    Medeek Wall Plugin
    1.5k Posts 27 Posters 1.1m Views 26 Watching
    • pbacotP Offline
      Good for you! That's like having some advertising and training done for you as well. as seeing how others experience the plugins.
      • medeekM Offline
        medeek
        This particular design for a storage unit was originally created by me about four years ago for a local client here in Western Washington. I had another purchase of this planset from my website and the customer requested that I also provide the 3D model so I thought this might be a good opportunity to test out the plugins and see what difficulties I would encounter with a fairly simple but large model:
        http://design.medeek.com/resources/trussplugin/images/truss_su531_800.jpg
        Framing:
        http://design.medeek.com/resources/trussplugin/images/truss_su532_800.jpg
        Wall Framing and Foundation:
        http://design.medeek.com/resources/trussplugin/images/truss_su533_800.jpg
        The floor plan (originally drawn in AutoCad):
        http://design.medeek.com/plansets/COMMERCIAL/STORAGE8443/preview/STORAGE8443_FLOORPLAN_REVA1.jpg
        View model here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        This planset can be purchased here: http://design.medeek.com/plans/search.pl
        Overall the process of creating the model went quite smoothly, I was pleasantly surprised. However I did note a few things:
        1.) When you have a large wall and are putting an excessive amount of doors or windows into it the regen time starts to become noticeable. Not sure what the fix is here but I will give it some thought.
        2.) With extremely large truss assemblies it may be advantageous to turn off the metal connector plates, the model gets a bit heavy and regen times are also affected.
        3.) I need to add in more light fixtures (ie. external wall packs)
        4.) There is currently no way to add a vent or window into a gable truss. This had to be done manually.
        5.) The Simpson holdown DTT2Z was not being properly rotated, additionally I needed to utilized a Titen HD bolt in this model, I will address that this evening and release and update of the Wall plugin shortly.
        6.) Anchor bolts typically need to be manually moved around and deleted. It would be nice to figure out a way for the plugin to preserve the manual manipulations even with a regen when the assembly is edited.
        7.) I don't have a way to deal with two wall intersecting each other in a "CROSS", in the model I simply had them pass through each other. I will need to give this some further thought.
        8.) I don't like the way I am creating/managing the components for slab reinforcement (mesh or rebar). I will need to change this up slightly. It works but performance suffers on large SOG foundations.
        9.) Obviously I need to spend some time further integrating the estimating module, that would be really nice for generating a materials list.
        10.) The parametrics of all of the plugins is really nice and to be honest, essential.
        11.) I manually copied over some more gutter downspouts since I need more for this long gutter run. By adding CUSTOM into the instance name I am able to maintain these additional downspouts even with a regen of the truss assembly.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM Offline
          medeek
          Version 1.1.3 - 09.23.2019
          • Fixed a bug with the placement of Simpson's DTT2Z holdown and replaced included component with a low poly version.
          • Added the option for Titen HD holdown anchor bolts: THD50500H, THD50600H, THD50800H, THD501200H, THD501400H, THD501500H.
          http://design.medeek.com/resources/trussplugin/images/truss_su530_800.jpg
          design.medeek.com
          • medeekM Offline
            medeek
            Version 1.1.4 - 09.28.2019
            • Fixed a critical performance bug that affects all the modules within the extension.
            *** CRITICAL PERFORMANCE UPDATE ***
            If you are noticing a slowdown of the plugin performance after multiple edits to a wall assembly, this fix will resolve that issue. This issue affects all previous versions of the plugin.
            design.medeek.com
            • medeekM Offline
              medeek
              The question "Can I manually edit my wall assemblies?", seems to come up quite often.
              ***** Important Information *****
              The parametrics (editing) with regards to the plugin(s) require that when you edit any wall assembly, roof assembly, foundation assembly etc... it regenerates the geometry from the parameters stored for that assembly.
              If you are going to manually edit an assembly just be sure not to regen it, by editing it or adding windows, doors etc... after you have done any manual edits. When you edit an assembly it essentially removes the existing geometry created by the plugin and redraws it. If you have altered the geometry created by the plugin it will also remove any of those manual edits.
              You can effectively lock an assembly by removing the instance name (or replace it with something else). When you remove the key words in the assembly instance name the plugin(s) no longer recognizes the assemblies as something they can edit and hence they become "locked" for editing.
              You can also unlock a valid assembly (provided it still has its attribute library) by putting the keywords back into an instance name. You will notice that each type of assembly has specific keywords utilized in its instance name.
              The problem with manual editing is that, yes you can do it, but the plugins have no way of knowing what changes you have done to the assembly and when it goes to rebuild/regen the only information it has is the parameters stored in its attribute library (database) for that assembly. If you explode the group that contains the assembly the attribute library for that group (assembly) is deleted and even if you were to group the assembly back together the attribute library will no longer be present and hence the assembly is no longer a parametric Medeek assembly.
              If you want to include custom components or groups within your assemblies (wall, truss etc...) and you want those "additional" geometric objects retained after a rebuild then you can accomplish this by including the keyword "CUSTOM" or "custom" within the sub-group or components instance name.
