    Foundation Plugin
    451 Posts 15 Posters 580.3k Views 15 Watching
    • medeekM Offline
      medeek
      Version 1.4.6 - 09.14.2019
      • Enabled the "Draw Blockout" tool for polyline stemwalls.
      • Enabled the "Edit Blockout" tool for polyline stemwalls.
      • Enabled the "Move Blockout" tool for polyline stemwalls.
      • Enabled the "Delete Blockout" tool for polyline stemwalls.
      http://design.medeek.com/resources/images/foundation_blockout_su_menu_active.jpg
      I will put out a short tutorial demonstrating this new tool even though it is mostly self explanatory.
      One to thing to note is that this tool only works for the "new" polyline stemwalls. I'm not sure yet what I'm going to do with the old stemwall tool. Basically everything you can do with old tool you can achieve with the new polyline tool (with the exception of joist pockets). I will need to give this some more thought.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Tutorial 7 - Blockouts in Polyline Stemwalls (8:35 min.)
        Unfortunately, I forgot to demonstrate the CMU option with the blockouts, so I will leave that up to the user to try that out for themselves.
        If you are using stemwall foundations at all this newest feature is critical in my opinion. Manually creating blockouts in your stemwalls renders the parametric ability of the plugin mute, hence this latest addition was necessary.
        design.medeek.com
        • medeekM Offline
          medeek
          It just occurred to me that the method/algorithm I use to remove rebar for a blockout can also be used to remove slab rebar or mesh from a slab depression. Now I have a solution for the slab depression reinforcement problem.
          The only potential issue I see with this is the shear number of solids (reinforcement) that may need to be trimmed, especially if the user has specified wire mesh. I will give this some additional consideration and see if it will work.
          It also just occurred to me that a stemwall opening (door & window) tool is very similar to the tool I just created and I can probably utilize almost 90% of the code I just created to quickly put together a tool for creating openings in stemwalls. So much for a relaxing Saturday evening and Sunday, I’ve got this.
          design.medeek.com
          • medeekM Offline
            medeek
            What is the convention for calling out openings (windows and doors) in a basement foundation plan?
            Do you list the actual size or is it similar to floor plans where you are using the nominal sizes (ie. 3040, 3068, etc...) but the actual opening is something entirely different?
            To be honest, in my neck of the woods I don't see very many basement plans because of our high water table, most everything is stemwall foundations with crawl spaces.
            Also would it be useful to have the plugin provide window and door bucks? If so what should that geometry look like?
            As far as the actual window and doors, my plan is to eventually split out the window and door module from the wall plugin so that it can also be utilized to place windows and doors into basement walls.
            design.medeek.com
            • medeekM Offline
              medeek
              As nearly I can tell the convention for doors and windows in basement plans is the same as in regular framing, so here is my proposed solution for openings in foundation walls:
              http://design.medeek.com/resources/trussplugin/foundation_openings_800.jpg
              Note that the header height is measured from the top of the door or window opening with the RO taken into account.
              So for example a standard 3068 door would have an actual opening width of 38" and an actual opening height of 82.5" (blockout dimemsions), assuming the rough opening dimensions given. Assuming that a 4" slab is poured on the top of the footing then the header height would need to be 84". The height of the top of the door opening measured from the top of the footing would be 80" + 4" + 2.5" = 86.5"
              Correct me if any of this goes counter to common practice.
              However, another way of dealing with the door may be to actually blockout the foundation all the way to the footing so that the 4" slab extends through the doorway (I've seen it done both ways). In this scenario you still want the door height (80") to remain the same so that the callout is still given as 3068, however to maintain the vertical position of the door within the foundation wall the vertical RO would need to change to 6.5" and the header height would need to be 80".
              design.medeek.com
              • medeekM Offline
                medeek
                The seventh and hopefully final toolbar (at least for now):
                http://design.medeek.com/resources/images/foundation_opening_su_menu_active.jpg
                This toolbar will allow the user to create, modify, move and delete openings (two types: doors, windows) within polyline stemwalls.
