    Medeek Electrical
    206 Posts 6 Posters 288.2k Views 5 Watching
    • jujuJ
      juju
      @medeek said:
      As a celebration of the 4th of July and the full parameterization of the Foundation plugin I will be offering an incentive on new purchases or renewals of the Truss, Foundation or Wall plugins.
      If you purchase or renew any of the BIM plugins on the 4th of July (tomorrow) you will be entitled to a complimentary license for the Medeek Electrical extension. This promotion is only valid on the 4th of July.
      I will be taking most of the day off tomorrow (finally) and eating some good food and watching some fireworks on the beach.
      Happy 4th of July!
      Very generous of you, done deal!
      Joyous celebrations!
      • medeekM
        medeek
        A couple of things worth noting after working with a customer via Skype this morning:
        1.) If your custom walls have reversed faces this will affect the plugin. The solution is to jump into the group, right click on the face in question and reverse the face.
        2.) The plugin calculates the bottom of the wall by looking at the origin of the group that is the container for the wall geometry. If the origin of this group is below or above the bottom of the wall then the vertical distance for positioning various electrical fixtures (ie. switches, outlets, data etc...) will not be correct. I may change this up to consider the lowest point of the face rather than the origin of the group, I will need to give this some additional thought.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          For the month of September I will be running the following promotion:
          If you purchase or renew any of the BIM plugins during the month of September you will be entitled to a complimentary license for the Medeek Electrical extension. This promotion is only valid until September 30th.
          Note, that if you already own an existing license for the electrical plugin then this promotion will allow you to further extend your license expiration of that plugin by an additional year.
          If you purchased or renewed one of the other extensions in the previous two weeks (Sept 1 thru Sept 14) you are also retroactively eligible for this promotion, please contact me via email to take advantage of this offer.
          design.medeek.com
          • medeekM
            medeek
            Version 1.0.8 - 09.28.2019
            • Fixed a critical performance bug that affects all the modules within the extension.
            *** CRITICAL PERFORMANCE UPDATE ***
            If you are noticing a slowdown of the plugin performance after multiple edits to an electrical fixture, this fix will resolve that issue. This issue affects all previous versions of the plugin.
            design.medeek.com
            • medeekM
              medeek
              I've had a lot of requests lately for floor mounted outlets. I've gone ahead and created some low poly models of the Leviton series:
              301 Moved Permanently
              (www.leviton.com)
              View model(s) here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              If there is interest in other brands of floor outlets please let me know. The Hubbell-Raco (6224) also interests me but I haven't had a chance to create a model of it yet and I have been unable to find any detailed dimensional data on it:
              (www.hubbell.com)
              design.medeek.com
              • medeekM
                medeek
                The second toolbar will now include an icon for floor mounted outlets:
                design.medeek.com
                • medeekM
                  medeek
                  Version 1.0.9 - 11.24.2019
                  • Added the "Draw Floor Outlets" and the "Draw Misc. Fixture" function to the secondary toolbar.
                  • Enabled the ability to draw misc. fixtures with Medeek wall assemblies or any wall geometry. Enabled misc. devices include: Thermostats, doorbell buttons, doorbell chimes, and doorbell transformers.
                  http://design.medeek.com/resources/images/electrical_ii_su_menu_active.jpg
                  http://design.medeek.com/resources/trussplugin/images/truss_su599_800.jpg
                  View model here:
                  3D Warehouse
                  Additional fixture components (ie. other manufacturer's doorbell models etc...) can easily be utilized by placing them into the appropriate sub-folder of the plugin's library/misc sub-folder.
                  design.medeek.com
                  • medeekM
                    medeek
                    Version 1.1.0 - 12.01.2019
                    • Fixed a minor bug in the General tab of the global settings.
                    • Enabled the ability to draw floor and ceiling outlets.
                    http://design.medeek.com/resources/trussplugin/images/truss_su603_800.jpg
                    The included outlets: Raco 5500, Leviton 25249 (Nickel and Brass) Series, Standard Duplex Outlet.
                    The plugin automatically detects whether the outlet is a floor or ceiling outlet and assigns the appropriate symbol. This may require some further refinement for outlets mounted to slightly inclined floor or ceiling surfaces, I will be testing this particular situation further.
                    User defined outlets can be utilized by dropping the component files into the appropriate library sub-folders: library/fc_rcpt/gang1 or library/fc_rcpt/gang2
                    The default label for floor/ceiling outlets is 'RCPT', however this can be set independently from wall mount outlets in the global settings.
                    design.medeek.com
                    • medeekM
                      medeek
                      Has anyone ever seen or used a symbol for a duplex switch?
                      https://images.homedepot-static.com/productImages/dc83dd18-43d4-4887-8ae8-4a0f70a16739/svn/white-leviton-light-switches-r62-05224-2ws-64_1000.jpg
                      design.medeek.com
                      • medeekM
                        medeek
                        Version 1.1.1 - 12.04.2019
                        • Added additional 240V duplex and simplex outlets to the built-in library: NEMA 6-15R and NEMA 6-20R.
                        • Added some simplex outlets to the floor outlet built-in library.
