    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    446 Posts 109 Posters 457.1k Views 109 Watching
    • samuel_tS Offline
      samuel_t
      @oxer said:
      Spanish Language for v1.0.9
      [attachment=0:8aivyaaf]<!-- ia0 -->es.zip<!-- ia0 -->[/attachment:8aivyaaf]
      Thanks for translation, Oxer. 😉
      @oxer said:
      REQUEST: Can you investigate the missing texts in the importing popup windows on macos? I think for users it's very useful to see the text to understand what have to do.
      I can't fix this problem because:
      "[On a Mac] UI.openpanel ignores the title argument. There isn’t even a place in the dialog for a title to appear. It also doesn’t support wildcard patterns for the filename and there is no place for a selection list to appear anyway. In fact, the filename argument appears to have no effect at all; it isn’t pre-selected and the user can choose anything."
      Source: https://forums.sketchup.com/t/good-default-directory-for-ui-savepanel/40307/6
      • samuel_tS Offline
        samuel_t
        @oxer said:
        Thanks for the aclaration.
        Thea4SU plugin has an options to Create or Edit Thea Model in it appears a tittle and options to selec model format, see the image.
        [attachment=0:1sjaildi]<!-- ia0 -->Texts in window.jpg<!-- ia0 -->[/attachment:1sjaildi]
        I'm Thea4SU beta tester and I can ask to Tomasz (TheaSU developer) if it's possible implement that in Universal Importer.
        Good idea!
        • samuel_tS Offline
          samuel_t
          1.1.0 version:
          • Fixes "big copy" issue again.
          • Shows face count before reduction.
          • Updates translations.
          Download latest Universal Importer plugin from SketchUcation PluginStore.
          • OxerO Offline
            Oxer
            Thea4SU plugin has an options to Create or Edit Thea Model in it appears a tittle and options to select model format, see the image.
              Ahmed0007
              @ahmed0007 said:
              Error 😕
              .glb 7.9mb
              Model is here : https://www.dropbox.com/s/bte329pn42gs5px/80005e0d-0006-f600-b63f-84710c7967bb.zip?dl=0
              this issue has been fixed in this version 😮 🎉
              just one little problem is the origin of the imported component placed very far away from geometry
              (~ 13579.78') this make very difficult to place the component.
              Thanks for this fix 😄
                • samuel_tS Offline
                  samuel_t
                  To locate "far from origin" component: Open Outliner in SketchUp. Select component. Zoom Selection.
                    Ahmed0007
                    Thanks 👍
                    • E Offline
                      Einstein
                      Hi, Samuel!
                      I have reinstalled MS Visual C++ as you advised and now I can import stuff 😄 Thank you!
                      Still a couple of things bother me a bit.
                      1. The plugin always asks how big the imported model should be. It doesn't preserve its original size.
                      2. I was thinking of remesher tool as one working on selection, which would be more comfortable than remeshing entire model, as it goes now.
                        However, the remesher icon is beautiful! 10/10 for it 😄
                      3. When I import a model with multiple textures, I can only select one texture file and that texture is applied.
                        Sometimes I can but another time I cannot have all textures included. Some models may be badly textured but I'm almost sure that I tried importing the same chair as TutorialsUp did with success, while I didn't get both textures (only one). I'm attaching both OBJ and FBX version of the model.
                      Rudolf Chair.rar
                        andsgf
                        Вот такая ошибка
                        smena8m-plus8.skp
                        • samuel_tS Offline
                          samuel_t
                          @andsgf said:
                          Вот такая ошибка
                          I suppose polygon reduction fails because face count is low at start (387). I can't fix this problem. 😕
                            Ahmed0007
                            @samuel_t said:
                            @andsgf said:
                            Вот такая ошибка
                            it's working after running cleanup extension on it.
                            • samuel_tS Offline
                              samuel_t
                              1.1.1 version:
                              • Copies only necessary files to temp dir.
                              • Shows model face count during import.
                              • jujuJ Offline
                                juju
                                @samuel_t said:
                                1.1.1 version:
                                I'm getting this message when trying to download:
                                "Sorry this plugin is not published at the moment. Probably under editing by the author. Please check later."
                                • samuel_tS Offline
                                  samuel_t
                                  @juju said:
                                  @samuel_t said:
                                  1.1.1 version:
                                  Please check now. It should be fine.
                                  • samuel_tS Offline
                                    samuel_t
                                    @tig said:
                                    It makes a folder 'Universal Importer/tmp' inside the main C:/ProgramData/ hidden-folder - not sure why ?
                                    What's wrong with the user's Temp folder ?
                                    User's temp folder can contain special chars which are not supported by program used by this plugin.
                                    @tig said:
                                    Permission muddles and other issues are almost inevitable !
                                    Famous plugins like Artisan and Skatter are using C:\ProgramData. This isn't a problem.
                                    @tig said:
                                    The importer then copies a seemingly random selection of files and subfolders into 'tmp' !
                                    It seems like these are from the same location as the file selected to import ?
                                    Currently about 17Gb !
                                    Textures can be associated to model. So I've no choice but to copy whole folder.
                                    Since 1.1.1 version of plugin, only necessary files are copied to temporary folder.
                                    @tig said:
                                    There's no auto-cleanup on completion, and so the 'tmp' folder will grow with each run of the importer !
                                    No. Plugin temporary folder is recycled on each new import. There's no risk to saturate disk.
                                    • jujuJ Offline
                                      juju
                                      @samuel_t said:
                                      @juju said:
                                      @samuel_t said:
                                      1.1.1 version:
                                      Still can't download, not published.
                                      • samuel_tS Offline
                                        samuel_t
                                        @juju said:
                                        @samuel_t said:
                                        @juju said:
                                        @samuel_t said:
                                        1.1.1 version:
                                        Yet it's published. Try following routines: Clear your browser cache. Reboot your Internet router.
                                        • kenK Offline
                                          ken
                                          I still have the problem I have for some time.
                                          • samuel_tS Offline
                                            samuel_t
                                            Reinstall Microsoft Visual C++ library (it can fix your error) then let me know if problem persists.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
