    [Plugin] ClothWorks v1.8.0 - 28 Apr 2024
    715 Posts 166 Posters 871.0k Views 165 Watching
    • jo-keJ Offline
      jo-ke
      Oh since a few months I am using SU2019.
      I just started the exe file and installed SU and followed the instructions.
      http://www.zz7.de
        So does that mean that you did not install SketchUp 2019 by right clicking and selecting Run as administrator? If you didn't, close SketchUp and repair the installation. Find the downloaded installer file, right click on it. Choose Run as administrator and when presented with the options, select Repair.
        • jo-keJ Offline
          jo-ke
          OK Thank you. I will try it and report....
          http://www.zz7.de
          • jo-keJ Offline
            jo-ke
            I hate it... Where can I find the current download of SU2019pro.
            Can't find it at the homepage of SU....
            http://www.zz7.de
            • jujuJ Offline
              juju
              https://www.sketchup.com/download/all
              • jo-keJ Offline
                jo-ke
                Thank you juju. OK, found the installation file, downloaded it, ran as admin, repaired su and restarted my pc. Started su and: clothworks dissappeared again. 😞
                http://www.zz7.de
                  Anton_S
                  Does this occur to all your plugins or just ClothWorks?
                  • jo-keJ Offline
                    jo-ke
                    It affects only clothworks
                    http://www.zz7.de
                    • jo-keJ Offline
                      jo-ke
                      somebody any idea?
                      http://www.zz7.de
                        What exactly does "dissappeared" mean? Is it only that the toolbar doesn't show? Does it show in the Extensions menu? Does it show in Extension Manager? If it does, does it show as Enabled?
                        • jo-keJ Offline
                          jo-ke
                          first session:
                          starting SU installing clothworks. everything OK.
                          clothing SU
                          second session:
                          starting SU, clothworks dissappeared completely.
                          http://www.zz7.de
                            Anton_S
                            @jo-ke In your second screenshot, you have ams_ClothWorks at line 2. I am totally not sure where that is coming from.
                            Paste the following into your file explorer address bar and send a screenshot of the plugins: %appdata%\sketchup\SketchUp 2019\SketchUp\Plugins
                            Then navigate into the ams_ClothWorks folder (if any) and send a screenshot.
                            Then, paste the following into your file explorer, and send a screenshot, if the Plugins folder exists:
                            C:\ProgramData\SketchUp\SketchUp 2019\SketchUp\Plugins
                            • jo-keJ Offline
                              jo-ke
                              OK, theses are the two screenshots:
                              http://www.zz7.de
                                Anton_S
                                As you can see, you have the same plugin installed in both locations. Delete the plugin from one of the installed locations. To delete the plugin, delete ams_ClothWorks folder and ams_ClothWorks.rb file from either program data or roaming. I see that the one located in roaming is newer.
                                • jo-keJ Offline
                                  jo-ke
                                  Thats it!
                                  I deleted all folders in both directories and the rb files and reinstalled the plugin.
                                  restarted su and: it was still there!
                                  Thank you
                                  http://www.zz7.de
                                    This begs the question, how did you install Clothworks in the first place? With the normal installation methods, you shouldn't have been able to get it installed in the two directories. It should have only been installed in User/App Data/Roaming...
                                      Anton_S
                                      Announcing version 1.7.0.
                                      Changes include:
                                      1. Added Russian translation. Desired language is accessible from ClothWorks menu.
                                      2. Added thickness generator for both cloth and strings. Cloth with thickness can be subdivided and draped/undraped, just like cloth without thickness. It is, however, not recommended to simulate cloth after generated thickness. Generating thikness, just like applying loop subdivision or laplacian smoothing, is for finalizing results.
                                      3. Added a feature to simulate by parts. When simulation starts, objects assigned Void state subtract cloth and collider vertices overlapping their axes-aligned bounding boxes. Subtracted vertices are not included in simulation.
                                      4. Added an option to draw cloth using SketchUp OpenGL API. Drawing cloth rather than transforming vertices guarantees a better performance, especially when simulating by parts. If Adaptive Remeshing is turned on, mesh resolution changes are drawn dynamically. When simulation is stopped, the original mesh is transformed/generated as necessary.
                                      5. Reworked gizmo. The new gizmo allows for translating, rotating, converging, and diverging selected pin(s).
                                      6. Fixed drag for strings.
                                      7. Fixed freezing issue when applying loop subdivision to undraped cloth.
                                      8. Completed the multi-threaded solver. If multi-threaded solver is turned on, most simulation tasks are distributed across all the available CPUs.
                                      9. Completed adaptive remeshing. Now, both cloth and strings are both refined and coarsened. Additionally, simulation can now be stopped and resumed from an adaptively refined mesh. Note that an adaptively refined mesh cannot be recorded.
                                      10. Updated manual
                                        Ahmed0007
                                        Thank you so much for this amazing Update
                                        i have a question.
                                        i can use custom pin (cube) as a Void object and get same results so what is the main use of Void group?
                                          Anton_S
                                          Void is used for excluding parts of the cloth mesh from simulation. If you have a large mesh and only want to simulate a part of it, you can use the Void shape. Simulating by parts improves simulation performance by a reasonable factor. If you use a pin to lock vertices in place, the locked portions of the mesh are still included in simulation and collide with other objects, hence no performance benefit.
                                          Simulating by parts will be covered in the tents tutorial that I started making but came across a thing that needs improvement. The void shape will definitely be covered upon releasing version 1.8.
                                            Ahmed0007
                                            [attachment=0:2vd1rl74]<!-- ia0 -->Tent.png<!-- ia0 -->[/attachment:2vd1rl74]
                                            thank you so much for explanation.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 35
                                            • 36
                                            • 20 / 36
