    CompoSpray is back [version 2.0.0]
    11 Posts 9 Posters 5.8k Views 9 Watching
    • jujuJ Offline
      juju
      Great work Didier, thank you!
      • jenujacobJ Offline
        jenujacob
        Thank you very much Sir Didier Bur!
        • srxS Offline
          srx
          Thank you Mr. Bur. ๐Ÿ‘ I am glad you on the road again.
          I noticed there is still an old bug with populating selected face - part of it is not populated, as it was masked, or something...
          Also when try to populate grass, I need to do it 5-6 times to reach the desired density. Would be nice to have pressure up to 1000%. Why not?
          www.saurus.rs
            db11
            With all of the discussion lately about sages and pros dropping off the SU map, it's great to see you back in the saddle and producing/updating plugins.
            Your (renewed) contributions are much appreciated!
            • pbacotP Offline
              Thank you very much!
              • HornOxxH Offline
                HornOxx
                Prima & 1000x Danke !! ๐Ÿ˜„
                http://media1.tenor.com/images/7a3d4d775b0958a0f2c8e4101313b842/tenor.gif?itemid=7607265
                never trust a skinny cook
                  Always innovative! ๐Ÿ˜Ž
                  • chonC Offline
                    chon
                    Hello all,
                    Thanks Didier for this update.
                    I've got an issue :
                    The plugin works fine when i install it in the C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2019\SketchUp\Plugins folder, but it doesn't work when i install it in my Fredo6's AdditionalPluginFolder.
                    If someone has an idea...
                    Many thanks for response.
                    • Didier BurD Offline
                      Didier Bur
                      Hi all,
                      The path to the plugin is hard-coded in the script. So if you locate the plugin elsewhere than C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2019\SketchUp\Plugins\DBUR_Compo_Spray, it will not work.
                      Sorry for the inconvenience, but what's the reason you want to install it with Fredo Tools ?
                      DB
                      • chonC Offline
                        chon
                        Tanks for response
                        The Fredo6's AdditionalPluginFolder is a small standalone script providing the capability to define one or several additional user-defined directories to load plugins in Sketchup.
                        We use 4 licences of SU and it is really interesting to centralize all plugins in 1 place for updates or installations on the 4 machines at the same time.
                        Edit : Compospray 1.4.2 was working fine with AdditionalPluginFolder after some corrections by TIG.
