201b9ebfd58e41a58c70c0e.jpeg
                              The arch leg height is defined or calculated by the following three parameters:
                              door width (w), transom/door height (h), arch radius (r )
                              and given by the following equation:
                              L = h - r(1-cos(asin(0.5*w/r)))
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                First look at an arched door with sidelites and transom:
                                https://aws1.discourse-cdn.com/sketchup/original/3X/0/0/006587420d7e4d5be6d85cf9cc6f08730fa1be28.jpeg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  I'm trying to wrap up the whole arched door (with sidelites) issue. I'm currently looking at the situation where you have sidelites but no transom, this turns out to be the more complicated situation since both the door and the sidelites follow the arch of the doorway.
                                  As nearly as I can tell an arched door always will have double sidelites and not a single sidelite:
                                  https://lcdn.doornmore.com/pub/media/catalog/product/cache/4c49b7d5a8bb55cec7c3e2e44ce07be3/t/u/tuscany-hillcrest-e-18.jpg
                                  Correct me if I'm wrong.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.3.5 - 04.18.2020
                                    • Enabled single and double sidelites for arched doors with a transom.
                                    • Added a leg height parameter to the door edit menu for arched doors.
                                    • Enabled double sidelites for arched doors without a transom.
                                    http://design.medeek.com/resources/trussplugin/images/truss_su682_800.jpg
                                    http://design.medeek.com/resources/trussplugin/images/truss_su681_800.jpg
                                    Along the way I also addressed some minor bugs with regards to door openings and the exterior wall trim. I highly recommend upgrading to this latest release.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Tutorial 11 - Split Wall Cladding (6:49 min.)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.3.6 - 04.22.2020
                                        • Resolved an issue with UTF-8 encoding.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          After some further analysis it would seem that I need one additional "end" wall condition, see image below:
                                          https://aws1.discourse-cdn.com/sketchup/original/3X/9/7/973ff5fef8b9951a0051cdba71630f0cdd67d504.jpeg
                                          In this situation you have multiple walls coming together at a single location. The exterior walls constitute an inside corner however the interior wall is not a normal "tee" intersection. If one uses the "end" condition then the end of the interior wall is wrapped with gypsum as shown and the gypsum on the exterior wall is not removed. It you try to use a "tee" condition the interior wall top plate wants to remove part of the exterior wall's top plate, so this doesn't really work either.
                                          I am going to call this wall condition a "terminal" wall condition. Essentially it is identical in behavior to the "end" wall condition however it does not get a gypsum wrap (interior walls), but it will also still remove any gypsum/sheathing/cladding of any wall it terminates against.
                                          See model here:
                                          3D Warehouse
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.3.7 - 04.25.2020
                                            • Fixed the HTML tabs of the global settings (page 2).
                                            design.medeek.com
                                            • 71
                                            • 72
                                            • 73
                                            • 74
                                            • 75
                                            • 73 / 75
