    Message "there was a problem exporting to this file"
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    23 Posts 12 Posters 35.5k Views 12 Watching
      sketchy
      I have also run into this problem exporting a LO document to PDF. Very frustrated, I put in a support ticket but haven't heard a peep in 2 days.
      The file is too large to post (1GB+) and I have no interest in deleting pages one at a time to find the culprit since there are over 40 pages. Each time they put out a new version of LO I get excited and try a project in it. Each time all my effort gets eaten by a bug(s).
      I would still be excited about a stable version, especially since there are some huge advances with this build in my opinion.
      Any other ways to trouble shoot this since I haven't heard from Google?
        sketchy
        got a reply:
        "Thank you for your note. To reduce the size of the file and potentially
        resolve this issue, I suggest purging the LayOut file:
        1. Click "File" > "Document Settings..."
        2. Click "References" in the right pane.
        3. Click the "Purge" button in the right pane.
        If you continue to encounter a crash after purging the LayOut file, you
        may consider exporting to PDF in increments of 5 pages. You can then use
        Adobe Acrobat to combine the resulting PDFs into a single PDF."
        Will try later but not too thrilled that the solution may involve a program I do not own.
        • GaieusG
          PDFCreator (free) can also stitch several pdf (and actually other kind of) files together.
          Yet I understand that it's just another workaround
            sketchy
            Purge worked. I guess if something doesn't work I will try that.
              sonder
              I am having this same problem with only one page on a 6 page layout file. I tried the purge routine to no avail. Any help would be appreciated.
                rose47
                I am having similar problem. I have a LO file which I have previously exported to pdf no problem. Now I want to add a small text box. Every time I export to pdf, if I choose overwrite option it shows me the previous version eg without the new text box. If I choose to resave with a new name, I get the message 'problem opening pdf viewer' and nothing happens. I have done a purge of the LO file, and tried re-saving the LO file with a different name first, done a re-boot - nothing! Any ideas?
                Thanks, Rose
                  SteveJLV
                  I had the same problem. In my case I resolved the issue after setting "Preserve Scale on Resize" on every Sketchup Model View.(put the check mark on)
                  No more problems after that.
                    Steve, is this in LO3? Your profile indicates you are still using SketchUp 8 which implies LayOut 3.
                      Jef.Coelho
                      I was having this problem every time added some image format, I had problems with todos.Na attempt to find a solution, I found that if I put the image in another file open and CTRL + C, I can paste in my original document and export PDF in any capacity. With me this problem only occurs when the document has pictures, only with inserted sketchup, all is well.
                        studio constantine
                        I hope you might have figured out the problem since it's been a long time I'm answering, I don't what the issue is, but there is a solution available, you can go to "Print tab - print as a file - choose the path - Print" you'll get the PDF file.
                        Thank You.
                        • 2 / 2
