    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    699 Posts 161 Posters 644.0k Views 161 Watching
      jkeller3
      I've been using this extension for some time now but I currently have an issue. Clothworks is crashing when ever I go to drop a cloth over a 3d item. Single plane it has no issue, but if there are 2 or more angels outside of the one plane it crashes with no warning, or lag.
        If you share the SKP file so we can see what you are trying to do, we can give you some help.
          Anton_S
          Yes, please share a model or send me a private message of your model, that I could look into the issue. Also, are you using ClothWorks v1.7.0 or an older version?
            jkeller3
            Anton,
            I DM'd you a skp file and screen capture of what happens. It happens with all SKP files no matter how complicated or simple. At first I thought maybe the geometry I was using was too complicated but you can see with that simple file simple draping does not work for me. This file used a quadrilateral grid at 3000 and default settings. I've uninstalled CW and reinstalled it. Versions of my software are:
            OSX Mojave Version 10.14.5
            sketchup Version 19.2.221
            ClothWorks version 1.7.0a
              Anton_S
              Joe Keller,
              I am able to reproduce the crash on my Mac OS X 10.14 but not on my Windows 10. I will look into fixing the issue as soon as possible. Thank you for the report!
              Anton
                Anton_S
                Announcing version 1.7.1:
                1. Fixed crash on Mac OS X. Thanks to jkeller3 for the report.
                2. Added Spanish language. Thanks to Oxer for the translations.
                • summerson1990S Offline
                  summerson1990
                  Just bought this plugin and saw a new version released (1.7.1a) but when updated the toggle UI interface is not working anymore. It can't be opened. I use SU 2019 PRO on win 10.
                    summerson1990
                    1. Added Spanish language. Thanks to Oxer for the translations.
                    Hi! v1.7.1 and 1.7.0 toggle UI not working on SU 2019 PRO, Windows 10
                      Anton_S
                      The Toggle UI toolbar option works correctly on my system. Please do a clean installation of the plugin. Navigate to your plugins folder and delete ams_ClothWorks folder and ams_ClothWorks.rb file. Then do a clean installation of version 1.7.1.
                      There are two plugin folders. To navigate to the first plugins folder, open a file explorer window and paste the following into the address bar: %appdata%\sketchup\SketchUp 2019\SketchUp\Plugins
                      The second plugins folder is located at:
                      C:\ProgramData\SketchUp\SketchUp 2019\SketchUp\Plugins
                      Ensure that original version is deleted from both folders prior to installing the new version.
                        summerson1990
                        Maybe you are using not a last release of SU (2019.2)? Because I did exactly you adviced and still the problem exists... I can make a gif screenshot in order to prove it.
                          This is what I see on 2019.2.
                          Click on the picture to make it go.
                            summerson1990
                            [attachment=0:205mv7bc]<!-- ia0 -->UI Toggle.gif<!-- ia0 -->[/attachment:205mv7bc]
                            Ok, so what's the problem with mine? See an attached gif by link https://dropmefiles.com/gDreG.
                              When you installed 2019.2, did you do so correctly? That is, did you right click on the downloaded installer and choose Run as administrator while logged into Windows under your normal user ID? We've seen lots of weird problems related to incorrect installation of SketchUp when users haven't used Run as administrator.
                                Anton_S
                                @summerson1990 I fixed the issue. Please update to 1.7.2. The problem had to do with non-ascii username. I originally relied on the ENV variable to get path to appdata. I see that the ENV variable has issues with non-ascii usernames. With 1.7.2, I updated to use Windows API to get the appdata path. Thank you for the report and my apologies for the inconvenience!
                                  summerson1990
                                  Yes, now it works fine, thanks a lot!)
                                    jbf
                                    Help needed...
                                    I`m rather new to sketchup- I am playing around with Clothworks and I have ran in to a problem regards adding a pattern to the cloth. I have followed the instuctionvideo to the point- but the pattern breaks/cracks in the bendings (see pic.) what am I doing wrong? hoping someone can help me on the way- Thanks
                                      Anton_S
                                      @jbf You have to apply pattern (material) directly to the faces of the cloth. Do not apply material to the top level group. See one of the ClothWorks videos for applying material.