              Also note that any non-grouped geometry (ie. edges and faces) will also be retained within the assembly by default.
              In fact, this is exactly how the electrical plugin works in concert with the Wall and Truss plugins. All of the electrical groups within your wall panels, utilize a special key word in their instance names. This allows them to be retained within the larger assemblies.
              There is a method to my madness.
              design.medeek.com
              • medeekM Offline
                medeek
                Gable Wall Workaround:
                A quick tutorial on how to manually edit a wall with the Trim tool to create a balloon framed gable wall.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.1.5 - 11.27.2019
                  • Added a rotation parameter for in-wall columns.
                  http://design.medeek.com/resources/trussplugin/images/truss_su602_800.jpg
                  Previously I was listing two sizes in order to get the rotated version (ie. 2x6 and 6x2) of a column size, however this proved to be a clunky and a non-scalable solution. This update rectifies this limitation.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.1.6 - 12.08.2019
                    • Improved the stability and execution speed of the wall edit menu and the window edit menu.
                    This improvement is courtesy of my recent work on the complex roof module of the truss plugin. I've improved the speed and stability of my algorithms for transferring data between the ruby code and the javascript. I will now need to update every other HTML menu found with the wall plugin and eventually within all of the plugins.
                    The wall edit menu contains the most parameters and hence its stability will be improved significantly by this code change, that is why I addressed it first. Other edit menus include: doors, garage doors, stairs, beams, etc...
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Version 1.1.6c - 12.11.2019
                      • Updated the garage door edit menu and the door edit menu.
                      • Added standard sizes of LVL headers (1-3/4") to the built-in header library: 7-1/4, 9-1/4, 11-1/4, 11-7/8, 14, 16.
                      Within the global settings under the custom header settings the user can easily setup additional LVL headers. I setup these standard sizes for convenience, however any size (width and depth) may be defined.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        Version 1.1.7 - 12.21.2019
                        • Enabled the "Wall Split" tool within the Medeek Wall Tools toolbar.
                        I will release a tutorial video explaining the use of this new tool and what circumstances would typically require its use.
                        (Click GIF to view animation)
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Tutorial 9 - Split Wall Tool (6:36 min.)
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            You mean like this? (click to view animation)
                            View model here:
                            3D Warehouse
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.1.7b - 12.25.2019
                              • Enabled temporary (construction) dimensions for the wall split tool.
                              • Added a vertical offset to the holdown symbol(s) to eliminate Z-fighting with the wall panel top plate.
                              http://design.medeek.com/resources/trussplugin/images/truss_su610_800.jpg
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Something that I have had on the to-do list for quite a while but have avoided it due to the many permutations and pitfalls: Stacked Windows
                                https://aws1.discourse-cdn.com/sketchup/original/3X/f/a/fa97f34608a78a0fdb712a3826c19565ba62342b.jpeg
                                I have some additional testing to do, but so long as the windows line up (same x-position along wall) and they are the same width (as shown) then the algorithm seems to be successful.
                                The real problems arise when the windows partially overlap, or even if they are aligned but the windows widths are different. Those type of scenarios create all kinds of framing permutations which then becomes a real can of worms for the logic. I may eventually tackle it but for now I’m going to make some simple assumptions, so that I don’t become too bogged down with this problem.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  My original algorithm was too simplistic, it did not account for multiple window stacks within a wall panel, now I have that resolved:
                                  The final step is to make sure that the blocking and insulation modules are compatible with stacked windows. As can be seen in this screen capture there is still an issue with stacked windows and blocking (right side).
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Version 1.1.8 - 01.06.2019
                                    • Added a "Stud Spacing Offset" parameter which allows for custom stud spacing/placement.
                                    • Enabled stacked windows within a wall panel.
                                    http://design.medeek.com/resources/trussplugin/images/truss_su616_800.jpg
                                    http://design.medeek.com/resources/trussplugin/images/truss_su615_800.jpg
                                    View model here:
                                    3D Warehouse
                                    Both of these items have been on the to-do list for quite some time and together constitute a fairly substantial upgrade to the functionality of the plugin. The offset parameter has been requested numerous times over the last few weeks.
                                    This update does not yet allow for stacking of windows/doors or doors/doors. However, now that the logic path has been established I should be able to enable these additional possibilities much more quickly. I will see if I can knock this one out this coming week.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      The same stacked windows as below but with the insulation included:
                                      I haven't finished the window/door stacking algorithm yet but it occurred to me that window over door is the most common configuration and not the other way around. In fact, I really see no reason to have a door over door algorithm either. Correct me if I'm wrong.
                                      design.medeek.com
                                        No doors' emergency exit on the upper levels possible ?
                                        • medeekM Offline
                                          medeek
                                          Now looking at stacked windows over doors:
                                          It's also possible that you might have multiple stacked windows over top of a door as shown to the right. A few things to consider here.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Yes, but in that case it will probably be a separate wall panel and not balloon framed to the second level.
                                            design.medeek.com
                                            • 74
                                            • 75
                                            • 8 / 75
