    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 456.7k Views 109 Watching
    • samuel_tS Offline
      samuel_t
      @oxer said:
      Thanks for the aclaration.
      Thea4SU plugin has an options to Create or Edit Thea Model in it appears a tittle and options to selec model format, see the image.
      [attachment=0:1sjaildi]<!-- ia0 -->Texts in window.jpg<!-- ia0 -->[/attachment:1sjaildi]
      I'm Thea4SU beta tester and I can ask to Tomasz (TheaSU developer) if it's possible implement that in Universal Importer.
      Good idea!
      • samuel_tS Offline
        samuel_t
        1.1.0 version:
        • Fixes "big copy" issue again.
        • Shows face count before reduction.
        • Updates translations.
        Download latest Universal Importer plugin from SketchUcation PluginStore.
        • OxerO Offline
          Oxer
          Thea4SU plugin has an options to Create or Edit Thea Model in it appears a tittle and options to select model format, see the image.
            Ahmed0007
            @ahmed0007 said:
            Error 😕
            .glb 7.9mb
            Model is here : https://www.dropbox.com/s/bte329pn42gs5px/80005e0d-0006-f600-b63f-84710c7967bb.zip?dl=0
            this issue has been fixed in this version 😮 🎉
            just one little problem is the origin of the imported component placed very far away from geometry
            (~ 13579.78') this make very difficult to place the component.
            Thanks for this fix 😄
              • samuel_tS Offline
                samuel_t
                To locate "far from origin" component: Open Outliner in SketchUp. Select component. Zoom Selection.
                  Ahmed0007
                  Thanks 👍
                  • E Offline
                    Einstein
                    Hi, Samuel!
                    I have reinstalled MS Visual C++ as you advised and now I can import stuff 😄 Thank you!
                    Still a couple of things bother me a bit.
                    1. The plugin always asks how big the imported model should be. It doesn't preserve its original size.
                    2. I was thinking of remesher tool as one working on selection, which would be more comfortable than remeshing entire model, as it goes now.
                      However, the remesher icon is beautiful! 10/10 for it 😄
                    3. When I import a model with multiple textures, I can only select one texture file and that texture is applied.
                      Sometimes I can but another time I cannot have all textures included. Some models may be badly textured but I'm almost sure that I tried importing the same chair as TutorialsUp did with success, while I didn't get both textures (only one). I'm attaching both OBJ and FBX version of the model.
                    Rudolf Chair.rar
                      andsgf
                      Вот такая ошибка
                      smena8m-plus8.skp
                      • samuel_tS Offline
                        samuel_t
                        @andsgf said:
                        Вот такая ошибка
                        I suppose polygon reduction fails because face count is low at start (387). I can't fix this problem. 😕
                          Ahmed0007
                          @samuel_t said:
                          @andsgf said:
                          Вот такая ошибка
                          it's working after running cleanup extension on it.
                          • samuel_tS Offline
                            samuel_t
                            1.1.1 version:
                            • Copies only necessary files to temp dir.
                            • Shows model face count during import.
                            • jujuJ Offline
                              juju
                              @samuel_t said:
                              1.1.1 version:
                              I'm getting this message when trying to download:
                              "Sorry this plugin is not published at the moment. Probably under editing by the author. Please check later."
                              • samuel_tS Offline
                                samuel_t
                                @juju said:
                                @samuel_t said:
                                1.1.1 version:
                                Please check now. It should be fine.
                                • samuel_tS Offline
                                  samuel_t
                                  @tig said:
                                  It makes a folder 'Universal Importer/tmp' inside the main C:/ProgramData/ hidden-folder - not sure why ?
                                  What's wrong with the user's Temp folder ?
                                  User's temp folder can contain special chars which are not supported by program used by this plugin.
                                  @tig said:
                                  Permission muddles and other issues are almost inevitable !
                                  Famous plugins like Artisan and Skatter are using C:\ProgramData. This isn't a problem.
                                  @tig said:
                                  The importer then copies a seemingly random selection of files and subfolders into 'tmp' !
                                  It seems like these are from the same location as the file selected to import ?
                                  Currently about 17Gb !
                                  Textures can be associated to model. So I've no choice but to copy whole folder.
                                  Since 1.1.1 version of plugin, only necessary files are copied to temporary folder.
                                  @tig said:
                                  There's no auto-cleanup on completion, and so the 'tmp' folder will grow with each run of the importer !
                                  No. Plugin temporary folder is recycled on each new import. There's no risk to saturate disk.
                                  • jujuJ Offline
                                    juju
                                    @samuel_t said:
                                    @juju said:
                                    @samuel_t said:
                                    1.1.1 version:
                                    Still can't download, not published.
                                    • samuel_tS Offline
                                      samuel_t
                                      @juju said:
                                      @samuel_t said:
                                      @juju said:
                                      @samuel_t said:
                                      1.1.1 version:
                                      Yet it's published. Try following routines: Clear your browser cache. Reboot your Internet router.
                                      • kenK Offline
                                        ken
                                        I still have the problem I have for some time.
                                        • samuel_tS Offline
                                          samuel_t
                                          Reinstall Microsoft Visual C++ library (it can fix your error) then let me know if problem persists.
                                          • samuel_tS Offline
                                            samuel_t
                                            1.1.2 version fixes loading of some OBJ files.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 22
                                            • 23
                                            • 13 / 23
