    Medeek Wall Plugin
    1.5k Posts 27 Posters 991.0k Views 26 Watching
    • jujuJ Offline
      juju
      Can windows and doors please be contained in a separate extension altogether?
      • medeekM Offline
        medeek
        Once I enable the ability to insert doors and windows into any generic walls then this request makes more sense. However, when a new customer purchases the Wall plugin the Window and Door plugin should also be automatically included (what good are walls if you don't have the tools to create openings in them).
        For now it will remain bundled with the Wall plugin however in the future I may split it out into a separate plugin. When a new user purchases the Wall plugin it will also include a license to the Window and Door plugin.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.2.8b - 02.25.2020
          • Added double slider (XOX) windows to the window module.
          • Added twin single hung windows to the window module.
          http://design.medeek.com/resources/trussplugin/images/truss_su657_800.jpg
          View model here:
          3D Warehouse
          (3dwarehouse.sketchup.com)
          design.medeek.com
          • jujuJ Offline
            juju
            Fair enough, but I (as do many others) use different dedicated extensions for Doors & Windows. If one can disable the functionality (and associated menu icons) without compromising the extension, I suppose it is all good.
            • medeekM Offline
              medeek
              Version 1.2.9 - 02.28.2020
              • Addressed the issue where upgrading the plugin would delete custom materials, custom headers and wall presets. These items are now stored outside of the plugin sub-folder.
              The good news with this update, is that unlike some of the other recent updates, it will not affect compatibility. The somewhat bad news is that I have not yet tested it with MacOS, but in theory it should work perfectly, I am waiting with bated breath.
              This is one those under-the-hood updates that does not appear to be very exciting however that fact that updating the plugin will no longer erase your custom materials, headers and wall presets is actually a pretty big deal. I am hoping this update will ultimately decrease a lot of my tech support calls and emails, I think it will make a difference.
              Now I just need to apply this same fix to the Truss, Foundation and Electrical plugins...
              design.medeek.com
              • medeekM Offline
                medeek
                Just to offer a few more details on this latest update.
                When you first install the plugin or upgrade it any existing plugin folder is removed during the uninstall and recreated during the install. The following sub-folders are created with the new .rbz file:
                • library_headers
                • library_mats
                • presets
                These contain the default headers, materials and presets (none) that come with the plugin as it ships.
                The first time you run the plugin it then creates a sub-folder here (on windows, Mac is similar but slightly different path):
                C:\Users%Username%\AppData\Roaming\Medeek\2017\medeek_wall_ext
                Notice the year in the full path, this will of course depend on which version of SU you are installing the plugin into. The plugin then looks into this folder for the three sub-folders listed above, if it can't find them it copies the default folders and their contents from the plugin folder to the "AppData" folder. This is where the working folders actually exist for these settings, and when you add new materials etc... this is where the modifications and additions are made.
                When you upgrade the plugin the plugin folder is removed and recreated however the sub-folder in AppData is retained. If the new installation then finds these sub-folder already existing it does not attempt to recreate them and hence your settings are retained.
                Each different version of SketchUp (ie. 2017, 2018, 2019 and 2020) will all have their own separate sub-folder and parameters assuming you've installed the plugins into these separate SU installations. One can easily duplicate parameters by copying and pasting the "medeek_wall_ext" sub-folder between the SU version folders if required. I may include a tool for automating that (migration wizard) if there is enough demand for it.
                design.medeek.com
                • medeekM Offline
                  medeek
                  The Beams/Columns toolbar will now include two additional icons:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/5/5/55156d19447d1e0b7157fb5ac0892ea81658327d.jpeg
                  • Draw Post
                  • Edit Post
                  In order to differentiate between in-wall columns and free standing columns I will be using the term "post" to refer to the latter and simply "column" to refer to the former.
