    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 573.0k Views 71 Watching
    • N Offline
      NBG
      The 5th version is realy quicker than the 3, that's nice
      • N Offline
        NBG
        is there a way to have a hole instead of a handle? So not a profile that goes from one side of the door to the other, but just for example a rectangular hole of 120x35mm on the top of a small door.
          Garry K
          Currently not. However I have had a number of requests for sliding cabinet doors.
          • N Offline
            NBG
            Would be nice indeed, the sliding doors, and those type of handle.
            EDIT SEPTEMBER 2
            for the question below, I just forgot to switch from "sink" type cabinet after generating this one. So problem solved
            OTher question: since i upgraded I have a problem with drawers. If I choose 1 drawer, there is no drawer box in the cabinet, so nothing happen if i click "interact".
            If I choose more than 1, it's the same for top drawer, but not for the other below.
            It looks like an option like "make top drawer as fixed panel" but I don't find anything like that.
            About drawer, you mentionned drawer systems template... I'd love to have Blum Legrabox. I don't know how common they are among your client though.
              Garry K
              You should email me directly via cabmaker32 - that is if you want quick a response.
              The manual states that a cabinet drawer height of 0 - means do not include a drawer box. Set it to -1 if you want CabMaker to calculate drawer box heights. There are situations where users do NOT want a drawer box since they want to use other specialized hardware.
                Garry K
                Getting ready to release CabMaker 5.0.147 and CutMaster 4.0.1.90
                CabMaker
                1. Fixed PROJECT tab Finished Panels section.
                2. Added Rotation Group for CutMaster
                3. Cleaned up Finished Panels and Finished Backs for Door Panel parameter.
                CutMaster
                1. Added User Flag (Rotation Group). You can now allow various parts to rotate which increases yield.
                  There are 4 settings
                  0 - use sheet grain
                  1 - do not rotate
                  2 - can rotate
                  3 - must rotate
                • N Offline
                  NBG
                  HEllo,
                  I can't figure out how to add a simple color to CAbmaker. I'm trying to follow the steps described in the manual (page 206), I already did it with a texture, but I'm stuck at step 1 because it's not a texture but a color this time.
                  When I go in sketchup in the materials panel, if I right click on the color I want to add to cabmaker, I can't select "export texture image". It's grayed out.
                  If I choose a material which is clearly a texture (wood, metal...) the option is available.
                  any workaround?
                  I'm trying to add a black that's a bit "less black" as the one in cabmaker is black as this new M.I.T. material, and make every details invisibles, even with shadows.
                  And I want a real anthracite gray too. the dark gray is not very dark.
                  • N Offline
                    NBG
                    Hello,
                    I got an error: "undefined method '[]=' for nil:NilClass" while trying to select the "omit drawer front" option for a sink cabinet.
                    So the cabinet exist. It is defined as a sink cabinet. It has 2 drawers. So far so good. But if I edit it and try to change juste that, I get this error.
                    If I choose tip ou tray it works, but not "omit..."
                    br,
                      Garry K
                      Martin,
                      As previously stated - for support please email me directly.
                      Garry
                        Garry K
                        Notice that cabinet 1 has 15 parts and is completed by sheet 9
                        Cabinet 32 has 7 parts and starts on sheet 24 and is completed on sheet 34.
                        The whole idea here is to drastically reduce handling of large parts and to allow the completion of cabinets sooner. Although the material yield is a bit lower the labor savings should be substantial.
                          Garry K
                          Adding and removing colors is quite simple
                          Here are a few lines from colors.txt
                          Make sure you copy the file and put it into the config folder
                          1. The first line is a new color that shows up as pink_1 where the actual color is rgb the final = sign separates the rgb value from the opacity (optional).
                          2. The second line is also a new color but this time shows up as pink_2 where the actual color comes from the hex value. Again opacity follows the second = sign (optional)
                          3. The third line is a texture (because it isn't an internet named color) and needs to be included in the textures.txt file where it will be specified as a bmp or a jpg
                          4. The fourth line is an internet color
                          pink_1=255,176,216=0.99
                          pink_2=#FFFACD=0.99
                          brushed_aluminum
                          aqua
                          Just omit internet colors and or textures from this file and your drop down list will be paired down. Also note that the order of colors / textures in the drop down list follows the order that they are in the colors.txt file.
                            Garry K
                            I was able to duplicate the nil class error when choosing 'Omit Drawer Front'. The fix will be in the next release which is fairly soon.
                              Garry K
                              I've been asked to show a tighter distribution. It adds a sheet of material but cabinets come off the CNC sooner.
                                Garry K
                                CabMaker 5.0.148 and CutMaster 4.0.1.90 are now available from my website
                                CabMaker
                                1. Added rotation group to Cabinets 2 tab
                                CutMaster
                                1. Added Sliding window for Cabinet number priority optimization.
                                2. Added Rotation control during import.
                                3. Added Rotation Drop Down for each part.
                                4. Added narrow part layer name modifier.
                                5. Fixed Tall cabinets - no longer drilling hinge holes twice.
                                6. Fixed Backs with notches for hanging brackets.
                                7. Added option to jump to first thumbnail after optimize.
                                8. Fixed Off cuts.
                                  Garry K
                                  CutMaster 4.0.1.91 is now available.
                                  1. Added parts padding for small parts with area less than x. This is to help isolate small parts because vacuum is often insufficient especially when small parts are at the outside edge of a sheet of nested parts.
                                    Garry K
                                    I've had a request to handle face frame cabinets for angled corners differently. Please respond if any of you are interested.
                                    • N Offline
                                      NBG
                                      HEllo,
                                      I just discovered that you could use the same sketchup licence on 2 computers provided that you don't use both at the same time. This is great news to me.
                                      So I was wondering if it was something that you could consider for CAbmaker? I'm pretty sure that almost every pro here would love to be able to do that (desk comptuer and laptopt, or laptop and home computer).
                                        Garry K
                                        I decided long ago to keep prices low so that hobbyists and retirees could afford a license.
                                        I also decided that companies that wanted my plugins on a second computer could afford a second license (my prices are quite low) or they can put a single license on their laptop and use that in the office.
                                        I also provide perpetual license so users do not have to upgrade if they do not want to. I give new users free upgrade if they purchased a license within 3 months of a new major release. I offer users free updates for any release while still in the same major version. And I offer a discount for users that have purchased the last major version more than 3 months ago (moving 3 to 4 etc)
                                        If anyone is confused by this then please email me.
                                        • N Offline
                                          NBG
                                          Hello,
                                          When I select "top" or "bottom" for "Handle Location:" in drawer section of project tab, I end up with handle on the edge of the face (instead of a few cm from the top or the bottom). I cannot find where this come from. I don't see any option that supposed to manage this.
                                          br,
                                            Garry K
                                            The handle is placed at stile width / 2.
                                            I'm guessing that you have slab doors and have set the stile width to 0
                                            With your input, this post could be even better šŸ’—
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 27 / 32
