    [Plugin] FullScreen v5.1.3 (25 April 2024)
    285 Posts 79 Posters 444.8k Views 80 Watching
      bharralure
      Bonjour Anton,
      Je viens d'installer la version 4.2.2 qui semble fonctionner parfaitement.
      De plus, "cerise sur le gâteau" (expression Français qui, j'espère, sera traduite correctement par Google), la fenêtre est en Français.
      Merci Anton pour cette mise à jour efficace.
        perroloco2000
        Hi Anton,
        The setting dialog doesnt display properly and cannot scroll to the option for Retain settings on Start.
        The settings aply well but I'm not able to keep them on the start.
        Specs: Windows 10 v1607 x64 / SU Pro 2017 v17.0.188899 / AMSlibrary 3.4.1, AMSwindowSettings 4.2.2 / Geforce GTX960M 2GB dedicated / 1920x1080
        In my other laptop (same specs as graphics: Intel HD4000 integrated / 1366x768) all works well!!
        Maibe a resolution issue? I tried other resolutions and connecting other monitors but same problem. Please help!
        Thanks in advance for your help and plugins.
        (tried to attach an screnshot)
          Anton_S
          Thanks for the report, Perroloco. I will fix that soon. By the way, if the Spanish translations are improper, because I used Google translate for them, you can modify the translations for the commands_es.strings and window_settings_es.html, located in ../ams_WindowSettings/lang folder and send me a PM with the two new files so that I could merge them into the plugin.
            Anton_S
            Alright, Perroloco, it's fixed now. Please upgrade to version 4.2.3.
              perroloco2000
              THANKS ANTON!!!
              Everything is working perfect now!
              For a google translation is really well done. I would only change "Contenedores de barra" for "Barra de herramientas".
              Glad I could help you also (tiny help je je). And thanks for your quick reply.
              Keep up the good work!
                Archsuke
                how to change language it's not possible
                  Jorgensen
                  Hi Anton
                  A very nice plugin. It's very satisfying working in full screen with no distracting menu bars 😄
                  When i first saw the settings menu, I thought that I could select the Mode, and then set settings for this mode, and then select an other mode, and then select settings for this mode. But that seems not to be the case - but i might have misunderstood the use of the plugin.
                  What I was looking for, was to be able to switch to full screen mode using F11, and then I would not see anything, just a blank clean, non disturbing work screen, then when I press F11, I should come back to a "normal" screen where I can access the different menus, if needed.
                  Could that setup be possible with this plugin?
                  Jorgensen
                    Anton_S
                    Hi Jorgensen,
                    There are "Save", "Retain", and "Reset" options, which are almost exactly what you're looking for. Here is how to utilize them:
                    1. Assign an F11 hotkey to (Menu) Window Settings -> Retain command.
                    2. Assign an F12 hotkey to (Menu) Window Settings -> Reset command.
                    3. Use WindowSettings UI to hide all the elements you would want hidden in fullscreen mode.
                    4. Click on the Save button and close the UI
                      Use F11 and F12 keys to toggle between fullscreen mode.
                    I know that you are looking for a single hotkey to do both, so that's a good request.
                    Anton
                      Jorgensen
                      Thanks Anton
                      Just what I was looking for. Not sure what happens, but it works.
                      And it's not a problem using two keys.
                      Jorgensen
                        khaeid
                        It stopped working on Sketchup 2019, I get the following error:
                        Error Loading File ams_WindowSettings.rb
                        Error: #<IOError: The required, staged c extension file, "C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/libraries/stage/win64/2.5/ams_lib.so", is missing!>
                        C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:199:in block in require_all' C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:196:in each'
                        C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/extension_manager.rb:196:in require_all' C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_Lib/main.rb:129:in <top (required)>'
                        C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require' C:/Program Files/SketchUp/SketchUp 2019/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:59:in require'
                        C:/Users/Khaled/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/ams_WindowSettings.rb:16:in `<top (required)>'
                          Anton_S
                          @khaeid Update to the latest version of AMS Library to rid of the error.
                            khaeid
                            I am already using the last version of the library 3.5.2, and I uninstalled both Library and Windows settings now and installed them again, and still have the same error
                              Anton_S
                              Latest version is 3.6.0: https://sketchucation.com/pluginstore?pln=ams_Lib.rbz
                                khaeid
                                Ah ok, Thank you, it works now, the version in Extension Warehouse was still the old one, I was downloading the library from there
                                • E Offline
                                  egomez121
                                  Thanks for this plug in! It works great on my Win7 PC! One request for me would be to have the ability to turn off the header for all the floating toolbars. I have a bunch on my secondary screen and the name headers take up a ton of room that I could utilize to better organize those floaters. Thanks again!
                                  • zooenZ Offline
                                    zooen
                                    Hello everyone,
                                    Well! it's been years that I use SU and I did not know it great plugin.
                                    Thank you Anton, Bravo! ☀
                                    It was while researching the procedure to follow to buy a license of Clothworks that I discovered it.
                                    Zooen
                                      pipinek
                                      @anton_s said:
                                      updated february 10th, 2012
                                      Now works on windows 7 too!!! Well, read the 1st post for an info. 😉
                                      Thankyou, for your replies and comments!!! They really improved the plugin plus my English. 😄
                                      Somehow, therefore, I don't strugle at the english essays anymore... ❗ :berserk: 😍
                                      Greetings,
                                      Any chance to get an update for Su 2020?
                                      Thank you
                                        Anton_S
                                        @pipinek said:
                                        Greetings,
                                        Thank you
                                        Hi! This plugin should work with SU2020 just as fine, provided you have the latest versions of the AMS Library and the Windows Settings plugins installed.
                                          pipinek
                                          @anton_s said:
                                          @pipinek said:
                                          Greetings,
                                          Thank you
                                          Oh, splendid.
                                          Than you.
                                          Alas I have noticed one issue with the plugin.
                                          Once active whilst I open/activate a toolbar it is completely frozen. As if it does exist on the screen except its visual presence there.
                                          The only way to touch it with the effect is to disable/unable an option Setting-Toolbar Containers. But in that case some docked icon are slightly displaced. Have to replace them.
                                          I will appreciate any piece of advice.
                                          Thank you in advance.
                                            Anton_S
                                            @pipinek said:
                                            Oh, splendid.
                                            Than you.
                                            Could you elaborate what's going on, perhaps with a screenshot? I am not able to quite make out what's going on.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 11 / 15