                  The new post or free standing column module is actually relatively simple so I thought I would knock it out this weekend since there has been some demand for it recently. The basic concepts and configurations will be as shown before in a previous thread:
                  https://aws1.discourse-cdn.com/sketchup/original/3X/6/7/6756cf007e91a2434f3dfe5ce4004f490e902263.jpeg
                  Each color denotes a unique material that can be specified by the user. Hopefully this should give enough flexibility when it comes to wrapping free standing columns.
                  Even though it requires more upfront work on my end I think I would like to setup the post selection similar to the custom header library so that the user can preconfigure various post sizes and materials. This feature will be made available within the global settings.
                  P.S. Tomorrow is the last day before the 2020 price increases takes affect.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Here are the parameters for the Post Module:
                    BASIC OPTIONS:
                    Post Type:
                    Post Size:
                    Lumber Species:
                    Grade:
                    Post Ply Qty.:
                    Pressure Treated: Yes/No
                    Post Rotation:
                    Adv. Post Options: Yes/No
                    ADVANCED OPTIONS:
                    Wrap: Yes/No
                    Wainscot: Yes/No
                    Cap: Yes/No
                    Base: Yes/No
                    Astragal: Yes/No
                    WRAP OPTIONS:
                    Wrap Thickness:
                    Wrap Air Gap:
                    Wrap Material:
                    WAINSCOT OPTIONS:
                    Wainscot Thickness:
                    Wainscot Air Gap:
                    Wainscot Height:
                    Wainscot Material:
                    Wainscot Ledge: Yes/No
                    Ledge Depth:
                    Ledge Overhang:
                    Ledge Material:
                    CAP OPTIONS:
                    Cap Thickness:
                    Cap Depth:
                    Cap Material:
                    BASE OPTIONS:
                    Base Thickness:
                    Base Depth:
                    Base Material:
                    ASTRAGAL OPTIONS:
                    Astragal Thickness:
                    Astragal Depth:
                    Astragal Height:
                    Astragal Material:
                    The basic options will be very similar to the beam module with the option for steel columns as well as wood (eg. lumber, timber, SCL, glulam).
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.3.0 - 03.07.2020
                      • Fixed a critical bug with custom materials that was caused by the change in the location of the plugin's data sub-folder.
                      *** CRITICAL BUG FIX ***
                      If you recently downloaded version 1.2.9 of the plugin then you will want to upgrade to this version to resolve an issue with custom materials in the Material Library. I highly suggest that everyone upgrade to this latest release at your earliest convenience.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        I've been thinking about how to best handle levels or floors of a structure lately. I'm thinking about assigning an additional parameter (that can be user edited) which assigns a given wall assembly to a particular user defined level or floor. Another way of handling this is in conjunction with layer assignment. Everyone's workflow is a little different so I think it is important that if I provide certain options I make them truly optional. In other words the layer assignment tool could optionally assign the assemblies to a particular layer/tag.
                        As a side note SU 2020 now calls layers -> tags. I'm not really happy with that change, I don't see why the word layer or layers was a bad or incorrect term within the context of SketchUp. Honestly, tags is even more confusing in my opinion. For now I will not be changing my terminology within the plugin, I will still be calling them layers, everyone knows what I'm talking about. If the term "tags" actually sticks then in a year or so I may consider updating my terminology, but I'm going to let this one percolate for a while.
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          First look at the HTML draw menu for the Post module:
                          https://aws1.discourse-cdn.com/sketchup/original/3X/2/1/213572d5f8abd98743fa7928f11241af0cd46c5b.jpeg
                          This module is relatively simple however since there are so many advanced options there is still quite a bit of coding to do.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Version 1.3.1 - 03.15.2020
                            • Added a "Style4" door hardware option (Lever & Deadbolt) to the door module.
                            • Fixed a bug with the door opening tool for man doors.
                            http://design.medeek.com/resources/trussplugin/images/truss_su659_800.jpg
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              First look at some posts created with the Post module:
                              https://aws1.discourse-cdn.com/sketchup/original/3X/a/d/ad1407e19b0f9014c9b3da8823f963bad5c4844d.jpeg
                              The basic module is up and running I just need to spend a few more hours on the advanced options (ie. wrap, wainscot, base, cap and astragal) and then this module will be a welcome addition to the plugin.