                Once this toolset is added the plugin I think most of my major functionality issues with the plugin will be resolved.
                design.medeek.com
                • medeekM Offline
                  medeek
                  The proposed parameters for Stemwall Openings (with default values):
                  Opening Type: Door (default), Window
                  Opening Width: 36"
                  Opening Height: 80"
                  Header Height: 84"
                  Horz. RO Offset: 1.0"
                  Vert. RO Offset: 2.5"
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.4.7 - 09.15.2019
                    • Enabled the "Draw Opening" tool for polyline stemwalls: Windows and Doors
                    • Enabled the "Edit Opening" tool for polyline stemwalls.
                    • Enabled the "Move Opening" tool for polyline stemwalls.
                    • Enabled the "Delete Opening" tool for polyline stemwalls.
                    • Fixed a bug with the Edit Blockout tool menu.
                    http://design.medeek.com/resources/images/foundation_su65_800.jpg
                    Similar to the blockout tools this new feature only works with polyline stemwalls as noted in changelog.
                    If you have a lot of rebar in your foundation walls and a lot of openings in those walls then the plugin will have a lot of boolean subtraction to do in order to trim out the rebar as shown, this will cause a performance hit but should not be unreasonable on an adequately equipped PC or Mac. For older machines one way around this is to only toggle rebar on as a final step after all of your other edits to the foundation wall are complete.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Tutorial 8 - Windows and Doors in Polyline Stemwalls (8:31 min.)
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        I'm really enjoying the new parametrics and the blockout functions:
                        http://design.medeek.com/resources/trussplugin/images/truss_su520_800.jpg
                        I initially created the (polyline) stemwall foundation then cut out the garage door with the blockout tool. Then I drew in the slab (polygon) option. At that point I decided I wanted a man door 4" off the right front corner, so I used the blockout tool again to create this opening.
                        Then I realized that slab needed to also flow into this opening so I used the "Edit Slab Outline" feature to modify the outline of the slab and, Voila! Done.
                        No manual edits and no having to delete and then recreate assemblies, I like this.
                        View model here:
                        3D Warehouse
                        (3dwarehouse.sketchup.com)
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.4.8 - 09.17.2019
                          • Added the "Move Stemwall Segment" icon to the stemwall toolbar.
                          • Added the "Move Stemwall Segment" function to the context menu for polyline stemwall assemblies.
                          • Enabled the "Move Stemwall Segment" tool for polyline stemwalls.
                          http://design.medeek.com/resources/images/foundation_stemwall_su_menu_active.jpg
                          I think the best way to explain this new feature is to provide a demonstration. I will be releasing another tutorial shortly showing how this new tool is used. I think you will find it very convenient.
                          Note that openings and blockouts are going to need some further adjustment to their algorithms in order to play nicely with this new feature. I'm already working on the solution.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Tutorial 9 - Moving Stemwall Segments (10:20 min.):
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.4.8b - 09.17.2019
                              • Removed the "Draw Slab on Grade" icon from the main toolbar.
                              • Added the SOG Foundation toolbar.
                              • Added the "Move SOG Edge" icon to the SOG foundation toolbar.
                              • Added the "Move SOG Edge" function to the context menu for polygon SOG assemblies.
                              • Enabled the "Move SOG Edge" tool for polygon/face SOG assemblies.
                              http://design.medeek.com/resources/images/foundation_su_menu_active.jpg
                              http://design.medeek.com/resources/images/foundation_sog_su_menu_active.jpg
                              Click on animated GIF to view move operation(s):
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Looks like the openings are now behaving properly with the Stemwall move tool:
                                [Click animated GIF to view]
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  Version 1.4.8c - 09.18.2019
                                  • Fixed bugs within the Stemwall and SOG move tools regarding: brick ledges, blockouts, and openings.
