Shadow Anomaly's in Layout
Was wondering if anyone else has experienced the following shadow anomaly's in Layout?
The circled areas in red should not appear solid as they are not a section cut nor should they have a fill assigned to them.
Thanks,
Mark
I haven't seen that sort of thing but then I might not have set up a scene that way. Can you share the LayOut file so we can poke at it a bit and help you determine what it is?
Shoot. This Layout file is much too large to upload.
So upload it to Drop Box and share the link. If you can't make it public, share it in a private message to me.
Im curious to see if this issue was sorted as I am having a similar problem in LO when rendering in hybrid or vector, I get unwanted areas of section fill. It's been happening for some time but have accepted that my sections need to be raster which is not ideal for presentation purposes. Hopefully this gets sorted in SU2023.
@sekta said:
Im curious to see if this issue was sorted as I am having a similar problem in LO when rendering in hybrid or vector...
Share your LO file so we can see what you've got.
Are you still using SU2020 as indicated in your profile?
