⚠️ Libfredo 15.4b | Minor release with bugfixes and improvements Update
Error loading F3d_Flextools - Help !
3 Posts 3 Posters 795 Views 3 Watching
    P177
    Ciao,chi mi può aiutare per questo error tools di sketchup??
    Ho tentato di installare ComponentFinder.rbz da flextools su sketchup2019 ma mi da il seguente errore:
    Error: #<NoMethodError: undefined method scan' for nil:NilClass> c:/users/pietro talamini.giplanet/appdata/local/f3d_flextools/packages/tools/component_finder/tool.rbe:586:in load'
    c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:4042:in load_module' c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:4034:in load_script'
    c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:3895:in load' c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:6458:in each'
    c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:6458:in load_products' c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:6382:in fetch_packages'
    c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:6332:in init' c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:6317:in method_missing'
    c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:8945:in setup' c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:8960:in module:FlexTools'
    c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:19:in <module:F3d>' c:/users/pietro talamini.giplanet/appdata/roaming/sketchup/sketchup 2019/sketchup/plugins/f3d_flextools/main.rbe:18:in <main>'
    C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in eval' C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in require'
    C:/Program Files/SketchUp/SketchUp 2019/Tools/extensions.rb:197:in load' C:/Users/pietro talamini.GIPLANET/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/f3d_flextools.rb:17:in register_extension'
    C:/Users/pietro talamini.GIPLANET/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/f3d_flextools.rb:17:in <module:FlexTools>' C:/Users/pietro talamini.GIPLANET/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/f3d_flextools.rb:7:in module:F3d'
    C:/Users/pietro talamini.GIPLANET/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/f3d_flextools.rb:6:in `<top (required)>'
    Vi ringrazio
      pibuz
      Since it's a friends post, I'll translate for him from italian: he has issues after the installation of componentfinder. He gets the error message he attached in his post. After the installation, no toolbars or icons showing the gear show up, then - after the relaunch of SketchUp - this error pops up.
      I tried helping him out uninstalling and installing again but didn't fix it. Any help would be greatly appreciated! Thanks in advance!
      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
        Make sure the it's the latest version. Go here to check: https://flextools.cc/
        Make sure SketchUp 2019 was installed correctly by right clicking on the downloaded installer file and clicking on Run as administrator. Then choose the repair option. Also make sure the latest version of SU2019 is installed from sketchup.com/download/all
        If after doing those things the error message still shows, contact the Flextools customer support for assistance.
