    [Plugin] GKWare Cabinet Maker
    627 Posts 69 Posters 611.3k Views 71 Watching
      Garry K
      Cabmaker now gives you a tool to help you choose door sizes for beaded doors.
      As you can see if you choose a bead spacing and cabinet width like this it won't look very good. This spacing is 50 mm and the cabinet width is 700.
      If the width is changed to 800 mm then it works.
      Or if the width is left at 700 and the spacing is changed to 25 then it works.
        Garry K
        The next major version 4 of CabMaker is awaiting Sketchup 2019.
        PLEASE note:
        • Licensed users running CabMaker 2 can upgrade to CabMaker 3 with a 25% discount. This discount will end when CabMaker 4 comes out.
        • Licensed users of CabMaker 3 who have purchased a license within 3 months of CabMaker 4 release will receive a free upgrade to CabMaker 4 upon request.
        Lots of new features.
        1. Top and Bottom hangers now edged differently
        2. Added bead board for plain doors and for Shaker doors
        3. Moved Oven Panel section under Context Help over to additional
        4. Added Handle Height for Top Section of Tall cabinets
        5. Handle Override wasn't working for Drawers. Fixed
        6. Added drawer - 2 handles when wider:
        7. Added horizontal offset for handles
        8. Added Door Style drop down for Finished Panels and Finished Backs.
        9. Added 1 to 4 panels wide for - Finished Panels, Finished Backs, Doors, Top Doors and Mid Doors
        10. Added mid rail heights for - Finished Panels, Finished Backs, Doors, Top Doors and Mid Doors
        11. Added button that makes a copied cabinet unique
        Doors with multiple panels and Finished sides configured independently from doors.
        Finished backs - great for kitchen islands etc.
          Garry K
          CabMaker 3.0.135 and CutMaster 3.0.1.85 are now available on my website.
          These will be the last updates for Major version 3
          CabMaker 4.0.136 will be available later this week along with modifications to pricing. The 25% discount for CabMaker 2 users upgrading to CabMaker 3 will end once CabMaker 4 is released.
            Garry K
            CabMaker 4.0.136 is now available from my website.
            10. Added 1 to 4 panels high for - Finished Panels, Finished Backs, Doors, Top Doors and Mid Doors. This option is enabled only when the first mid rail height is set to 0.
            11. Added mid rail heights for - Finished Panels, Finished Backs, Doors, Top Doors and Mid Doors
            12. Added button that makes a copied cabinet unique
            13. Added Handle Offset per cabinet
            14. Added ability to save Door image. Images are now used by all Door and Drawer drop downs
            15. Now honoring file name case for DXF
            16. Added glass2
            17. Background color is pale blue for all overrides (-1) values
              Garry K
              CabMaker 4.0.138 is now available.
              1. Kick Ht Override sending wrong meta data for pullouts over to cutmaster. Fixed
              2. Side by side pulouts sending wrong door information over to cutmaster. Fixed
              3. Creating a new library without any files causes CabMaker to not use "Save" or "Save As". Fixed
              4. DXF export was adding too much to the undo stack. Fixed
              5. Hinged top and hinged bottom doors had pull in wrong position. Fixed
              6. Top Section door not honoring number of rows. Fixed
              7. Additional panels for Shaker doors sometimes has a raised panel. Fixed
              8. Added lateral adjustment to finished panels (doors)
              9. Set Lateral adjustment to negative side thickness and turn off side for door to replace side.
                Garry K
                CabMaker 4.0.141 is now available along with CutMaster 3.0.1.87
                Version 4.0.141 – Jun 9, 2018
                1. Materials editor check boxes are now showing the color.
                2. Shaker style doors second panel not clearing second panel raised panel. Fixed
                3. Added extend bottom in rules for microwave cabinets.
                4. Side thickness now can be different from rest of case.
                  Version 4.0.140 – May 9, 2018
                5. You can now adjust the position of Dimensions at a Cabinet Level.
                6. Face Frame construction points not correct for corner cabinets. Fixed
                7. Corner Cabinets dimension outline not accurate. Fixed.
                  Garry K
                  CabMaker
                  Version 4.0.142 – Jun 23, 2019
                  1. Added middle leg check boxes cabinet parameter.
                  CutMaster
                  Version 4.0.1.88 Jun 23, 2019
                  1. Drawer layer names no longer can have spaces. Now converted to underscores.
                  2. Drawer layer names now show in applicable machining section.
                  3. Added machining section for drawer bottoms pocket screws.
                  4. Added comment / purpose for each machining section.
                  Please note that starting with CabMaker 4.0.142 you require CutMaster 4
                  CutMaster 2.0.1.57 was released on Oct 24, 2017
                  Major version CutMaster 3 first came out 20 months ago.
                    Garry K
                    CabMaker 4.0.144 is now available.
                    Version 4.0.144 – Jun 30, 2019
                    1. Added Elevation Dimensioning.
                    2. Added optional Dual Dimensions so inches and mm will both display.
                    3. Added cabinet dimension overrides. You can now disable dimensions for a given
                      cabinet.
                    Version 4.0.143 – Jun 27, 2019
                    1. Modified startup code to guarantee that required folders exist.
                    2. Added automatic Backup and Restore for config folder.
                    Here is dual elevation dimensions
                    Override the PROJECT dimensions at the cabinet level or leave as -1 to use PROJECT settings. A value of 0 will turn off dimensions for the current cabinet.
