    Foundation Plugin
    441 Posts 15 Posters 444.8k Views 15 Watching
    • medeekM Offline
      medeek
      After looking at various details (including some of my own) I am wondering if enabling an option to include a 4" DIA drain pipe along the footing might be of some interest. Please let me know know your thoughts on this. I haven't had too much call for it but I have often called one out in many of my own plans and drawings:
      http://design.medeek.com/cad/autocad/STEMWALL_DETAIL_240.jpg
      http://design.medeek.com/cad/autocad/STEMWALL_DETAIL.pdf
      Parameters would probably be:
      1.) Diameter: 4"
      2.) Bend Radius: 4"
      3.) Wall Thickness: 0.125"
      4.) Hollow: Yes/No
      5.) Ftg. Clearance: 2"
      Additional layer for PVC and a PVC material (RGB: 149, 219, 184)
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • jujuJ Offline
        juju
        yes please
        • pbacotP Offline
          The drain line would be good. We also use slab sub-drains.
          • medeekM Offline
            medeek
            Version 1.3.6 - 08.25.2019
            • Added a drain pipe option in the draw and edit menus for polyline stemwall foundations.
            • Added a drain layer in the Global Settings under the "Layers" tab.
            • Fixed a bug with the hide edges option with regards to closed loop polyline stemwall foundations.
            http://design.medeek.com/resources/trussplugin/images/truss_su481_800.jpg
            ** NOTE **
            If you have previously installed the plugin and are upgrading to this latest version in order to utilize the new drain pipe feature please do the following action once you have installed Version 1.3.6:
            1.) Click on the global settings tab.
            2.) Click on the Layers tab within the Global Settings.
            This action will initialize the "Drain Layer" for future use. New installations of the plugin will automatically initialize the new layer when they enable the layers options for the first time.
            In order to help minimize the model size I've limited the drain pipe circle profile to 16 segments rather than the usual 24 segments. Visually this seems to be the best compromise.
            I've also added the option to draw the drain pipe as a simple solid or hollow as shown with the "Hollow Pipe" option. By default this is set to "YES".
            The drain pipe is positioned with its bottom level with the bottom of the footing. Currently there is no vertical offset, but I'm not opposed to adding one if there is call for it.
            The other parameters are fairly self explanatory.
            design.medeek.com
            • medeekM Offline
              medeek
              With regards to estimating it wouldn’t be that hard for me to calculate the lineal feet of drain pipe as well as give a count on the number of elbows (45, 90 etc…) I’ve added this to the todo list.
              design.medeek.com
              • pbacotP Offline
                Do you need to model the wall thickness of the pipes? With all the bends that you also model, it might add a lot of geometry to a larger house plan.
                • medeekM Offline
                  medeek
                  That is the point of "Hollow Pipe" option, if you don't need to model the actual inside of the pipe you can toggle it off and just represent the pipe as a solid object.
                  It does add a lot of unnecessary geometry in my opinion but some users might want it modeled exactly.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.3.7 - 08.26.2019
                    • Added a drain pipe option in the draw and edit menus for rectangular and polygon slab-on-grade foundations.
                    • Increased the speed/performance of the drain pipe modeling method.
                    http://design.medeek.com/resources/trussplugin/images/truss_su482_800.jpg
                    The smoothing routine I was using was a major slowdown/bottleneck so I have removed it for now. I will need to experiment with an improved smoothing routine but for now it is not imperative, the pipe is a proper solid and group.
                    As you can see in the model there are some visible edges at each elbow, these can be removed by adjusting the smooth normals/soften coplanar options within the Soften Edges tool in the SketchUp Default Tray.
                    design.medeek.com
                    • medeekM Offline
                      medeek
                      Working on the step tool this evening. This one gets real interesting, lots of possible configurations even though it is a simple linear piece of foundation (ie. Top Step, Bottom Step, Double Step).
                      I haven't spent too much time looking at the rebar yet for a step but I'm starting to now and just wondering how everyone would like it drawn/configured. I can terminate the rebar lengths at the step or I can extrude them along to follow the path of the step(s). Any thoughts, cad drawings or details showing preferred rebar layout would be extremely helpful.
                      I have enough tricks in coding toolbox now that I can pretty much make the rebar do anything you want, I just want to make it as realistic as possible without getting overly complicated.
                      Along that same vein I think I have the other advanced options figured out for a stemwall step: Anchor Bolts, Vents, Insulation. However, I don't know what I want to do with the drain pipe just yet. Obviously it needs to transition from one height to another but what is the preferred way to model this?
                      design.medeek.com
                      • medeekM Offline
                        medeek
                        After some serious head scratching and tossing around various parameters I've managed to boil it down to this:
                        http://design.medeek.com/resources/trussplugin/images/truss_su483_800.jpg
                        Three different step configurations: Top, Bottom, Double (see previous drawing for details)
                        The Double Step has three additional parameters as well as the option for the Ftg. transition.
                        As you can see it gets rather complicated, or at least appears so. In actuality it is fairly simple once you understand what each parameter does.
                        http://design.medeek.com/resources/trussplugin/step_foundation_800.jpg
                        design.medeek.com
                        • medeekM Offline
                          medeek
                          First look at the wireframe preview for a stemwall step:
                          http://design.medeek.com/resources/trussplugin/images/truss_su484_800.jpg
                          Tomorrow I start in earnest to code the concrete portion of the module now that all of the supporting infrastructure is in place. Then from there it is rebar, anchor bolts etc...
