    OnClick swinging Plumb-bob
    Scheduled Pinned Locked Moved Dynamic Components
    3 Posts 2 Posters 6.2k Views 2 Watching
    • SJS66S Offline
      SJS66
      Hi all.
      I know this might be asking a bit much, but I was wondering if you could use OnClick animateslow or animatecustom to make a plumb-bob swing like a plumb-bob (on all 3 axis) until it stops swinging like it would in reality.
      I've attached a basic test plumb-bob model, if anyone wants to download & play with it. I know I can make it swing back & forth on different axis at different times & can get it to position itself on different axis but not sure how to make it swing through multiple axis at the same time, say in a spiral back to plumb like it would in reality. I had a few goes but it ended up kind of doing my head in a bit. I think I need a fresh outlook on it. So I thought I'd share to see if anyone else has some spare time & save me from going crazy like a coconut...that boy needs help.
      https://youtu.be/pajL2jFFX2Q
      I've included a plate at the top of the plumb-bob string to help in orientating it at a few angles etc. I also saved as a SU2018 version & can save as earlier if needed.
      Cheers.
      Have fun!
      • jujuJ Offline
        juju
        This is probably something more suited to Physics extensions?
        • SJS66S Offline
          SJS66
          Unfortunately non of the physics extensions are compatible with SU 2019.
          Sounds like another good reason to switch to Blender;-)https://sketchucation.com/forums/viewtopic.php?f=179&t=69981
