    Hide command problem
    2 Posts 2 Posters 1.4k Views 2 Watching
    • E Offline
      erdincerdincdurmus
      why objects look like this in hide command
        If your profile is correct and you are using SketchUp 2019, it's because you have Hidden Geometry turned on in the View menu. In SU2020, it could be Hidden Objects instead. In either case, deselect the appropriate item in the View menu.
        Note: Moved from the Bugs category because this is not a bug in SketchUp.
        BTW, your profile says you are using SketchUp 2019 Free/Make which doesn't exist. What version are you really using. Please update your profile as that information is helpful to others when you ask for assistance. Thanks.
