    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    729 Posts 170 Posters 940.6k Views 171 Watching
      Anton_S
      As you can see, you have the same plugin installed in both locations. Delete the plugin from one of the installed locations. To delete the plugin, delete ams_ClothWorks folder and ams_ClothWorks.rb file from either program data or roaming. I see that the one located in roaming is newer.
      • jo-keJ
        jo-ke
        Thats it!
        I deleted all folders in both directories and the rb files and reinstalled the plugin.
        restarted su and: it was still there!
        Thank you
        http://www.zz7.de
          This begs the question, how did you install Clothworks in the first place? With the normal installation methods, you shouldn't have been able to get it installed in the two directories. It should have only been installed in User/App Data/Roaming...
            Anton_S
            Announcing version 1.7.0.
            Changes include:
            1. Added Russian translation. Desired language is accessible from ClothWorks menu.
            2. Added thickness generator for both cloth and strings. Cloth with thickness can be subdivided and draped/undraped, just like cloth without thickness. It is, however, not recommended to simulate cloth after generated thickness. Generating thikness, just like applying loop subdivision or laplacian smoothing, is for finalizing results.
            3. Added a feature to simulate by parts. When simulation starts, objects assigned Void state subtract cloth and collider vertices overlapping their axes-aligned bounding boxes. Subtracted vertices are not included in simulation.
            4. Added an option to draw cloth using SketchUp OpenGL API. Drawing cloth rather than transforming vertices guarantees a better performance, especially when simulating by parts. If Adaptive Remeshing is turned on, mesh resolution changes are drawn dynamically. When simulation is stopped, the original mesh is transformed/generated as necessary.
            5. Reworked gizmo. The new gizmo allows for translating, rotating, converging, and diverging selected pin(s).
            6. Fixed drag for strings.
            7. Fixed freezing issue when applying loop subdivision to undraped cloth.
            8. Completed the multi-threaded solver. If multi-threaded solver is turned on, most simulation tasks are distributed across all the available CPUs.
            9. Completed adaptive remeshing. Now, both cloth and strings are both refined and coarsened. Additionally, simulation can now be stopped and resumed from an adaptively refined mesh. Note that an adaptively refined mesh cannot be recorded.
            10. Updated manual
              Ahmed0007
              Thank you so much for this amazing Update
              i have a question.
              i can use custom pin (cube) as a Void object and get same results so what is the main use of Void group?
                Anton_S
                Void is used for excluding parts of the cloth mesh from simulation. If you have a large mesh and only want to simulate a part of it, you can use the Void shape. Simulating by parts improves simulation performance by a reasonable factor. If you use a pin to lock vertices in place, the locked portions of the mesh are still included in simulation and collide with other objects, hence no performance benefit.
                Simulating by parts will be covered in the tents tutorial that I started making but came across a thing that needs improvement. The void shape will definitely be covered upon releasing version 1.8.
                  Ahmed0007
                  [attachment=0:2vd1rl74]<!-- ia0 -->Tent.png<!-- ia0 -->[/attachment:2vd1rl74]
                  thank you so much for explanation.
                    Ahmed0007
                    Request.
                    Please add all context menu option in ClothWorks UI.
                    it would be great and time saving.
                    • 1852sketch1
                      1852sketch
                      Hello Anyone,
                      I was told to try hear to find out how to get my validation email sent to me. I did purchase Cloth Works on July 26th, 2019. I did receive my Pal Pay receipt but still waiting on the email from Sketchucation to complete the license.
                      I have tried to contact MikeL and Rich from their provided email message area`s from Contacts on this site. I have not heard anything from them and it is now the 31st. How can I get in touch with them to get the email. I have no choice but to have Pay Pal get my money back. I am lost and never have waited this long and to not hear anything, well sucks. I hope someone can help ...I just want to use the product.....
                      • G
                        Gábor
                        Hello 1852sketch,
                        I confirm that you've purchased ClothWorks. Our system sent out the license at time of the purchase by email. I've re-sent you your purchased ClothWorks license now. The email address you gave at the purchase and your email address what is registered here are different. Now I've sent the license to both email addresses. I hope you'll receive it this time.
                        Thank you for your purchase.
                          jkeller3
                          I've been using this extension for some time now but I currently have an issue. Clothworks is crashing when ever I go to drop a cloth over a 3d item. Single plane it has no issue, but if there are 2 or more angels outside of the one plane it crashes with no warning, or lag.
                            If you share the SKP file so we can see what you are trying to do, we can give you some help.
                              Anton_S
                              Yes, please share a model or send me a private message of your model, that I could look into the issue. Also, are you using ClothWorks v1.7.0 or an older version?
                                jkeller3
                                Anton,
                                I DM'd you a skp file and screen capture of what happens. It happens with all SKP files no matter how complicated or simple. At first I thought maybe the geometry I was using was too complicated but you can see with that simple file simple draping does not work for me. This file used a quadrilateral grid at 3000 and default settings. I've uninstalled CW and reinstalled it. Versions of my software are:
                                OSX Mojave Version 10.14.5
                                sketchup Version 19.2.221
                                ClothWorks version 1.7.0a
                                  Anton_S
                                  Joe Keller,
                                  I am able to reproduce the crash on my Mac OS X 10.14 but not on my Windows 10. I will look into fixing the issue as soon as possible. Thank you for the report!
                                  Anton
                                    Anton_S
                                    Announcing version 1.7.1:
                                    1. Fixed crash on Mac OS X. Thanks to jkeller3 for the report.
                                    2. Added Spanish language. Thanks to Oxer for the translations.
                                    • summerson1990S
                                      summerson1990
                                      Just bought this plugin and saw a new version released (1.7.1a) but when updated the toggle UI interface is not working anymore. It can't be opened. I use SU 2019 PRO on win 10.
                                      • summerson1990S
                                        summerson1990
                                        1. Added Spanish language. Thanks to Oxer for the translations.
                                        Hi! v1.7.1 and 1.7.0 toggle UI not working on SU 2019 PRO, Windows 10
                                          Anton_S
                                          The Toggle UI toolbar option works correctly on my system. Please do a clean installation of the plugin. Navigate to your plugins folder and delete ams_ClothWorks folder and ams_ClothWorks.rb file. Then do a clean installation of version 1.7.1.
                                          There are two plugin folders. To navigate to the first plugins folder, open a file explorer window and paste the following into the address bar: %appdata%\sketchup\SketchUp 2019\SketchUp\Plugins
                                          The second plugins folder is located at:
                                          C:\ProgramData\SketchUp\SketchUp 2019\SketchUp\Plugins
                                          Ensure that original version is deleted from both folders prior to installing the new version.
                                          • summerson1990S
                                            summerson1990
                                            Maybe you are using not a last release of SU (2019.2)? Because I did exactly you adviced and still the problem exists... I can make a gif screenshot in order to prove it.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 36
                                            • 37
                                            • 20 / 37
