    CompoSpray is back [version 2.0.0]
    11 Posts 9 Posters 5.4k Views 9 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      I've updated my old plugin CompoSpray which is now live at the EW here:
      https://extensions.sketchup.com/en/content/compospray
      Faster, better, more reliable than before, compatible with SU2016 and higher, 14 different ways of spraying components.
      Enjoy ๐Ÿ˜‰
      Click on the image to see a short video.
Dropping components on lines
Spraying components with altitude constraints.
      Dialog
      DB
      • jujuJ Offline
        juju
        Great work Didier, thank you!
        • jenujacobJ Offline
          jenujacob
          Thank you very much Sir Didier Bur!
          • srxS Offline
            srx
            Thank you Mr. Bur. ๐Ÿ‘ I am glad you on the road again.
            I noticed there is still an old bug with populating selected face - part of it is not populated, as it was masked, or something...
            Also when try to populate grass, I need to do it 5-6 times to reach the desired density. Would be nice to have pressure up to 1000%. Why not?
            www.saurus.rs
              db11
              With all of the discussion lately about sages and pros dropping off the SU map, it's great to see you back in the saddle and producing/updating plugins.
              Your (renewed) contributions are much appreciated!
              • pbacotP Offline
                Thank you very much!
                • HornOxxH Offline
                  HornOxx
                  Prima & 1000x Danke !! ๐Ÿ˜„
                  http://media1.tenor.com/images/7a3d4d775b0958a0f2c8e4101313b842/tenor.gif?itemid=7607265
                  never trust a skinny cook
                    Always innovative! ๐Ÿ˜Ž
                    • chonC Offline
                      chon
                      Hello all,
                      Thanks Didier for this update.
                      I've got an issue :
                      The plugin works fine when i install it in the C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2019\SketchUp\Plugins folder, but it doesn't work when i install it in my Fredo6's AdditionalPluginFolder.
                      If someone has an idea...
                      Many thanks for response.
                        Didier Bur
                        Hi all,
                        The path to the plugin is hard-coded in the script. So if you locate the plugin elsewhere than C:\Users\XX\AppData\Roaming\SketchUp\SketchUp 2019\SketchUp\Plugins\DBUR_Compo_Spray, it will not work.
                        Sorry for the inconvenience, but what's the reason you want to install it with Fredo Tools ?
                        DB
                        • chonC Offline
                          chon
                          Tanks for response
                          The Fredo6's AdditionalPluginFolder is a small standalone script providing the capability to define one or several additional user-defined directories to load plugins in Sketchup.
                          We use 4 licences of SU and it is really interesting to centralize all plugins in 1 place for updates or installations on the 4 machines at the same time.
                          Edit : Compospray 1.4.2 was working fine with AdditionalPluginFolder after some corrections by TIG.