                      Garry K
                      I will be releasing CabMaker 5 later today. This is because Sketchup 19.2 has just been released. CabMaker 5 will only be available at Sketchucation and on my web site.
                      All CabMaker 4 licensed users are entitled to a free CabMaker 5 license.
                      Trimble has at least 4 bugs in their Extension manager so I will only provide an extension link with cabmaker 4 on the Extension Warehouse.
                      1. Sketchup puts up a message "there is one extension ready to be updated" even though I have turned off "Allow checking for updates". This message only shows up if you have internet access.
                      2. Sketchup puts up the message even though the Extension Warehouse has an OLDER version. Essentially Sketchup isn't checking version numbers
                      3. Sketchup's Extension Manager wants you to click Manage and then Update. When you click Update then Sketchup deletes CabMaker 4
                      4. After Sketchup deletes CabMaker 4 it fails to install. This is not a true update - it is a delete and install with no rollback on failure.
                      My recommendation is to ignore the message and to NOT run Update. At least the annoying message disappears after a couple of seconds.
                      BTW - Trimble has told me they can't do anything about it. Essentially they aren't helping.
                        StefanBorreGude19731973
                        I cant get the Sketchup Plugin to work.
                        I have downloaded the trial version and created an account. I wish to use the DXF exporter.
                        However, when I try to use the DXF export function in SU there is a prompt that I need to sign in using my username, login and "Hardware". I know the two first since I just registered, but I figure I need to write something in the "Hardware" field.
                        Help??
                        BR
                        Stefan
                          Garry K
                          For now leave the hardware field blank. If you have issues then email me directly via CabMaker32 and I will help you.
                            Garry K
                            CabMaker 5 is available from my web site and from Sketchucation.
                            Version 5.0.146 – Jul 22, 2019
                            1. Added Finished Panels section in PROJECT tab.
                            2. Modified Frame section in Rules tab.
                            3. Added Clear Number in PROJECT tab.
                            4. Added Reverse (per cabinet) for dimensioning. works better for back to back island cabinets.
                            5. Created 32 metric templates complete with images.
                            6. Fixed Top Overhang Override coming from Rules.
                            7. Added auto load Finder or Windows Explorer.
                            8. Modified configs first time through, reports, animate, browser etc.
                            9. Alternate storage is now enforced as the default.
                              Garry K
                              I have added 32 Imperial Templates and 32 Metric Templates examples to the web site for free download.
                              Additionally I have cleaned up material and door templates.
                              Does anyone want other template examples such as drawer systems?
                              • N Offline
                                NBG
                                The 5th version is realy quicker than the 3, that's nice
                                • N Offline
                                  NBG
                                  is there a way to have a hole instead of a handle? So not a profile that goes from one side of the door to the other, but just for example a rectangular hole of 120x35mm on the top of a small door.
                                    Garry K
                                    Currently not. However I have had a number of requests for sliding cabinet doors.
                                    • N Offline
                                      NBG
                                      Would be nice indeed, the sliding doors, and those type of handle.
                                      EDIT SEPTEMBER 2
                                      for the question below, I just forgot to switch from "sink" type cabinet after generating this one. So problem solved
                                      OTher question: since i upgraded I have a problem with drawers. If I choose 1 drawer, there is no drawer box in the cabinet, so nothing happen if i click "interact".
                                      If I choose more than 1, it's the same for top drawer, but not for the other below.
                                      It looks like an option like "make top drawer as fixed panel" but I don't find anything like that.
                                      About drawer, you mentionned drawer systems template... I'd love to have Blum Legrabox. I don't know how common they are among your client though.
                                        Garry K
                                        You should email me directly via cabmaker32 - that is if you want quick a response.
                                        The manual states that a cabinet drawer height of 0 - means do not include a drawer box. Set it to -1 if you want CabMaker to calculate drawer box heights. There are situations where users do NOT want a drawer box since they want to use other specialized hardware.
                                          Garry K
                                          Getting ready to release CabMaker 5.0.147 and CutMaster 4.0.1.90
                                          CabMaker
                                          1. Fixed PROJECT tab Finished Panels section.
                                          2. Added Rotation Group for CutMaster
                                          3. Cleaned up Finished Panels and Finished Backs for Door Panel parameter.
                                          CutMaster
                                          1. Added User Flag (Rotation Group). You can now allow various parts to rotate which increases yield.
                                            There are 4 settings
                                            0 - use sheet grain
                                            1 - do not rotate
                                            2 - can rotate
                                            3 - must rotate
                                          • N Offline
                                            NBG
                                            HEllo,
                                            I can't figure out how to add a simple color to CAbmaker. I'm trying to follow the steps described in the manual (page 206), I already did it with a texture, but I'm stuck at step 1 because it's not a texture but a color this time.
                                            When I go in sketchup in the materials panel, if I right click on the color I want to add to cabmaker, I can't select "export texture image". It's grayed out.
                                            If I choose a material which is clearly a texture (wood, metal...) the option is available.
                                            any workaround?
                                            I'm trying to add a black that's a bit "less black" as the one in cabmaker is black as this new M.I.T. material, and make every details invisibles, even with shadows.
                                            And I want a real anthracite gray too. the dark gray is not very dark.
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 31
                                            • 32
                                            • 26 / 32