                              View model here:
                              3D Warehouse
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.3.2 - 03.31.2020
                                • Added the ability to draw and edit free standing columns with the Beams/Column Toolset.
                                http://design.medeek.com/resources/trussplugin/images/truss_su661_800.jpg
                                View model here:
                                3D Warehouse
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.3.2b - 04.02.2020
                                  • Added an indexing parameter for posts to the General tab of the global settings.
                                  • Added the built-in materials (red brick) for post wrap and wainscot and (concrete) for post ledges.
                                  • Added labels and callouts for all post types.
                                  http://design.medeek.com/resources/trussplugin/images/truss_su662_800.jpg
                                  I've also switched to the new .rbe encryption method for the plugin which effectively prevents it from running on SketchUp 2015 or earlier. I was more than content to stick with the .rbs encryption method but the SketchUp extension signing page has removed this encryption method and only the .rbe method is currently offered.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Tutorial 10 - Posts (14:24 min.)
                                    Round or Greek/Roman columns would also be a nice addition to this module but I'm not entirely sure on the construction or geometry of them. They typically have a gradual taper and then the top (capital) always has some interesting geometry (Doric, Ionic, Corinthian):
                                    https://mcgrawimages.buildingmedia.com/CE/CE_images/2014/dec_Crown-Columns-5.jpg
                                    https://st.hzcdn.com/simgs/d34177fe0df2a9e2_4-9388/home-design.jpg
                                    design.medeek.com
                                    • pbacotP Offline
                                      Yeah, the classical orders are pretty involved. But people now buy columns and install them with little regard to the details or proportions. Some will be happy with what you can come up with in a parametric plugin, but others will probably just find or model their own version. You'll find Corinthian and composite columns most challenging with the floral details and required poly count. Good for you, if you going to tackle this as well!
                                      • medeekM Offline
                                        medeek
                                        I'm always up for a bit of a challenge so after digging around on the internet for awhile and reading some documents provided by some of my mentors here is what I have for classical columns:
                                        1.) The diminution ratio seems to be 5/6 for most columns that are 15ft of less. I will label this ratio as "m".
                                        2.) There is a height to diameter ratio however I think I should leave it up to the user to specify whatever diameter they chose for any particular height however I could suggest the classical (recommended) diameter for a given height.
                                        3.) If we let the base diameter be "d" then the entasis radial difference "E" is given by:
                                        E = d(1-m)/2.
                                        4.) Let h = height of the shaft. The entasis (or diminution) begins at a height of 1/3h. The entasis is not a linear reduction in diameter but rather follows a curved profile with the radius of curvature tangent to the lower cylindrical portion of the shaft.
                                        5.) The radius of the entasis curvature is given by r[sub:3w5bl8ej]e[/sub:3w5bl8ej] = 2h[sup:3w5bl8ej]2[/sup:3w5bl8ej]/9E + E/2.
                                        6.) The angle of the sweep of the arc is given by theta = asin(2h/3r[sub:3w5bl8ej]e[/sub:3w5bl8ej])
                                        The above derivation and observations should then give me enough information to be able to properly draw the shaft of any classical column. The base and capital however are a whole nother story.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          For the base and capital of a classical column I think it would be easiest just to pre-model some standard configurations and then have the plugin insert the components rather than try to draw them from scratch. Since both of these elements are merely a function of the column diameter the plugin can easily scale them to the correct size upon insertion... problem solved.
                                          Now I just need some decent (but low poly) ionic and corinthian capitals, if such a thing is possible.
                                          design.medeek.com
                                          • pbacotP Offline
                                            Sometimes people leave the base off so you might consider that, especially for Tuscan column.
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 73
                                            • 74
                                            • 39 / 74
