    [Plugin] Universal Importer - v1.2.6 - 30 July 2024
    453 Posts 112 Posters 612.1k Views 113 Watching
    • E
      Einstein
      Hi!
      I downloaded the latest update but I'm still getting the same bug with every file format. I cannot import any file to SketchUp ๐Ÿ˜ž
      By the way, I think it would be cool to also have polygon reduction as standalone tool for meshes that already exist in SketchUp. Because we haven't had a decent free polyreducer in SketchUp so far. It's just a suggestion.
      Regards,
      Michaล‚
        Ahmed0007
        i import this model with v1.0.1 without any problem but v1.0.6 give me this error why?
        please help.
        800085a7-0000-fd00-b63f-84710c7967bb.zip
        • OxerO
          Oxer
          please help.
          On macOS 10.13.6 & SU2017 the v1.0.6 works fine with your model.
          • OxerO
            Oxer
            It's a good idea ๐Ÿ‘
            • samuel_tS
              samuel_t
              please help.
              In recent versions of plugin there's a mechanism that prevents copy of a too big folder. To fix this issue: Create a sub folder in your Documents then place model and textures inside that sub folder. Re-import.
              • samuel_tS
                samuel_t
                @einstein said:
                Hi!
                Hi!
                Could you please upload your model (textures included) to a file hoster or here? So I could debug it.
                  Ahmed0007
                  @samuel_t said:
                  please help.
                  Still Same error ?
                  • samuel_tS
                    samuel_t
                    @ahmed0007 said:
                    @samuel_t said:
                    please help.
                    Still Same error ?
                    What's size of model in MB?
                      Ahmed0007
                      @samuel_t said:
                      @ahmed0007 said:
                      @samuel_t said:
                      please help.
                      Still Same error ?
                      8 mb
                      • samuel_tS
                        samuel_t
                        @ahmed0007 said:
                        @samuel_t said:
                        @ahmed0007 said:
                        @samuel_t said:
                        please help.
                        Still Same error ?
                        8 mb
                        OK. Could you please post a screen capture of folder containing model (aka a Windows Explorer view)?
                        • TutorialsUpT
                          TutorialsUp
                          Now i'm also unable to import this model again
                          https://www.youtube.com/watch?v=owXwypsZIHY
                          file type .obj
                          size 110 mb
                          located in Documents folder \Documents\obj 2
                            Ahmed0007
                            @samuel_t said:
                            @ahmed0007 said:
                            @samuel_t said:
                            @ahmed0007 said:
                            @samuel_t said:
                            please help.
                            Still Same error ?
                            8 mb
                            C:\Users\Ahmed\Documents\New folder (2)
                            • samuel_tS
                              samuel_t
                              @ahmed0007 said:
                              @samuel_t said:
                              @ahmed0007 said:
                              @samuel_t said:
                              @ahmed0007 said:
                              @samuel_t said:
                              please help.
                              Still Same error ?
                              8 mb
                              Everything seems OK. I don't understand why you can't import... ๐Ÿ˜• There are no hidden files, isn't?
                                Ahmed0007
                                Everything seems OK. I don't understand why you can't import... ๐Ÿ˜• There are no hidden files, isn't?[/quote]
                                did you try this on your own pc
                                No! There are no hidden files
                                i think i should stick with older version.
                                • samuel_tS
                                  samuel_t
                                  Yes. I tried to import a model with this path: "C:\Users\Samuel\Documents\New folder (2)" and it's OK.
                                  • samuel_tS
                                    samuel_t
                                    @Ahmed0007
                                    Could you please upload your model to a file hoster? This way I can verify if the model is the problem.
                                    • TutorialsUpT
                                      TutorialsUp
                                        Ahmed0007
                                        @samuel_t said:
                                        @Ahmed0007
                                        i uplode the model in my first comment
                                        • samuel_tS
                                          samuel_t
                                          file type .obj
                                          size 110 mb
                                          OK. I'm gonna release a hotfixed version.
                                            Ahmed0007
                                            i tried on another pc and get this error
                                            and on one another file get "model is too big error" model size was 11mb
                                            • 22
                                            • 23
                                            • 4 / 23
