    How to create this in Profile builder 3
    extensions
    3 Posts 3 Posters 4.3k Views 3 Watching
    • soloS
      I would normally just model this if it was a small section, but I need 2 miles of cartoon fencing which will be on a very organic terrain, Profile builder is the best for this I assume, but I cannot seem to get my head around how to do this.
      This is what I want it to look like, I need more variety than just 2 uprights, almost if the uprights can be randomized.
        I will made that with groups (components) of 2 or 3 spans (because you have some "inclined" posts between them )
        then at the end when all is done use the genious random component replacement by Sdmitch! πŸ˜‰
        Of course you must draw some few different modules variations but it's not a big deal πŸ˜„
        • W
          Whaat
          You should create a PB3 assembly that uses one part for the posts (component) and another component-type span part for the rails. Then, try using the above-mentioned random component replacer plugin to swap the posts for randomized versions and the rail components as randomized versions.
