[Plugin]T2H_BuildingStructureTools2.2.4 in20141207
@driven said:
I don't have it installed, but what happens if you enter radians?
1.57079633
johnGreat, that works! What's going on then?
the way ruby handles radians to degrees must have changed or you have another plugin that is changing the definition and it's effecting this one...
I'll see if I can find any thing...
john -
johnCheers, really appreciate your help.
Thanks driven, I should have spotted that! (one radian = 180/π degrees). By the way Josh Madison has a great little free prog that everyone should have on their Desktop...
https://joshmadison.com/convert-for-windows/
Wow, I still have the version from years ago that was named MConvert
I keep it on a USB stick as I've always been afraid of losing it as I could never find it online anymore. Thanks for the link! -
great tool and works well, however, when i produce a take off table I select the entity ID and there is no identification (highlighting) of the item within the model.
Do i need to have a particular switch turned on -
@krisidious said:
nice improvements... That wall tool looks nice. Can it possibly do curved walls? or transform lines into walls?
I would also like to draw curved walls with this - could we select a arc then apply the wall type?
@cadmunkey said:
run into a problem, not sure if its 2105 specific as I no longer have 14 and before installed.
When I have the rotation set to default (0) the member follows the line path fine (on the left in the picture).
On the right, I wanted the RHS to be rotated about 90 degrees, so typed '90' in the rotation box but when I apply it I get something more like 35 degrees. I've tried with different inputs but the output never corresponds to the angle I have chosen. Any ideas?i had similar problem before, input required in radians not in degrees.
90deg = 1.570796326795rad
30deg = 0.610865238198it will works as expected,
hi all,
is anyone has plugin files of early version (V0.56).
helps are much appreciates
I was facing the same issue thanks for the reply it has helped me a lot.
