    Medeek Electrical
    206 Posts 6 Posters 288.2k Views 5 Watching
    • medeekM
      medeek
      Version 1.0.8 - 09.28.2019
      • Fixed a critical performance bug that affects all the modules within the extension.
      *** CRITICAL PERFORMANCE UPDATE ***
      If you are noticing a slowdown of the plugin performance after multiple edits to an electrical fixture, this fix will resolve that issue. This issue affects all previous versions of the plugin.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM
        medeek
        I've had a lot of requests lately for floor mounted outlets. I've gone ahead and created some low poly models of the Leviton series:
        301 Moved Permanently
        (www.leviton.com)
        View model(s) here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        If there is interest in other brands of floor outlets please let me know. The Hubbell-Raco (6224) also interests me but I haven't had a chance to create a model of it yet and I have been unable to find any detailed dimensional data on it:
        (www.hubbell.com)
        design.medeek.com
        • medeekM
          medeek
          The second toolbar will now include an icon for floor mounted outlets:
          design.medeek.com
          • medeekM
            medeek
            Version 1.0.9 - 11.24.2019
            • Added the "Draw Floor Outlets" and the "Draw Misc. Fixture" function to the secondary toolbar.
            • Enabled the ability to draw misc. fixtures with Medeek wall assemblies or any wall geometry. Enabled misc. devices include: Thermostats, doorbell buttons, doorbell chimes, and doorbell transformers.
            http://design.medeek.com/resources/images/electrical_ii_su_menu_active.jpg
            http://design.medeek.com/resources/trussplugin/images/truss_su599_800.jpg
            View model here:
            3D Warehouse
            Additional fixture components (ie. other manufacturer's doorbell models etc...) can easily be utilized by placing them into the appropriate sub-folder of the plugin's library/misc sub-folder.
            design.medeek.com
            • medeekM
              medeek
              Version 1.1.0 - 12.01.2019
              • Fixed a minor bug in the General tab of the global settings.
              • Enabled the ability to draw floor and ceiling outlets.
              http://design.medeek.com/resources/trussplugin/images/truss_su603_800.jpg
              The included outlets: Raco 5500, Leviton 25249 (Nickel and Brass) Series, Standard Duplex Outlet.
              The plugin automatically detects whether the outlet is a floor or ceiling outlet and assigns the appropriate symbol. This may require some further refinement for outlets mounted to slightly inclined floor or ceiling surfaces, I will be testing this particular situation further.
              User defined outlets can be utilized by dropping the component files into the appropriate library sub-folders: library/fc_rcpt/gang1 or library/fc_rcpt/gang2
              The default label for floor/ceiling outlets is 'RCPT', however this can be set independently from wall mount outlets in the global settings.
              design.medeek.com
              • medeekM
                medeek
                Has anyone ever seen or used a symbol for a duplex switch?
                https://images.homedepot-static.com/productImages/dc83dd18-43d4-4887-8ae8-4a0f70a16739/svn/white-leviton-light-switches-r62-05224-2ws-64_1000.jpg
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.1.1 - 12.04.2019
                  • Added additional 240V duplex and simplex outlets to the built-in library: NEMA 6-15R and NEMA 6-20R.
                  • Added some simplex outlets to the floor outlet built-in library.
                  http://design.medeek.com/resources/trussplugin/images/truss_su604_800.jpg
                  I'm wondering with the undesignated 240V outlets if I should provide the NEMA number (ie. 6-20R) next to the 2D symbol. I would assume that this would be very useful information, a 240V receptacle can take many forms and various amperages.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.1.1b - 12.04.2019
                    • Added more 20A (NEMA 5-20R) outlets to the outlet module: GFCI, WP GFCI, USB etc...
                    Creating a few new electrical components gives me a much needed break from the code and is actually quite relaxing. I'm at the most difficult part of the complex roof module, so I'm taking a couple days to clear my head so that I can take a fresh crack at it and allow myself to think outside the box if required. I find that sometimes it helps to take a break sometimes, which effectively takes the blinders off, and then alternative (better) solutions almost magically appear.
                    If there are any specific outlet or fixture types you would like added please email me.
                    I apologize that I have not provided a solution for other electrical standards yet. Eventually I will do this but I'm not ready to bite it off just yet.
                    Even if you do not purchase the plugin, I think it would be worthwhile to download the trial version just for all of the pre-built electrical components now available in the library sub-folder. Of course, I would prefer that you purchase the plugin but if you don't need the parametrics and some of the other automated features then even the trial version and the library files might be quite useful.
                    design.medeek.com
                    • medeekM
                      medeek
                      Version 1.1.2 - 12.24.2019
                      • Added the "Draw Low Voltage Panel" function to the secondary toolbar.
