    Installing twilight render to SU 2019
    5 Posts 2 Posters 2.2k Views 2 Watching
    • emerald15E Offline
      emerald15
      I've only just updated to SU2019, (not wanting to do it mid project). I can't get Twilight Render to install - Has anyone got any ideas please?
      • BoxB Offline
        Give us a clue, what doesn't work? what have you tried? have you downloaded the latest version from twilight? Have you downloaded the correct version from twilight? Is 2019 installed correctly and working? What version of windows? have you really gone from version 8 to 2019? so many questions.
          emerald15
          Sorry Box, here's the full story. I'm using Windows 10. I'm running SU2018, but I've only just installed SU2019, as I was busy completing several projects. SU2019 seems to be running normally, I'm just adding in all my prefered extensions. I already have Twilight Render 2 running on SU2018. I just don't seem to be able to get it running on SU2019 - the name should be coming up under the extensions menu but it isn't there. Any advice would be appreciated.
          • BoxB Offline
            You don't say whether you have reinstalled it or are just trying to make it work from your previous install.
            You would need to download and install the latest version after you have installed 2019, during the install, if I remember correctly, it will ask what SU versions you want to install it for.
              emerald15
              Sorry for the delayed reply - internet out! That's solved it! I had tried to re-install, but it obviously hadn't run through properly as I don't recall it asking for the SU versions. I'm now up and running. Many thanks for the advice!
