    3D Truss Models
    1.5k Posts 32 Posters 1.9m Views 31 Watching
    • medeekM
      medeek
      I've also been giving some thought to gutters. If there are no half hip or gable conditions the gutter will wrap completely around the roof.
      Otherwise the gutter will be broken into one or more sections.
      Downspouts are more of an issue. With a complex roof the positioning of downspouts needs to be more customizable. I would like to implement a system where the user can select standard locations to position downspouts along a gutter run. For instance at either end or at the middle, this should provide enough flexibility for most situations.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • jujuJ
        juju
        Are you going to provide an interface where parameters will be set, to be adhered to, for the sizing of gutters and downpipes (thus relating to number of) based on the plan area (not actual, but measured perp from above) of the roof served?
        • medeekM
          medeek
          Tutorial 16 - Introduction to Complex Roofs (19:42 min.)
          I did forget to mention the "Edit Outline" function which can be initiated by right clicking on the roof assembly. However, if you have a number of customized roof planes the results may become unpredictable, especially if the the outline is dramatically changed. The feature will need some further refinement.
          design.medeek.com
          • medeekM
            medeek
            First look at a gutter fully wrapping a complex (hip) roof:
            http://design.medeek.com/resources/trussplugin/images/truss_su568_800.jpg
            Note the 3/4" offset from the sub-fascia since I have soffit and fascia enabled. The 3/4" thick fascia is not drawn yet, hence the gap.
            I've also set my vertical offset to 1" for the gutter.
            design.medeek.com
            • medeekM
              medeek
              Version 2.5.6 - 10.11.2019
              • Added gutters for complex roofs.
              http://design.medeek.com/resources/trussplugin/images/truss_su569_800.jpg
              View model here:
              3D Warehouse
              (3dwarehouse.sketchup.com)
              On this particular model I've employed a vertical offset of 1" and a gutter extension of 1.5" with a K5 style gutter, other gutter styles available.
              I have not enabled downspouts yet as I need to come up with a better system for handling these. I think I have a new system figured out but I need to work on the details before I'm ready to implement it.
              design.medeek.com
              • medeekM
                medeek
                The problem with complex roofs is that I am only scratching the surface right now. There are quite a few permutations that are possible that are quite common with many residential designs that I still cannot handle with the current complex roof module.
                Consider this relatively simple example:
                3D Warehouse
                With this case the fascia is at two levels. At the back corner on roof plane A you have what I call a 3/4 Hip (kind of hybrid between a half hip and a hip, one side is a hip and the other is technically a half hip). This causes the fascia line to rise by 24".
                Where roof plane E meets roof plane D, you have one roof plane dying into the other and creating a "Flying Valley" and the other roof plane terminates at the wall below (a partial gable end?).
                I guess I was wrong there are "flying valleys" after all.
                The problem with trying to construct this particular example with my proposed secondary roof module is that its a little more complicated than that. Rather than two separate roof assemblies the roofs are technically merged. Also the 3/4 Hip configuration kind of requires that the roof assemblies are one construct.
                This example really has me scratching my head right now.
                What does jump out at me is that when you are dealing with an inside corner (angle between walls is greater than 180 deg.) the roof planes die into each other creating a partial gable and a flying or hanging valley.
                When you have an outside corner (angle between the walls is less than 180 deg.) you then end up with a 3/4 hip. Two additional solutions might be a gable or half hip with unequal legs. If you were to keep making the setback of the half hip larger eventually it would degenerate into the 3/4 hip where one leg is now a hip roof.
                design.medeek.com
                • medeekM
                  medeek
                  My original restrictions on the placement of gable ends are too tight. In order to created roofs where you may have a gable on a gable we need to relax things a bit or at least change up the conditionals:
                  http://design.medeek.com/resources/trussplugin/images/truss_su570_800.jpg
                  This further complicates each building element or at least opens up possibilities which did not exist before so I will need to add additional logic for sheathing, cladding, sub-fascia and gutters.
                  Who said complex roofs were going to be easy.
                  design.medeek.com
                  • medeekM
                    medeek
                    Another variation of the gable roof study:
                    http://design.medeek.com/resources/trussplugin/images/truss_su571_800.jpg
                    Gables ad infinitum...