                                        jbf
                                        Thank you so much Anton- I canΒ΄t belive I overlooked that small detail. everything is working as it should πŸ‘
                                        • kelly13K Offline
                                          kelly13
                                          Π’ скСтчапС ссылка Π½Π° Π»ΠΈΡ†Π΅Π½Π·ΠΈΡŽ ΠΏΡ€Π΅Π΄Π»Π°Π³Π°Π΅Ρ‚ ΠΊΡƒΠΏΠΈΡ‚ΡŒ Ρ‚ΠΎΠ»ΡŒΠΊΠΎ Ρ‡Π΅Ρ€Π΅Π· PayPal - Π° ΠΏΠ΅ΠΉΠΏΠ΅Π» Π·Π°Π±Π»ΠΎΠΊΠΈΡ€ΠΎΠ²Π°Π» ΠΌΠΎΠΉ счСт ΠΈ ΠΏΠΎΡ‚Ρ€Π΅Π±ΠΎΠ²Π°Π» ΠΏΡ€Π΅Π΄ΠΎΡΡ‚Π°Π²ΠΈΡ‚ΡŒ скан Π΄ΠΎΠΊΡƒΠΌΠ΅Π½Ρ‚Π°, ΡƒΠ΄ΠΎΡΡ‚ΠΎΠ²Π΅Ρ€ΡΡŽΡ‰Π΅Π³ΠΎ Π»ΠΈΡ‡Π½ΠΎΡΡ‚ΡŒ с Ρ„ΠΎΡ‚ΠΎ ΠΈ прописку, адрСс ΠΏΠΎ мСсту ΠΆΠΈΡ‚Π΅Π»ΡŒΡΡ‚Π²Π°. Π― ΠΆΠΈΠ²Ρƒ Π² строящСмся Π΄ΠΎΠΌΠ΅, ΠΊΠΎΡ‚ΠΎΡ€Ρ‹ΠΉ ΠΏΡ€ΠΈΠ½Π°Π΄Π»Π΅ΠΆΠΈΡ‚ ΠΌΠ½Π΅, Π½ΠΎ Ρƒ Π½Π΅Π³ΠΎ всС Π΅Ρ‰Π΅ Π½Π΅Ρ‚ ΠΎΡ„ΠΈΡ†ΠΈΠ°Π»ΡŒΠ½ΠΎΠ³ΠΎ адрСса ΠΈ поэтому Ρƒ мСня Π½Π΅Ρ‚ Π² паспортС прописки.
                                          Π― прСдоставила сСрвису Paypal ΠΊΠ²ΠΈΡ‚Π°Π½Ρ†ΠΈΡŽ ΠΎΠ± ΠΎΠΏΠ»Π°Ρ‚Π΅ элСктроэнСргии с ΠΌΠΎΠ΅ΠΉ Ρ„Π°ΠΌΠΈΠ»ΠΈΠ΅ΠΉ ΠΈ адрСсом, Π½ΠΎ счСт ΠΌΠ½Π΅ Π΄ΠΎ сих ΠΏΠΎΡ€ Π½Π΅ Ρ€Π°Π·Π±Π»ΠΎΠΊΠΈΡ€ΠΎΠ²Π°Π½.
                                          ΠžΡ‡Π΅Π½ΡŒ Ρ…ΠΎΡ‡Ρƒ ΠΊΡƒΠΏΠΈΡ‚ΡŒ Π²Π°ΡˆΡƒ Π»ΠΈΡ†Π΅Π½Π·ΠΈΡŽ, Π½Π΅ΡƒΠΆΠ΅Π»ΠΈ нСльзя ΠΏΠΎ-Π΄Ρ€ΡƒΠ³ΠΎΠΌΡƒ, НЕ Ρ‡Π΅Ρ€Π΅Π· PayPal ?
                                          translated from Russian by Google translator
                                          In the sketchup, the link to the license offers to be bought only through PayPal - and the paper blocked my account and demanded to provide a scan of an identity document with a photo and registration, address at the place of residence. I live in a house under construction, which belongs to me, but it still does not have an official address and therefore I do not have a residence permit in my passport.
                                          I provided Paypal with a receipt for payment of electricity with my name and address, but my account has not yet been unblocked.
                                          I really want to buy your license, is there really no other way, NOT through PayPal?
                                            Anton_S
                                            ЗдравствуйтС ЕвгСния! Π’Π°ΠΌ Π½Π΅ Π½ΡƒΠΆΠ΅Π½ PayPal для ΠΏΠΎΠΊΡƒΠΏΠΊΠΈ ClothWorks. НаТмитС Π½Π° ΠΊΠ½ΠΎΠΏΠΊΡƒ "Check Out", Ρ‡Ρ‚ΠΎΠ±Ρ‹ ΠΊΡƒΠΏΠΈΡ‚ΡŒ, ΠΈΡΠΏΠΎΠ»ΡŒΠ·ΡƒΡ Π΄Ρ€ΡƒΠ³ΠΎΠΉ ΠΌΠ΅Ρ‚ΠΎΠ΄. Π‘ΠΌΠΎΡ‚Ρ€ΠΈΡ‚Π΅ ΠΏΡ€ΠΈΠΊΡ€Π΅ΠΏΠ»Π΅Π½Π½Ρ‹Π΅ ΡΠΊΡ€ΠΈΠ½ΡˆΠΎΡ‚Ρ‹.
                                            • 34
                                            • 35
                                            • 8 / 35
