    Foundation Plugin
    451 Posts 15 Posters 580.3k Views 15 Watching
    • medeekM Offline
      medeek
      First look at some bottom steps with 24" steps:
      http://design.medeek.com/resources/trussplugin/images/truss_su486_800.jpg
      Notice that the optional footing transition has been toggled on.
      Now I just need to wrap up the concrete for the double step and then I'll release a new version so that everyone can test out this new feature.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        Version 1.3.8 - 08.29.2019
        • Enabled the "Draw Stemwall Step" tool with the following step types: Top, Bottom, Double.
        • Enabled the "Edit Stemwall Step" function/menu for stemwall steps.
        • Added a "Hide Edges" option in the draw and edit menus for stemwall steps.
        http://design.medeek.com/resources/trussplugin/images/truss_su487_800.jpg
        Currently the other options are not yet enabled (anchor bolts, rebar, insulation, vents, and drain pipe). I will work on these this weekend and try to wrap up the stemwall step module by Monday.
        After that I will put together the Interior Bearing tool and then move back to the Truss Plugin development for a while. However, if there are specific requests for features or bug fixes I will continue to address those in the next few weeks.
        design.medeek.com
        • medeekM Offline
          medeek
          This is kind of what I have in mind for the rebar for a top step:
          http://design.medeek.com/resources/trussplugin/images/truss_su488_800.jpg
          Note the typical 3" clearance for the very top bar. Also note how the other top bar extends beyond the step by 12". I can provide another parameter that allows the user to specify the length of this lap/extension.
          I apologize that the dimensions are so small in the image, I should have increased the text size to make it more readable.
          The bottom step and double step would be similar. Thoughts or a different rebar configuration?
          design.medeek.com
          • medeekM Offline
            medeek
            For the drain pipe with a step I'm looking at three possible ways to model the vertical transition:
            http://design.medeek.com/resources/trussplugin/images/truss_su489_800.jpg
            The first model just follows the concrete step and makes a vertical jump.
            The second model transitions with a couple of 45 degree elbows.
            The third makes a more gradual transition with 16" of lead in before beginning the slope.
            Which is the preferred way to model the drain pipe?
            design.medeek.com
            • medeekM Offline
              medeek
              Version 1.3.9 - 08.30.2019
              • Added an option for additional horizontal bars in the draw and edit menus for polyline stemwall foundations.
              http://design.medeek.com/resources/trussplugin/images/truss_su490_800.jpg
              Now we just need a few more options that will allow for vertical bars.
              design.medeek.com
              • medeekM Offline
                medeek
                Version 1.3.9b - 08.31.2019
                • Added an option for vertical bars in the draw and edit menus for polyline stemwall foundations.
                http://design.medeek.com/resources/trussplugin/images/truss_su491_800.jpg
                View model here:
                3D Warehouse
                (3dwarehouse.sketchup.com)
                The top of the vertical rebar is 3" below the top of the stemwall and extends into the footing by half the footing depth.
                These various foundation assemblies are starting to rival the wall and truss plugins assemblies in complexity and details, exciting stuff.
                I still need to work on a module that will allow for brick ledges on stemwalls as well as another module for adding in windows and doors. A CMU option would also be nice. No matter how hard I work on this stuff it always seems like there is more, its a moving target I guess.
                design.medeek.com
                • medeekM Offline
                  medeek
                  Version 1.3.9c - 09.01.2019
                  • Enabled rebar for stemwall steps (top step only).
                  • Added an option for additional horizontal and vertical bars in the draw and edit menus for stemwall steps.
                  http://design.medeek.com/resources/trussplugin/images/truss_su492_800.jpg
                  I rolled the revision a little early since I noticed there was a bug in the edit function for stemwall steps. If you've recently installed 1.3.9b, I would highly recommend updating to this latest version.
                  I just need to work out the rebar for the other two step configurations and then rebar is complete.
                  I will then attack anchor bolts next, then the drain pipe and then the FPSF insulation. I will probably leave the vents disabled for now or at least until someone gives me more feedback on how they would like to see this configured.
                  The nice thing with the rebar is that you still have the option to install top and/or bottom bar with or without the horizontal bar, so lots of design permutations.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.3.9d - 09.02.2019
                    • Enabled rebar for stemwall steps (bottom step and double step).
                    http://design.medeek.com/resources/trussplugin/images/truss_su493_800.jpg
                    http://design.medeek.com/resources/trussplugin/images/truss_su494_800.jpg
                    Rebar was a bit a of a pain especially the double step, the rest of the advanced options should be relatively simple comparatively.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      First look at stemwall steps with drain pipe:
                      http://design.medeek.com/resources/trussplugin/images/truss_su495_800.jpg
                      View model here:
                      3D Warehouse
                      I don't know why but just looking at this model makes me very happy. I guess I've been trying to do this sort of thing with foundations since I began programming the foundation plugin about three years ago and I am now finally arriving at a viable solution.
                      Note, that the hide edges option will hide the concrete lines at the end of each assembly and the entire foundation will appear as monolithic. I have not enabled this option in this model because I want to show the three different steps types distinctly.
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        First look at that stemwall steps with FPSF insulation:
                        http://design.medeek.com/resources/trussplugin/images/truss_su496_800.jpg
                        Not sure if an additional piece of insulation should be added at the actual step, any thoughts on that?
                        View model here:
                        3D Warehouse
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          Version 1.4.0 - 09.02.2019
                          • Enabled drain pipe for stemwall steps.