                    The one thing that jumps out here is that gable roof planes cannot be adjacent to each other (or other variants like dutch gable or half hip configurations), gable roof planes are separated by hip planes. Additionally, I will limit the gable option to orthogonal roof planes only (corners must be 90 or 270 degrees).
                    There is always on more thing to add, at some point I hope to have conquered this beast.
                    design.medeek.com
                    • medeekM
                      medeek
                      When you raise the fascia line along a segment of the roof inevitably it must return to same level since a roof is a closed loop. See model here:
                      3D Warehouse
                      I think I can make this work but I'm going to have to drastically change my algorithms to allow for unequal fascia/gutter lines.
                      The other interesting thing with all of this is that the fascia line could step up and down multiple times around a roof.
                      Another observation is that only hip roof planes technically step up or down, gable roof planes/edges are controlled by the adjacent hips.
                      design.medeek.com
                      • medeekM
                        medeek
                        A couple of interesting gable roofs:
                        http://design.medeek.com/resources/trussplugin/images/truss_su572_800.jpg
                        Looks like I have the roof primitive working for "interior" gables. Now I just need to sort out the details for sheathing, cladding, sub-fascia and gutters. An interior gable is defined as a gable roof plane with one or more corner angles of 270 degrees (orthogonal inside corner), hence an interior gable.
                        For now I'm not going to allow interior dutch gables or half hips. As long as the angles, at both corners, are 90 degrees then you will be able to place a dutch gable or half hip on that roof plane. However, the gable is a little more flexible and will allow some interesting configurations, as shown.
                        design.medeek.com
                        • medeekM
                          medeek
                          Notice how the sheathing is now projecting underneath the gable overhangs:
                          http://design.medeek.com/resources/trussplugin/images/truss_su574_800.jpg
                          Now I just need to get the cladding to behave similarly and then a few adjustments to the sub-fascia and gutters.
                          design.medeek.com
                          • medeekM
                            medeek
                            First look at cladding correctly displaying for interior gables:
                            http://design.medeek.com/resources/trussplugin/images/truss_su575_800.jpg
                            The sub-fascia for interior gables is interesting because in most cases one or both side will die into another roof plane, however this is not always the case as can be seen in the example to the far left. Logic to include all of these possibilities now must be constructed.
                            Unlike the much simpler exterior gable the position of the peak of the interior gable roof has no direct relation to the perimeter points that define this gable's edge. Due to this inconvenience I cannot (easily) mathematically calculate the sub-fascia, I must use the roof primitive geometry to derive the correct points and position, again more emergent behavior. In short, the roof primitive is smarter than I am.
                            design.medeek.com
                            • medeekM
                              medeek
                              First look at sub-fascia for interior gables:
                              http://design.medeek.com/resources/trussplugin/images/truss_su576_800.jpg
                              Bit of a struggle to consider all of the possible permutations for this type of roof but I think I have finally arrived at a robust solution.
                              I just need to consider gutters and then we can proceed with the actual framing of the roofs.
                              I've also heavily modified my error checking code for the roof primitive to make the overall performance more robust. With the addition of interior gables there is more probability that the designer can create roof design that does not have valid geometry. Further testing will be required to try and eliminate these scenarios or further augment the areas that are having trouble with these situations.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 2.5.7 - 10.14.2019
                                • Allowed the option for interior gables within complex roofs.
                                • Fixed a bug in the gutter module for complex roofs.
                                http://design.medeek.com/resources/trussplugin/images/truss_su577_800.jpg
                                I need to do some traveling in the next few days but I just wanted to get the update out the door before taking a break from the code.
                                View model here:
                                3D Warehouse
                                design.medeek.com
                                • medeekM
                                  medeek
                                  As I'm taking a break from the code before my trip it dons on me that the soffit & fascia, primarily the fascia is probably more important than the actual roof framing right now. If I have that feature enabled it will allow the designer to complete his or her elevations. Whereas the framing is a critical future feature but does not really come into play for the actual construction documents.
                                  With that in mind, I think my next big push will be to complete the soffit & fascia, then I will begin the framing algorithms. The good news is that the fascia algorithms will be very similar to the sub-fascia so most of my work there is already done.