                        http://design.medeek.com/resources/trussplugin/images/truss_su604_800.jpg
                        I'm wondering with the undesignated 240V outlets if I should provide the NEMA number (ie. 6-20R) next to the 2D symbol. I would assume that this would be very useful information, a 240V receptacle can take many forms and various amperages.
                        design.medeek.com
                        • medeekM
                          medeek
                          Version 1.1.1b - 12.04.2019
                          • Added more 20A (NEMA 5-20R) outlets to the outlet module: GFCI, WP GFCI, USB etc...
                          Creating a few new electrical components gives me a much needed break from the code and is actually quite relaxing. I'm at the most difficult part of the complex roof module, so I'm taking a couple days to clear my head so that I can take a fresh crack at it and allow myself to think outside the box if required. I find that sometimes it helps to take a break sometimes, which effectively takes the blinders off, and then alternative (better) solutions almost magically appear.
                          If there are any specific outlet or fixture types you would like added please email me.
                          I apologize that I have not provided a solution for other electrical standards yet. Eventually I will do this but I'm not ready to bite it off just yet.
                          Even if you do not purchase the plugin, I think it would be worthwhile to download the trial version just for all of the pre-built electrical components now available in the library sub-folder. Of course, I would prefer that you purchase the plugin but if you don't need the parametrics and some of the other automated features then even the trial version and the library files might be quite useful.
                          design.medeek.com
                          • medeekM
                            medeek
                            Version 1.1.2 - 12.24.2019
                            • Added the "Draw Low Voltage Panel" function to the secondary toolbar.
                            • Enabled the ability to draw low voltage panels with Medeek wall assemblies or any wall geometry. Included Structured Media Panels: Leviton 47605 (14", 21", 28", 42").
                            http://design.medeek.com/resources/trussplugin/images/truss_su607_800.jpg
                            View model here:
                            3D Warehouse
                            For now only the flush cover models are included however if I find the time I will model up the hinged cover variants and include those as part of the standard library.
                            design.medeek.com
                            • medeekM
                              medeek
                              I'm trying to figure out how to best handle the situation where outlets and switches are vertically sitting on top of each other:
                              I'm thinking about adding an advanced parameter which allows offsetting the symbol and label a custom amount so that the symbols don't all pile up on top of each other.
                              https://aws1.discourse-cdn.com/sketchup/original/3X/d/e/defeb5852a72cbaf1da8d509e2dc46c79a8d2005.jpeg
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.1.2b- 12.25.2019
                                • Added an offset parameter (advanced options) for switches which allows the symbol and label to be offset from the wall.
                                http://design.medeek.com/resources/trussplugin/images/truss_su609_800.jpg
                                design.medeek.com
                                • medeekM
                                  medeek
                                  Version 1.1.3 - 01.01.2020
                                  • Added additional (120V, 20A) outlets to the built-in outlet library.
                                  This update includes various (20A) USB and GFCI outlets.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    For many of the electrical fixtures the designer can use their own electrical components as well as the ones included with the plugin. Here are a few hints/tips on how to do this:
                                    1.) You need remove the spaces from file names with spaces in them. Either delete the spaces or replace them with underscores like I have done with my filenames.
                                    2.) With your electrical light fixtures be sure that fixture base is located at the origin of the model within your component file. This actually applies to any electrical fixture. The location of the component with respect to the origin determines where it will land within the model once it is inserted by the plugin.
                                    3.) When you insert the (ceiling mount) light fixture below make sure you select "ceiling" and not "wall" for the mounting position from the parameter list.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Per a customer request I will probably add in two additional user definable fields for all electrical fixtures:
                                      1.) Description
                                      2.) Circuit
                                      Unlike other parameters these will default to a nil value.
                                      Are there any other parameters like these that I should add while I am updating each electrical fixture type to include these additional two parameters?
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        Version 1.1.4 - 02.16.2020
                                        • Added optional metadata parameters for switches: description, circuit.
                                        http://design.medeek.com/resources/trussplugin/images/truss_su649_800.jpg
                                        Once I've received some additional feedback on this new feature I will probably add the metadata parameters for all other electrical fixtures.
                                        Further down the road I can probably also setup a tool which will allow the user to quickly visualize which switches, outlets etc... are on a particular circuit.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          Version 1.1.5 - 04.28.2020
                                          • Added a Global Reset button in the General tab of the Global Settings.
                                          • Plugin files switched from .rbs to .rbe encryption.
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            My youngest son is looking for a job this summer and with the situation being mostly under lockdown I would rather him work from home, with me.
                                            As such I'm proposing that he help me by creating a number of models for the Electrical plugin so that I can extend it to include the British Standards (BS 1363). I have had a number of requests for other electrical standards and by far the most highly requested has been the British equivalents of our NEMA sockets and switches.
                                            The BS 1363 (Type G) seems to be quite widespread throughout the world.
                                            I have a few models already from a few months prior but any additional information on receptacles and switches as well as standard boxes used in the trade would be greatly appreciated.
                                            design.medeek.com
                                            • 11
                                            • 6 / 11