                                  This is a critical fix for the items mentioned above and I highly recommend upgrading to this latest version.
                                  Adjusting a Slab on Grade foundation with brick ledges:
                                  [Click image to view Animation]
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    There is one final issue or missing feature with the polyline stemwall tool and that is brick ledges. I have been working on the complex roof module this evening but I really feel like I need to address the brick ledge issue before I leave the foundation plugin development for a spell.
                                    Originally my thinking was that a brick ledge option for stemwalls needed to be on a per edge basis. However, even if this were the case the stemwall thickness and footing size would still remain the same for all of the assembly, even for those segments that do not have brick ledges.
                                    Typically I would assume that a stemwall foundation should have a thicker stemwall and footing for those walls that are supporting brick veneer. If this is the case then it actually makes more sense to have a global option for the assembly rather than a per edge basis.
                                    Please correct me if I am wrong here.
                                    I guess I need a bit of guidance, perhaps some more more examples of stemwall foundation plans with brick ledges (and some walls without) would be extremely helpful.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Here is a simple example of a stemwall foundation where the front of the house would have brick veneer and the rear and sides would be siding or stucco:
                                      http://design.medeek.com/resources/trussplugin/images/truss_su521_800.jpg
                                      Notice how the dimensions for the sections of the walls that support the brick are thickened accordingly and the model splits the foundation into two separate stemwall assemblies to achieve this.
                                      View model here:
                                      3D Warehouse
                                      In a situation like this one would not need brick ledges on a per edge basis since those stemwalls sections with brick would require a different (thicker/larger) profile to deal with the extra dead load of the veneer.
                                      If there is a valid argument for a brick ledge tool that works on a per edge basis I will entertain it, but I need to see a situation where there would be call for this.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.4.9 - 09.19.2019
                                        • Added a brick ledge option for polyline stemwalls.
                                        • Fixed a bug with regards to metric templates for foundation vents within polyline stemwalls.
                                        http://design.medeek.com/resources/trussplugin/images/truss_su522_800.jpg
                                        Note that the top rebar is offset from the bottom rebar so that it stays centered within the decreased width of the upper stemwall. Anchor bolt placement and FPSF insulation is also adjusted accordingly as shown.
                                        The example shown is a 10" stemwall with a 4" brick ledge.
                                        As previously discussed the brick ledge option is an assembly wide option and not on a per edge basis, hopefully this is flexible enough for most designers.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          I think we are just about ready to fully retire the old stemwall tool. The only thing I am missing with the new polyline tool is joist pockets, I guess there is always one more thing.
                                          Joist pockets would be a feature that would be on a per edge basis. Like brick ledges for slab-on-grades there would be no "move" function, only draw, edit and delete tools. So essentially I need one more toolbar for joist pockets, with three icons... I know everyone is about ready to hit me right now, with all of these toolbars I keep adding, I'm sorry.
                                          In my defense though I should point out that the user can easily disable/turn off any of the toolbars that they do not commonly use, so that they do not overly clutter their SketchUp workspace.
                                          Joist pockets are not a high priority in my opinion. I have a few western US builders who use them on a regular basis but I don't think they are as popular anymore. I'm going to put this option on the back burner for a while, however as they say the squeaky wheel gets the grease so I'm always open to suggestion if you feel otherwise.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Now that I have stemwalls and brick ledges on my mind it seems clear that we probably need a brick ledge option for stemwall steps:
                                            http://design.medeek.com/resources/trussplugin/images/truss_su523_800.jpg
                                            However, as I'm looking around at various examples of brick ledges combined with steps it appears that sometimes the brick ledge laps as shown in this image:
                                            https://synergiscadblog.com/wp-content/uploads/2014/12/rwt9.jpg
                                            Do I need another parameter so that the designer can lap the brick ledge?
                                            View model here:
                                            3D Warehouse
                                            design.medeek.com
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 22
                                            • 23
                                            • 17 / 23