                          • Enabled FPSF insulation for stemwall steps.
                          • Enabled anchor bolts for stemwall steps.
                          http://design.medeek.com/resources/trussplugin/images/truss_su497_800.jpg
                          The stemwall step tool is complete.
                          Again the only thing missing is the vents option (which I have disabled for now). I will give this some more thought and address it as soon as I have a practical solution.
                          The next item of business is the interior bearing tool/module which will allow for linear interior bearing assemblies (ie. post-and-beam, stud wall, CMU etc...) I'm very familiar with the first two systems however I'm not so familiar with how CMU interior bearings are typically constructed. Any information would be helpful.
                          This next module is very simple and I hope to complete it within 3-4 days. Then back to the quest for the holy grail of the Truss plugin... Complex Roofs.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            Parameters for the new Interior Bearing Module:
                            Basic Options:
                            Bearing Type: Post and Beam, Stud Wall, CMU
                            Bearing Height:
                            Footing Width:
                            Footing Depth:
                            Ftg. Offset Start:
                            Ftg. Offset End:
                            Sill Plate Offset:
                            Stemwall Offset:
                            Rebar Option: Yes/No
                            Post and Beam Options:
                            Beam Width:
                            Beam Depth:
                            Post Spacing:
                            Post Width:
                            Stud Wall Options:
                            Stud Depth:
                            Stud Width:
                            Stud Spacing:
                            Top Plate Qty: 1,2,3
                            Top Plate Thk.:
                            Rebar Options:
                            Ftg. Bar Dia.:
                            Ftg. Bar Qty.:
                            Let me know if I'm missing anything. I haven't included a section for CMU yet since I need to do more research on that particular construction type.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              Version 1.4.1 - 09.04.2019
                              • Enabled the "Draw Interior Bearing" tool with the following support types: Post & Beam, Stud Wall.
                              http://design.medeek.com/resources/trussplugin/images/truss_su498_800.jpg
                              View model here:
                              3D Warehouse
                              Now a video demonstrating the polyline stemwall, interior bearing and step tool all working together would be interesting.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Tutorial 6 - Polyline Stemwalls, Steps and Interior Bearings (13:27 min.):
                                View model here:
                                3D Warehouse
                                http://design.medeek.com/resources/trussplugin/images/truss_su499_800.jpg
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  There has been some call to provide a CMU option for the polyline stemwall module. In order to represent CMU my intent was to not alter the model but just apply the appropriate material/texture as I am doing with the Wall plugin. However this method only really works with linear sections of walls (at least for the faces parallel to the Z plane):
                                  http://design.medeek.com/resources/trussplugin/images/truss_su500_800.jpg
                                  As you can see from the image/model the vertical faces come out just fine however the horizontal faces are a bit of a mess. I really don't want to change up the way I'm modeling the stemwall itself (ie. breaking it into linear segments) so the solution might be to simply provide a more generic material for the horizontal faces without any of the brick interior design, mortar lines etc... thoughts? It would look not quite as realistic when looking at the top of the CMU wall but it also wouldn't appear as confusing as the result shown here.
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    Medeek Live Training: Session 1
                                    Scheduled time is 11:00 PST
                                    This is my first attempt at live streaming so hopefully things go smoothly but I'm sure it will be a bit of a learning experience. The primary topics covered will be the recent additions to the foundation plugin however I am willing to open it up to other questions about all of the other plugins.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      This bi-directional pattern (even though not as realistic) seems to be a decent compromise and provided the segments of the polyline stemwall are orthogonal and in length increments that are multiples of 24" the texture works:
                                      http://design.medeek.com/resources/trussplugin/images/truss_su501_800.jpg
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        First look at a CMU polyline stemwall:
                                        http://design.medeek.com/resources/trussplugin/images/truss_su502_800.jpg
                                        Note that the callout includes the number of CMU block calculated per the volume of the stemwall and the standard block size (16" x 8" x stemwidth). For now the nominal depth and height of the CMU block is hard coded to these typical values found in North American construction but I will probably provide some parameters in the global settings where these values can be customized.
                                        The horizontal face texture I'm using only really works well for standard CMU block sizes and if the walls are orthogonal and in 2' length increments. I don't have a work around yet to deal with exceptions. I will give this some additional thought and come up with a better solution.
                                        Now all I need to do is enable CMU for the stemwall step tool and then I'll roll a new release.
                                        This update is a direct result of discussions had in today's training session, thank-you to everyone who participated and providing feedback which will directly impact the plugins' development.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.4.2 - 09.05.2019
                                          • Enabled CMU blocks for polyline stemwall foundations.
                                          • Enabled CMU blocks for stemwall steps.
                                          http://design.medeek.com/resources/trussplugin/images/truss_su503_800.jpg
                                          ** NOTE **
                                          If you have previously installed the plugin and are upgrading to this latest version in order to utilize the new CMU feature please do the following action once you have installed Version 1.4.2:
                                          1.) Click on the global settings tab.
                                          2.) Click on the Layers tab within the Global Settings.
                                          This action will initialize the “CMU Layer” for future use. New installations of the plugin will automatically initialize the new layer when they enable the layers options for the first time. This action is only required for those users upgrading their plugin installation.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            I'm interested in putting the new polyline stemwall tool through its paces. If you have a fairly complex foundation plan that you think I should try and model please email me a PDF of it.
                                            design.medeek.com
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 22
                                            • 23
                                            • 15 / 23