                          Hopefully this module combined with the polyline stemwall module will give designers the flexibility they need in order to model any type of stemwall or basement foundation.
                          design.medeek.com
                          • medeekM Offline
                            medeek
                            First look at a Type A (Top Step) concrete, with and without hidden edges:
                            http://design.medeek.com/resources/trussplugin/images/truss_su485_800.jpg
                            Haven’t really had much feedback with regards to the rebar for a step. For now I think I will just terminate it at the step. We can always talk about lapping and turned up or turned down rebar later as I’m sure the discussion will come up.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              First look at some bottom steps with 24" steps:
                              http://design.medeek.com/resources/trussplugin/images/truss_su486_800.jpg
                              Notice that the optional footing transition has been toggled on.
                              Now I just need to wrap up the concrete for the double step and then I'll release a new version so that everyone can test out this new feature.
                              design.medeek.com
                              • medeekM Offline
                                medeek
                                Version 1.3.8 - 08.29.2019
                                • Enabled the "Draw Stemwall Step" tool with the following step types: Top, Bottom, Double.
                                • Enabled the "Edit Stemwall Step" function/menu for stemwall steps.
                                • Added a "Hide Edges" option in the draw and edit menus for stemwall steps.
                                http://design.medeek.com/resources/trussplugin/images/truss_su487_800.jpg
                                Currently the other options are not yet enabled (anchor bolts, rebar, insulation, vents, and drain pipe). I will work on these this weekend and try to wrap up the stemwall step module by Monday.
                                After that I will put together the Interior Bearing tool and then move back to the Truss Plugin development for a while. However, if there are specific requests for features or bug fixes I will continue to address those in the next few weeks.
                                design.medeek.com
                                • medeekM Offline
                                  medeek
                                  This is kind of what I have in mind for the rebar for a top step:
                                  http://design.medeek.com/resources/trussplugin/images/truss_su488_800.jpg
                                  Note the typical 3" clearance for the very top bar. Also note how the other top bar extends beyond the step by 12". I can provide another parameter that allows the user to specify the length of this lap/extension.
                                  I apologize that the dimensions are so small in the image, I should have increased the text size to make it more readable.
                                  The bottom step and double step would be similar. Thoughts or a different rebar configuration?
                                  design.medeek.com
                                  • medeekM Offline
                                    medeek
                                    For the drain pipe with a step I'm looking at three possible ways to model the vertical transition:
                                    http://design.medeek.com/resources/trussplugin/images/truss_su489_800.jpg
                                    The first model just follows the concrete step and makes a vertical jump.
                                    The second model transitions with a couple of 45 degree elbows.
                                    The third makes a more gradual transition with 16" of lead in before beginning the slope.
                                    Which is the preferred way to model the drain pipe?
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.3.9 - 08.30.2019
                                      • Added an option for additional horizontal bars in the draw and edit menus for polyline stemwall foundations.
                                      http://design.medeek.com/resources/trussplugin/images/truss_su490_800.jpg
                                      Now we just need a few more options that will allow for vertical bars.
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        Version 1.3.9b - 08.31.2019
                                        • Added an option for vertical bars in the draw and edit menus for polyline stemwall foundations.
                                        http://design.medeek.com/resources/trussplugin/images/truss_su491_800.jpg
                                        View model here:
                                        3D Warehouse
                                        (3dwarehouse.sketchup.com)
                                        The top of the vertical rebar is 3" below the top of the stemwall and extends into the footing by half the footing depth.
                                        These various foundation assemblies are starting to rival the wall and truss plugins assemblies in complexity and details, exciting stuff.
                                        I still need to work on a module that will allow for brick ledges on stemwalls as well as another module for adding in windows and doors. A CMU option would also be nice. No matter how hard I work on this stuff it always seems like there is more, its a moving target I guess.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Version 1.3.9c - 09.01.2019
                                          • Enabled rebar for stemwall steps (top step only).
                                          • Added an option for additional horizontal and vertical bars in the draw and edit menus for stemwall steps.
                                          http://design.medeek.com/resources/trussplugin/images/truss_su492_800.jpg
                                          I rolled the revision a little early since I noticed there was a bug in the edit function for stemwall steps. If you've recently installed 1.3.9b, I would highly recommend updating to this latest version.
                                          I just need to work out the rebar for the other two step configurations and then rebar is complete.
                                          I will then attack anchor bolts next, then the drain pipe and then the FPSF insulation. I will probably leave the vents disabled for now or at least until someone gives me more feedback on how they would like to see this configured.
                                          The nice thing with the rebar is that you still have the option to install top and/or bottom bar with or without the horizontal bar, so lots of design permutations.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Version 1.3.9d - 09.02.2019
                                            • Enabled rebar for stemwall steps (bottom step and double step).
                                            http://design.medeek.com/resources/trussplugin/images/truss_su493_800.jpg
                                            http://design.medeek.com/resources/trussplugin/images/truss_su494_800.jpg
                                            Rebar was a bit a of a pain especially the double step, the rest of the advanced options should be relatively simple comparatively.
                                            design.medeek.com
                                            • 22
                                            • 23
                                            • 8 / 23