                      • Enabled the ability to draw low voltage panels with Medeek wall assemblies or any wall geometry. Included Structured Media Panels: Leviton 47605 (14", 21", 28", 42").
                      http://design.medeek.com/resources/trussplugin/images/truss_su607_800.jpg
                      View model here:
                      3D Warehouse
                      For now only the flush cover models are included however if I find the time I will model up the hinged cover variants and include those as part of the standard library.
                      design.medeek.com
                      • medeekM
                        medeek
                        I'm trying to figure out how to best handle the situation where outlets and switches are vertically sitting on top of each other:
                        I'm thinking about adding an advanced parameter which allows offsetting the symbol and label a custom amount so that the symbols don't all pile up on top of each other.
                        https://aws1.discourse-cdn.com/sketchup/original/3X/d/e/defeb5852a72cbaf1da8d509e2dc46c79a8d2005.jpeg
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.1.2b- 12.25.2019
                          • Added an offset parameter (advanced options) for switches which allows the symbol and label to be offset from the wall.
                          http://design.medeek.com/resources/trussplugin/images/truss_su609_800.jpg
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.1.3 - 01.01.2020
                            • Added additional (120V, 20A) outlets to the built-in outlet library.
                            This update includes various (20A) USB and GFCI outlets.
                            design.medeek.com
                            • medeekM
                              medeek
                              For many of the electrical fixtures the designer can use their own electrical components as well as the ones included with the plugin. Here are a few hints/tips on how to do this:
                              1.) You need remove the spaces from file names with spaces in them. Either delete the spaces or replace them with underscores like I have done with my filenames.
                              2.) With your electrical light fixtures be sure that fixture base is located at the origin of the model within your component file. This actually applies to any electrical fixture. The location of the component with respect to the origin determines where it will land within the model once it is inserted by the plugin.
                              3.) When you insert the (ceiling mount) light fixture below make sure you select "ceiling" and not "wall" for the mounting position from the parameter list.
                              design.medeek.com
                              • medeekM
                                medeek
                                Per a customer request I will probably add in two additional user definable fields for all electrical fixtures:
                                1.) Description
                                2.) Circuit
                                Unlike other parameters these will default to a nil value.
                                Are there any other parameters like these that I should add while I am updating each electrical fixture type to include these additional two parameters?
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.1.4 - 02.16.2020
                                  • Added optional metadata parameters for switches: description, circuit.
                                  http://design.medeek.com/resources/trussplugin/images/truss_su649_800.jpg
                                  Once I've received some additional feedback on this new feature I will probably add the metadata parameters for all other electrical fixtures.
                                  Further down the road I can probably also setup a tool which will allow the user to quickly visualize which switches, outlets etc... are on a particular circuit.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Version 1.1.5 - 04.28.2020
                                    • Added a Global Reset button in the General tab of the Global Settings.
                                    • Plugin files switched from .rbs to .rbe encryption.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      My youngest son is looking for a job this summer and with the situation being mostly under lockdown I would rather him work from home, with me.
                                      As such I'm proposing that he help me by creating a number of models for the Electrical plugin so that I can extend it to include the British Standards (BS 1363). I have had a number of requests for other electrical standards and by far the most highly requested has been the British equivalents of our NEMA sockets and switches.
                                      The BS 1363 (Type G) seems to be quite widespread throughout the world.
                                      I have a few models already from a few months prior but any additional information on receptacles and switches as well as standard boxes used in the trade would be greatly appreciated.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        First look at a low poly UK outlet:
                                        https://aws1.discourse-cdn.com/sketchup/optimized/3X/2/e/2e5f4918da58bff09ced278b8c468e318626a862_2_690x388.png
                                        The model is based off of the .SAT models provided on the website of MK Electric.
                                        View model here:
                                        3D Warehouse
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Unlike the typical US outlet and/or switch the British variety come with the faceplate and the electrical component integrated into a single unit. Due to this fact and other considerations the draw and edit menus for the UK version of the plugin will be different than the North American version (NEMA).
                                          Here are some typical outlets:
                                          3D Warehouse
                                          For those of you concerned that I am taking my attention off of the wall and truss plugins, don't be overly concerned. I am only setting up the templates so that my youngest son Edmond can be set loose to do most of the heavy lifting. I will provide oversight, as necessary, to make sure that every outlet and switch model meets my exacting standards but the bulk of my time will be spent working on the gable wall module for the next few days.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            I have been contacted by SketchUp (Educational Programs Coordinator) with regards to using SketchUp for electrical work. They are looking for some examples of recent work to share with the IBEW and ETA (electrical union) to showcase the use of SketchUp in the design and layout of electrical systems.
                                            I am not an electrical contractor so I don't have any actual real life case studies to share or demonstrate but I am hopeful that some of the current users of the electrical plugin might have some examples they are willing to share with the rest of the electrical community.
                                            If you would be interested in sharing some of your work as a case study please contact me at nathan@medeek.com.
                                            design.medeek.com