                                  Also speaking to a number of plugin clients earlier today it took me back at how many of them actually use AutoCad for their construction documents, and just import parallel projections from SketchUp as a DXF/DWG. Even though the resulting mess of "dumb lines" in your AutoCad drawing is not optimal I suppose it is still quicker and easier to do this rather than to try and actually draw a complex roof elevation from scratch.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    More gables:
                                    View model here:
                                    3D Warehouse
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      I will be out for 2 - 3 days however you can probably reach me by phone if it is an emergency, however I won't have any computer in front of me so it may be hard to do any significant support or troubleshooting.
                                      I had an interesting conversation with a client today and he wondered if I disliked engineering, and that is why I am now developing plugins. I do not dislike engineering, in fact I really would like to get back into it but I would like to get back into it with SketchUp and my plugins leading the charge.
                                      The one problem I have with the way residential engineering is done (or at least the way I was doing it), is the lack of automation. Yes, there are plenty of tools out there (spreadsheets, Forte etc...) that help with the calculations, however I want something even more streamlined. I want a program that already takes a 3D model of a structure and then is somehow smart enough to propagate the loads throughout that structure and run all the numbers automatically. This is the way engineering should be done in the 21st century, we have the computers, and yes we have the technology, we just need to leverage it so that we can stop wasting our time on tedious chores.
                                      To be honest, most of residential engineering is quite mundane. There is some engineering judgement that comes into play in certain situations however for the most part it is merely taking some inputs and running them through a number of AWC and ASCE equations and giving the result a GO or NO-GO. This is exactly what computers were built for.
                                      This is my vision for the engineering module and what it should be able to do:
                                      I should be able to enter the site criteria for a project and then with the push of a single button crunch all of the engineering calcs for that model. The items that fail will be flagged. I modify those items accordingly (upgrade a header to a larger size), and then run the numbers again, until everything passes. I then click the generate report, a PDF is generated. I review it one last time, checking for errors and making sure all the inputs and outputs look reasonable and consistent, and then print out a paper copy, and stamp and sign it.
                                      I've decided my time is much better spent developing a proper solution like this rather than continuing my practice of manually crunching numbers for local residential clients. Undoubtedly, I would make more money working on local engineering projects than I would make working on just these plugins (full time). In fact, I even turned down an employment opportunity last year for a really nice, six figure income so that I could specifically pursue the Wall plugin full time.
                                      Currently I'm probably only making only about half of what I could make working strictly as a conventional engineer or corporate drone, but with me it has never been about the money. One has to look at the big picture with these things. I love what I do, I have full ownership, and I am able to help hundreds, maybe thousands of architects, engineers and designers rather than just a handful of local clients. Every day I wake up I get to decide what needs to done, I control the direction I take, even though my customers do guide me. I am also able to leverage both my love for programming and my love of engineering. I didn't choose this path, it chose me.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        First look at fascia with complex roofs:
                                        http://design.medeek.com/resources/trussplugin/images/truss_su579_800.jpg
                                        View model here:
                                        3D Warehouse
                                        Now I just need to look at the various permutations for various roof end configurations (ie. gable, half hip, dutch gable).
                                        With gable and half hip configurations we also have Boxed, Angled or Gable style configurations.
                                        design.medeek.com
                                        • medeekM
                                          medeek
                                          First look at a half hip fascia and rake with a boxed soffit:
                                          http://design.medeek.com/resources/trussplugin/images/truss_su580_800.jpg
                                          design.medeek.com
                                          • medeekM
                                            medeek
                                            First look at the soffit on a complex roof:
                                            http://design.medeek.com/resources/trussplugin/images/truss_su581_800.jpg
                                            Unlike the sub-fascia and fascia the soffit (and its miter cuts) are also a function of the overhang at each roof plane, therefore the computation of the correct width of the soffit is a bit more complicated with asymmetric pitches.
                                            The example shown is a symmetric roof with hips all the way around. The inclusion of gables, dutch gables and half hips along with the soffit box extension parameter makes for a much more complicated problem.
                                            design.medeek.com
                                            • 63
                                            • 64
                                            • 65
                                            • 66
                                            • 67
                                            • 76
                                            • 77
                                            • 65 / 77
